Question about M-Audio MobilePre (US41401) Audio Input
Hardware issue Can't seem to get the device recognized by computer (have tried both laptop and desktop with Win XP SP2). Have uninstalled and re-installed drivers and get it going. Under device manager I have an exclamation point and it says The Device Cannot Start (Code 10). Have tried another USB cable and can't get it to work. Both cables do, however, power up the device.
  • Anonymous Dec 15, 2008
    ditto
5 Suggested Answers
SOURCE:
SOURCE: Problem with "M-Audio 49e keystation"
The 49e has been a real pain--especially if you have previously used another M-audio controller on the same machine. I just spent 3 hours to get mine working on XP (with a Creative sound card). In summary--for my machine--Windows XP kept putting the old WDM driver back (vintage 2001), even though I installed the M-Audio. I had to finally use the 'Add New Hardware Wizard' and force it to install the non-certified M-Audio drivers that were supposedly installed when running the M-Audio installer. (Skip internet search, and browse to M-Audio folder in Program files, it will eventually find them.) There are two M-Audio USB drivers that need to be 'forced' via New Hardware Wizard. But Windows thinks its drivers are a better match and even though 'device is working properly' it doesn't get recognized in your software. After I go rid of the WDM drivers and replaced them with the 2 USB ones from M-Audio, my DAW finally recognized the keyboard. I even went through regedit to clean up all the M-Audio stuff so I could get a fresh install. I don't know if this makes enough sense, but good luck.
Posted on Oct 24, 2007
SOURCE: Midiman Midisport 4x4 USB freezes
well, all you need to, the midiman need chances you to chance it, try another one
Posted on Dec 04, 2008
SOURCE: M-Audio KeyStudio is connected using the USB cable
Soltion is to download the software for Micro USB from M-Audio website and connect the USB of the Micro USB to your computer with headphones and mic connected to it and connect the USB cable from the M-Audio KeyStudio keyboard to the computer and the Pro Tools M-Powered Essential software will work.
Posted on Feb 07, 2010
  • 1027 Answers
SOURCE: i have driver installed but every time i plug in
Just what the message means- USB devices should draw only 200ma or so. My guess is that the M-Audio device has a shorted capacitor inside and that causes high current draw. It needs to be serviced or replaced.
Posted on Apr 23, 2010
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
Driver for Pioneer DVD-RW DVR-K16D
Suggest you try this, Chris;
Go to Device Manager.
[WinXP:
Start > Right-click on My Computer > Left-click on Properties at the bottom of the list > Left-click on the Hardware tab. Left-click on Device Manager
Win Vista/ Win 7:
Windows logo button > Right-click on Computer > follow the above ]
When Device Manager loads click on the + sign, to the left of DVD/CD-ROM drives.
Right-click right on the name of the optical drive. (CD/DVD drive)
Left-click on Uninstall.
A Microsoft 'squawk box' will come up; "Warning you are about to uninstall this device"
It's OK. Click on OK.
Now close all windows, go back to your desktop screen.
Restart your computer.
(WinXP: Start > Turn Off Computer > Restart
Win Vista/Win 7: Windows logo button > Restart )
When Windows fully loads you will get a pop-up, out of the system tray, "Found new hardware device", and perhaps another one, "Found Pioneer DVD-RW"
Windows has the habit of losing drivers. Let's see if this 'slaps Windows around'.
Regards,
joecoolvette
[Driver: Small piece of software that allows the Operating System to communicate with a device.
Windows XP/Vista/7 is the O/S, the optical drive is the device ]
Nov 26, 2012 | Sony VAIO VGN-BX660P Notebook
My audio device is not working. so i want to sound driver for it.
You can download all the drivers you need for Lenovo 3000 Y410 Laptop from the below link
http://www-307.ibm.com/pc/support/site.wss/MIGR-68104.html#audio
Just scroll down the page for Audio drivers for both win XP and Vista,click on the blue version number to download the one you want.
Note : Incase you have win XP,some people has issues installing the xp driver with sp3 installed,the driver seems to work with only sp1 and sp2.So if u have SP3 and unable to install xp driver, do one of the following.
1) Uninstall SP3 and install SP2 and then try installing the driver for XP
2) Download Vista driver and install it with windows compatibility mode set to XP SP2.
Nov 30, 2010 | Lenovo 3000 Y410 Laptop
My PC or Laptop will not recognize my maxtor one touch 111 120GB hard drive. it was working fine befor and now i get an error from windows that says: thre was a problem installing your new hardware
It is your driver related issue.
Check your operatign ssytem version is winxp sp2 ?
SP2 is perfact for usb 2.0
Also you can try to uninstall all usb driver and install inf update utility it is comes with motherbord disk.
You can uninstall usb drivers from computer with device manager .
For that go to my computer proeprty then hardware then device manager then uninstall all usb drivers.then restart the computer then check.
Also check your harddriver usb cable is working fine tryt all usb ports of computrer 1 by 1.
Also try in another computer.
Aug 24, 2009 | Maxtor OneTouch III Mini Edition 120GB...
No sound devices on my sony vaio VGN-CR322H laptop
Pl check the whether all driver from OEM have been installed including MB and try to reinstall the driver it should work fine. or reinstall the SP2 for win XP. then install the OEM driver again, this should work, else there might be hardware problem.
Aug 20, 2008 | Sony VAIO PCV-J200 PC Desktop
Creative zen vision m is not detected.
You Could Try This..
I'm Using Windows XP (SP2)
I Had This Problem with my Zen & found that if I Uninstalled the USB in Device Manager (Portable Devices) and rebooted the computer and let Windows redetect and install them.
YOU MUST HAVE YOUR PLAYER PLUGGED INTO THE PC WHEN YOU DO WHAT'S BELOW, AS YOU NEED IT TO APPEAR IN PORTABLE DEVICES
To Get To Device Manager Quickly - Highlight My Computer On Desktop/Right Mouse & Choose Properties/Choose Hardware At Top/Then Select Device Manager/Then Portable Devices/Highlight Your Player & Right Mouse Then Choose Uninstall/Exit Device Manager/Disconnect Your Player/Them Restart Computer..../When The Computers Ready Try Connecting Your Player Again It Should Work?
Jul 26, 2008 | Creative Labs ZEN Vision:M Digital Media...
Labtec Wireless desktop 1200 not working- win xp sp2
Seen to be a problem with power manager.
On Linux the solution what
echo -1 >/sys/module/usbcore/parameters/autosuspend
I find it here:
http://www.linuxquestions.org/questions/linux-hardware-18/usb-error-usb-2-4-device-descriptor-read64-error-71-643022/
Apr 26, 2008 | Labtec Wireless Desktop Keyboard/Mouse...
USB will not recognize devices
just try to first install your device driver in xp-home sp2 and then try if not pllz ask me.
Dec 25, 2007 | Dell Dimension 4500 PC Desktop
Acer aspire 4720z audio driver for widows xp home edition sp2
is there any other way to solve the audio problem? after i install win xp sp3 in my acer aspire 5550,i get stuck in installing audio driver.i have download the driver from many website even in acer.com, but still cant solve it..please give me some idea..
Dec 02, 2007 | Acer Aspire 4720 Notebook
M-Audio MobilePre (US41401) Audio Input Logo
Top M-Audio Televison & Video Experts
Paul Bade
Norman Worley
Are you a M-Audio Televison and Video Expert? Answer questions, earn points and help others
