Question about Sony FD Trinitron WEGA KV-27FV310 27" TV
SONY KV-27FV310 FINE TUNING
I have distortion in the picture on channels 2,3,and 4. I have verified with another TV receiver the cable source is fine. It appears these channels need some fine tuning. How do I accomplish this???
Tim Urbanski
tim_47@yahoo.com
    Sergeant:
    Champion:
  • 267 Answers
AUTO PROGRAM YOUR CHANNELS. IF PROBLEM PERSISTS REPAIR OR REPLACE TUNER.
Posted on Jan 12, 2009
Re, all i get is a distorted picture of the game screen. I've tried fine tuning the TV around that channel but it doesn't help.
hi sounds like the av sender inside the ps could be getting dodgy, have you tried it on another tv?
Apr 07, 2012 | Sony PlayStation (PS) Console
Sony pre-LCD 32" receives power and directly
I would take your A/B switch out of the line. And get yourself a good reciever to channel every thing.
Jan 04, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Cannot get channel 2 clearly
Normally grainy pictures are a result of poor ground connections, although usually for more than one channel. Check the cable connections first. Otherwise all I can suggest is to have the tuner replaced.
Dan
Sep 11, 2008 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
No signal
Check is RF Antena/ Cable connected? If yes, go to TV Menu and select Auto-Program. TV will start tuning and search all available channels on cable/ on-air. If there is no channel reception, TV has defective Tuner. If you know basic electronics knowledge, replace the Tuner or contact nearest Sony repair shop.
Jun 04, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony KV-27FV310
Component In is not converted to composite out (yellow)
TV monitor out normally goes to A / V receiver in......T.
Nov 18, 2007 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Sony TV - Loss of half the picture
sarge, it sounds like the vertical output IC went bad on you. If it was a bad connection or a bad capacitor, your picture would have been a straght line across the screen. They call the output section of the IC a push-pull type of amp, so the top half of the sweep IC went out. If you have had some soldering experience, and or experience with solid state repair, locating the bad IC and replacing it is no big deal. If you havent, stay safe and call in a pro to assist you in this repair, as there is alot of high voltage inside this puppy that is still present even if the set is unplugged. It should not cost an arm or a leg to repair this set. An honest repair on a set like this if you take it in should not exced 125 to 150 bucks. Good Luck PS Please dont forget to rate this thread.
Oct 22, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Snowy picture and Yellowy Whites
Make sure the TV setting is set to or . A power surge may have reset your ?cable-ready? TV. Check the cable setting on your TV and make sure it is set to or . If a VCR is connected: * The VCR needs to be on channel 4. * VCR may not be ?fine-tuned? to channel 4. Locate and adjust the fine-tuning mechanism until the picture comes in clearly. * The <3/4> switch may be in the wrong position. Locate the switch on the back of the VCR and set it to <4>. If a converter is connected: * Make sure the TV is on channel 4. * TV may not be ?fine-tuned? to channel Locate and adjust the fine-tuning mechanism until the picture comes in clearly. * Determine if the converter is bad. Locate the cable wire coming in to the room and connect it directly to the back of the TV. If the picture is clear, your converter needs to be exchanged. Give us a call or stop by your local office and we?ll switch out your equipment. Check the fine-tuning of your TV
Jan 11, 2006 | Fujitsu Plasmavision P42VCA30EH 42 in....
Sony FD Trinitron WEGA KV-27FV310 27" TV Logo
121 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
