Question about Canon imagePROGRAF iPF8000 Printer
Ink will not dry
Any solution for black ink not drying on canvas media on my ipf 8000. We can handle it but if you lightly rub it, the ink smudges.
Art
artman@bulletgraphics.com
Without having to apply a varnish, the best way is to use frog juice which is a spray which come as both matt or gloss and gives the same eefects as a varnish but isnt noticable with the matt. This reduces the solid black areas from smudging.
Posted on Jan 10, 2009
Originally the black ink would not print. replaced, primed, cleaned. nothing, the same problem, no black ink. Now I can't get the cartridge light to quite blinking. It is not steady orange, but a...
First off, if you touched the metal contacts on the printer or cartridge, you could damage or leave a film on the contact surface. Take it out of the printer, with a qtip dip in rubbing alcohol, squeeze out access, rub surfaces, air dry, and reinsert again. If still no ink, turn the print end up under the very hot water tap and run for 2 minutes. Dry and replace. It may do the trick.
Mar 01, 2014 | HP DesignJet 450c InkJet Printer
Hello, i'd like to ask for advice. I have this one problem with canon ipf 8000, we've been using Schoeller H 64160 photopaper for poster printing with no problem. But recently we got different type of...
iI would check your paper type setting. you are working with a liquid type of ink and water will effect it. check the drying time of this ink. set your paper type to the set the type most suitable for this paper. try heavy gloss. you will find it under paper settings in the main menu. If no luck refer back to the ink and its compatibiliy with your ipf 8000. now if these are a recharged cartridges. you should change to the oem. meaning" original engineering manufacture".
Apr 09, 2017 | Canon imagePROGRAF iPF8000 Printer
I'm trying to print wedding invitations on my Canon MP460. I'm using a cardstock thickness of paper and have set the ink levels for "Other Photo Paper" on my Mac. The paper has been going through...
Sounds like the ink isn't having time to dry and is rubbing along paper.
Paper may be too thick. If it prints OK on normal paper (test first) but not on thick card, then it doesn't support thick paper settings.
Jan 31, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Printer leaves gray ink on page
I guess that you use a non-genuine print cartridges, try to use a genuine one.
please confirm me at walid_sayed@hotmail.com
thanks
Apr 03, 2010 | HP DeskJet F380 All-In-One Printer
Printer is smudging ink/transfering onto innapproriate pages
take the ink cartridges out; clean them with a q-tip and rubbing alcohol, clean each cartridge; let it dry and then run a test page
May 04, 2009 | Xerox Phaser 6130 Laser Printer
Ink remains wet and if touched smudges.
Sounds like the fuser is bad...try installing a new fuser.
Apr 20, 2009 | Office Equipment & Supplies
Canon PIXMA MX700 printhead immediately coated with ink, smudges
It's likely that the foam pads that the print head rests on when the printer is not in use are saturated with ink. They're to the right as you look into the printer: a rectangular one for black ink and a square one for the colored ink. If you power the printer off and back on, with the cover open, you'll see where the printhead goes to rest.
The pads aren't easy to get at, but you can blot them with a paper towel. Gummy, half-dried ink dissolves in rubbing alcohol, and you can soak a paper towel or a cotton ball with alcohol and wipe down the area. I've had good luck soaking the pads with alcohol, then blotting them dry with a rag.
Feb 18, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Print head problem
Take it out and rub the ink outlet on the cartridge with a piece of tissue to clear any residual dry ink. You should eventually see two lines of ink on the tissue, yellow and black. If not then it has dried inside and there is not much you can do except replace it
May 10, 2008 | HP OfficeJet Pro K5400dn Photo Printer
Canon imagePROGRAF  iPF8000 Printer Logo
212 people viewed this question
old marine
old marine
