Question about Sony Ericsson W910i Cellular Phone
Front slide not working
The slide mechanism somtimes does not work propely? it seems as if there is something stopping the slide action,
Take the battery out, you should see two tiny screws. One has come loose and is jamming the slider.
Posted on Jan 26, 2009
    Brigadier General:
  • 7,752 Answers
You should take the phone to a mobile service center and have them correct the problem for you.
Posted on Nov 10, 2008
I have an 04 Pacifica FWD. I have a rubbing/grinding in front end. Put car on stands and let it idle in drive. Something is causing front wheels to randomly stop rotation. CV joint or tranny goin bad?
what you describe on the stands is normal differential action
rubbing /grinding noise can be bearings ,brake pads or calliper stuck on the slide pins
Jan 30, 2017 | Cars & Trucks
How do I open stuck sliding shelf on front of tower?
no pc stated must TOWER.
I have tower severs, huge, and desktops and more.
tower means zero.
USB flash stick (thumb drive, etc)
no PC stated, all HP PC have service tag
tell the full model name , wins 10x better answers. for sure.
here is your tag , on one of min is top front , other left side. case.
clear as day... HP bla bla
http://pcdied.com/
May 28, 2014 | HP Pavilion Computers & Internet
How to repair the front left wheel and height adjustment assembly on a Kirby G10 vacuum cleaner
The wheels are held on by a screw behind the wheel guard, i suspect your height adjuster has come loose off the spline, this can be simply tapped back onto the axle
Jul 21, 2017 | Kirby G10 Sentria Vacuum Cleaner...
Drivers side sliding door won't close
check mechanism on working doors. In my car if I move the catch on the door(click it like in closed position)like it was closed,then when I open the handle it releases open;this shows me closing/opening. Spray penetrating fluid on the metal/mechanism,possibly rusty and prevents smooth actions. Hope this helps.
Jan 01, 2014 | 2004 Nissan Quest
Chainsaw is going well,then if i stop it let say for 5 minutes , then if i want to start it again ,it may start propely or it may not but if it dosen't start propely,it will then start and stop ,
This sounds like vapour lock ( when the fuel in the carb and block vapourisis before it can get into the engine due to heat ) so anything you can do to reduce the heat will help, make sure the starter grill is clear and not restricting air flow over the engine, if the fuel is stale replace with fresh, try not to let the machine completly run out of fuel before re filling, do not use super unleaded fuel, richen up the fuel mixture on the carb H screw, use the primer if fitted to pull cool fuel through the carb
Jun 25, 2012 | Garden
Toro self propelled rear mower recycler.. starts and runs fine..Then stops if you do not keep the propulsion in gear
I would say that something inside the mechanism that engages the self-propelled action has broken. When you release the lever, (most of the way), that keeps the S.P. action moving, it's suppose to flip the action off but keep the motor running. And when you release this same lever all the way, it acts as a kill switch. If your wheels never disengage, then I would look at the mechanism spoke of above.
If you hear this mechanism click when you release this lever, this is good and it's not broken. Then you may have grass and junk clogged up under the cover where the front wheel is. This would also keep it from disengaging.
Good Luck!
Jim
Aug 19, 2011 | Toro Power Lawn Mower
Frigidaire Front Load Washer stops mid cycle
washer stops as i check to see why, It seem's to be the knob. When i touch it it goes back on somtime (temporaly) fromt loader frig
Jul 28, 2011 | Frigidaire ATF6000ES Front Load Washer
My LS1216 slide compound miter saws mitering table is stuck at 0 degrees it appears jammed although I've looked for something jammed stopping the plate from moving and see nothing, the handle locking...
Hello stella....... There is a locking mechanism on the miter saw to lock it on whatever setting you require. loosen that locking mechanism and the saw should move for you. Here is a schematic of the parts so you can see exactly which parts are involved
http://www.searspartsdirect.com/partsdirect/part-model/Makita-Parts/Saw-Parts/Model-LS1220/1339/0744300/P8100100/00002?blt=06&prst=&shdMod=
Joe
Thanks for choosing Fixya!
Feb 06, 2011 | Makita 10" Dual Bevel Sliding Compound...
S Reg VW Golf cabriolet roof has stopped working its doing nothing at all fuses seem fine and wires all in place any suggestions?
My S Reg VW Golf Cabriolet roof has stopped working - I can hear the motor buzzing - but no action ! Any suggestions ? The car has recently had a full service.
Jul 02, 2009 | 1996 Volkswagen Golf
Sony Ericsson W910i Cellular Phone Logo
260 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
