Question about Philips 32RF50S 32" TV
Phillips Big Screen Older Model
Our Tv was moved and when it finally got to our new house, the picture is all green. I have tried all the menu buttons and looking to see where I can go next. I even took off the screen and cleaned everything in side thinking maybe the blue and red was dirty. NO luck......Someone said i need fluid but they only said that didn't look at the TV ...what does that mean..
    Sergeant:
  • 337 Answers
It means the fluid that cools each picture tube is low in the green but where did the fluid go,remove the back cover and check for a fluid leak towards the front side of the chassis and if any it should be right below one of the picture tubes.The description of your problem tell us you have a rear projection set but the heading shows a direct view tv.?????????? Since it was move the leak is only a possibility there could be other reason.Be careful and be sure set is unplug.
Posted on Sep 29, 2006
55PW9363 55 in. Rear Projection HDTV-Ready Television: My Phillips big screen has double images and doubl...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 17, 2010 | Philips 55PW9363 55" Rear Projection...
Green light flashing and no picture on our tv
2004-Model H 347 - 10839 Phillips big screen HDTV. The picture went 3-D.
Dec 25, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Black Box appearing on my screen
go into your menu and access the closed caption modes. someone has accidently put your tv in the "text" mode. turning off the closed caption feature will correct this.
Apr 01, 2009 | Televison & Video
Color is off since relocation
Hello Mia1026,
First I would suggest that you have a qualified TV technician look at your set because it sounds like your Blue and green CRTs have been damaged in the move. If this is the case they will have to be replaced.
I would if I were repairing this TV:
Check to see if there was physical damage to the CRTs
Check to see if the HV trippler was functioning
Check to see if the CRTs lit when power is applied (on the Green and Blue CRTs)
That would be a good start.
I hope this helps,
Thank you,
Sep 15, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Older model Magnavox Big screen tv
Sorry Bud... It is dead, and would cost more to fix it then to buy a new one. And even if you got it fixed, something else will blow out on ya before to long, and most of those old parts are no longer made. Hey- it had a good long run of it's life, it's time to let go.
May 30, 2017 | Televison & Video
Problems playing my Phillips DVD/ VHS with my new WESTENHOUSE HDTV
I notice this was made in 2008 and I hope you have found the answer. But if you or others have not here is my answer. Are using the RCA cable from the output on the DVD Player and you have plugged it into the RCA in ports then you need to use the remote to move through the on screen menu. My INSIGNIA has a Source List menu on the remote that shows on screen. I can scope through the MENU for TV, Composite Side, S-Video Rear, S-Video Side, Composite 1, Composite 2, VCR, HDMI 1, HDMI 2, HDMI 3. That is found using either the INPUT button on the upper left on the remote or the buttons; VIDEO, COMP, HDMI, AND TV across the top of the remote. Hope this helps.
Apr 13, 2008 | Philips Televison & Video
Plasma tv screen has green pixelating into pictures
I had the same problem and solved it with a factory reset. hold menu button dowm for 10 seconds and it will alow you to reset all the colors.
Feb 01, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Phillips TV/VCR combi 14PV400/07
To solve this problem, cancel the wake up alarm !
Dec 23, 2007 | Philips 14PV225 14 in. TV/VCR Combo
Problems with my Phillips Rear Projection TV!!
have the coolant (glycol) in the CRT's....not as expensive as buying a new set...and sounds like it should be good as new if thats the only problem you have with it.
Jul 16, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 32RF50S 32" TV Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
