Question about Kenmore 62602 Electric Dryer
What does a thermal fuse look like
The washer sprung a leak, and now the dryer does't work after getting wet.Is it a fuse or what should I do?
what does fuse look like
    Sergeant:
    Champion:
  • 291 Answers
The fuse is a small plastic piece with only 2 wirs connected to it and it will be behind the back cover or the ones that the back dont come off, it is inside the lower panel in front ,,, check your break ,,,, it may have trip it even if it dont look or feel like it.
Larry
Posted on Nov 25, 2008
It only wash & don't spin? Then it stops and leak water by the door....
LG Washer & Dryer 7 (WD12331AD)
Its is a direct drive front loader with 7kg capacity for washing and 3.5kg capacity for drying.
when new
thats 7 kg with wet clothes and water
and only 3.5 kg wet clothes to dry
the older it gets the less weight it can wash and dry
worn motor or drum overload if it doesnt want to spin at all
leak at the door . replace the door seal ..is a most common fix
extra info
It has 9 preset settings, 400 - 1200 RPM, 5 temperature settings, digital display and delayed start timer.
Sep 20, 2016 | LG Washing Machines
Back of toilet lid is wet every time and gets your back wet?
3 things come to mind.
1. Condensation from the temperature difference between water inside the toilet and the surrounding atmosphere but since you keep the lid open that may be unlikely.
2. Take the tank top off to ensure the fill hose hasn't sprung a leak and spraying water toward the front.
3. Someone in your household has terrible aiming skills.
Sep 01, 2014 | Washing Machines
Drip water from bottom of dryer
Not sure what all you did already. But you may want to check your washer machine and see if it is spinning the clothes out. You may have problems with your washer machine. Loose belt, clogged up water pump. If your clothes are that wet and water is leaking from your dryer, the problem is not the dryer. Check your hose connection on your washer also.
Aug 05, 2012 | Haier HLP140E Electric Portable Dryer
Water leaks in all programs
Bosch WET 2820 Front Load Washer / Dryer water
Leaking.
This video will show you how to change a door seal on this Bosch front loader washing machine .
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 27, 2011 | Bosch WET 2820 Front Load Washer / Dryer
Leaking from a washer/dryer in condo
Just turn off the water, remove the hoses and unplug it, then bring it out away from the wall. You should be able to tilt the machine and see it from underneath to detect the source of the leak. Also, find how to remove the front of the washer without dimantling the machine and run it without the front panel on there. That is the best way to track down your leak. It could be a seal under the tub, a hose coming from the tub to the pressure valve, a hose from the water pump or the pump itself. The pump is at the bottom, so it will get wet regardless of where it is leaking from. Make sure you dry out everything before you start to look for the leak.
Sep 04, 2009 | Whirlpool Washing Machines
The gfci on cord keeps tripping
GFCI's trip because theire is current leaking to ground. This often can be be caused simply by electrical components getting wet.
Or, it can be caused by a serious short to ground.
Fist, check to see if the inside circuits are getting wet from an internal leak. If so, fix leak, dry off components with a har dryer, try again.
If GFCI trips, it should be serviced by an experienced appliance repair person.
May 13, 2009 | Karcher K2.26 Electric Power Washer
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Washer portion not working...?
wowwow...that's a sprung seal allright..have to turn it over, and remove the bottom, motor, etc..got a service person handy?
Feb 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 62602 Electric Dryer Logo
79 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
