Question about Whirlpool LER4634J Electric Dryer
Fuse blew replaced it and dryer won't work.
Whirlpool 4cycle 3 temperatures Model #LER4634JQ0. Fuse blew in main box we replaced it and the dryer will not come back on.
  • AGENTBARBEE Jan 03, 2009
    IM GETTING POWER TO DRYER BUT DRUM WILL NOT START AT ALL. CAN YOU HELP
  • 24 Answers
By the way, voltage is 230 AND 115.
With one fuse, you will have 115 to one leg.
Leg = Black or Red wire.
White is the neutral and, (if you have it), solid copper is the ground.
White to red = 115 v
White to black = 115 v
Red to black = 230 v.
BE CAREFUL.
I like to check the voltage at the terminals on the back of the dryer. Usually covered by a small plate.
If you have the correct voltage here and the dryer still won't start, let me know.
mrboo747
Posted on Nov 11, 2008
    Scholar:
  • 62 Answers
Did you replace both fuses? there are 2 thirty amp fuses both are needed . if you can check voltage to the outlet that will eliminate an electrical problem and narrow it down to the dryer. If you have voltage to the dryer outlet, then I would look at the connections at the terminal block(where the cord connects to the dryer) then a meter would be needed to do much more testing.
Posted on Nov 05, 2008
What is wrong with a whirlpool 4 cycles 3 temperature dryer that will not get hot?
First clean the vents inside the dryer and to the outside be sure and clean around the blower wheel. Check the thermal fuse, the cutout fuse & all the thermostats. Check the heating element also check that it is not grounded to the heater box. Last check the centrifical switch on the motor as the heater runs through it.
Hope this will help you
Feb 27, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer modle LER4634JQ0 doesnt heat i tested out the heating element it still is good and the fuse and that is still good i tried testing another little fuse it looked like at the top of the heating duck...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Whirlpool LER4634J Electric Dryer
How do i reconnect the heating element wires on a whirlpool dryer ler4634jq0? i forgot to log the wire placement when removing the heating element. Help!
if there are only 2 wires to the element box terminal it doesn't matter which wire goes on which terminal,because its a.c. current
Apr 06, 2011 | Dryers
I have a Whirlpool Model LER4634JQ0 that was used to dry a heavy quilt. When the next load was put in to dry, the dryer would not start. Power to the dryer is okay. My wife tried to start the dryer today...
sounds like the dryer belt is broken or off the pully, does it make any noise at all? if yes then unplug carfully pull out and open to check belt replace if needed
Jul 06, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Mod LER4634JQ0 has stopped working - you can hear the timer clicking, but does not operate on any cycles
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 09, 2009 | Whirlpool LER4634J Electric Dryer
It takes my whirlpool dryer three or four cycles to dry clothes
Kenmore Dryers are almost all the same therefore am sending this;
http://www.youtube.com/watch?v=lHkIK8oy1K4
How to Clean a Dryer Vent Video
http://www.youtube.com/watch?v=5Dj4im31lRY&feature=related
Why is so inportant to clean the lint?
http://www.youtube.com/watch?v=9kxbF31Oh4s&NR=1
It was helpful?
May 15, 2009 | Whirlpool Dryers
Whirlpool LER4634EQ, when I press the button to turn dryer on it doesn't kick in, won't turn on. but you can hear the timer humming on the temp dial. Dryer was working perfectly. Is there a fuse in those...
yes, it sounds like you blew the main dryer thermal fuse, easy fix. write down the model number and go and buy one were ever. it will be white plastic with two metal tabs coming out of it. it might be skiny or it could be a round one no bigger then a half dollar. write me back once you have this. kelly
Dec 22, 2008 | Whirlpool LER4634J Electric Dryer
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
Whirlpool ler4634jq0
The gas das't start tere for dryer goes for long time without drying the klotnes
Nov 06, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
158 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
