Question about Dell Precision 530 Minitower 2.4Ghz 93218917
Image is not positioned properly on the wide flat screen
Dear Expert,
I connect a Dell SP2208WFP Flat Panel Monitor to a Dell Inspiron 1420 note book computer. The image on the wide flat screen is clear but it is positioned to the right and the right margin of the image is cut off. Could you please show me how to position the image properly on the wide screen (ie, how to move it to the center)?
Thanks,
James
  • Anonymous Feb 21, 2009
    I have 1 1/2 vertical space on the left side of my 16" flat screen monitor. It's connected to a Gateway laptop.
  • tielmanx Feb 21, 2009
    I have 1 1/2" vertical space on the left. Canot get a full screen.
    Scholar:
  • 59 Answers
Hi... generally the image adjustment and positioning controls will be located on the monitor itself.But iam not sure about this model because i dont have one.You can try the user manualfor further adjustments. Also try changing the refresh rates..i.e keep them the highest possible. Also if your notebook uses inbuilt nvidia graphics, then you will be presented with a system tray applet something like "nvidia display control"... You can change the positioning from there as it will have a interactive GUI.[graphical user interface].
Posted on Nov 04, 2008
Dell monitor blue light on no display
Hook it up to a different computer or laptop. If it still has issues then change out the cable. Add more info: has it ever worked? When was the last time it worked.
Apr 14, 2014 | Dell 22" SP2208WFP Widescreen Flat Panel...
Laptop all whit screen
Dell Inspiron 1420 Notebook PC?
The white screen can be fixed. How?
Connect a VGA monitor to the laptop. Connect to the VGA port on the right rear. Example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT type monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
By default the display should show on the external VGA monitor.
No?
Press, and hold the Fn key down, and at the same time tap the F8 key ONCE.
Still no?
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down again, and tap once more on the F8 key.
No display on the external VGA monitor, means you have a bad graphics chipset. Replace motherboard.
Display does show on the external VGA monitor, means you have a problem with;
1) Video Cable
or
2) Screen Inverter
or
3) LCD screen
Video Cable:
The Display Panel Cable (Video Cable for Dell), connects to the motherboard by the left Hinge.
Goes under the left Hinge, and up into the Display Assembly.
It then connects to the Screen Inverter, and to the back of the Display Panel. (LCD screen for Dell)
From normal opening, and closing of the laptop, the Display Panel Cable may become pinched in the left Hinge.
This can cause;
A) The connection at the motherboard to come loose
B) The connection at the back of the Display Panel to come loose
C) Stretch the wires inside the Display Panel Cable's sheath, and damage the wires. (Break)
If you are lucky just the connection at the motherboard, and/or connection at the back of the Display panel, may have come loose.
Diagnoses is to NOT just look at the connections, but physically push the connectors of the Display Panel Cable, into the connector at the motherboard, AND back of the Display Panel.
Visually inspect the Display Panel Cable's sheath. Do you see any outward appearance of damage? This means the tiny wires inside may be damaged.
Replace the Display Panel Cable.
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Keyboard Cover.
Unfasten the Keyboard, LEAVING the Keyboard Cable ATTACHED to the motherboard. Roll the Keyboard over, and lay it upside down on the Palm Rest Cover,
http://support.dell.com/support/edocs/systems/ins1420/en/SM/display.htm#wp1129771
[ NOTE*
Two Philips head screws at top of Keyboard. After removing, lift the top of the Keyboard up a little, slide it a LITTLE towards the Display Panel.
DO NOT lift it straight up at first.
There are 3 plastic tabs on the bottom of the Keyboard, that slide into the Palm Rest Cover. If you pick it straight up you will break those tabs off ]
In Removing the Display Assembly, note where number 1 points to.
This is the Display Panel Cable's connection, TO the motherboard.
Note where number 2 points to. Those cables going to the Mini-Card Antenna, HAVE to be reconnected, right back to the SAME terminals on the Mini-Card. Make a mark on the cables, and matching marks on the Mini-Card.
Use the instructions in Removing the Display Bezel.
Use the instructions in Removing the Display Panel.
View the last illustration in Removing the Display Panel.
Note how the Display Panel Cable attaches to the Display Panel, and Screen Inverter
Number 2 points to the connection at the back of the Display Panel
Number 6 points to the connection to the Screen Inverter
The Black connector that is not numbered at the bottom, is the motherboard connector of the Display Panel Cable.
This is a better view of the screen Inverter,
http://www.ebay.com/itm/Dell-Inspiron-1420-1421-LCD-Inverter-Backlight-Combo-/370274752470
Display Panel Cable checks out? Look at the screen Inverter. This small circuit board is located at the bottom of the Display Panel, and behind the Display Bezel. Closer look at link listed above.
Is the cable coming from the Display Panel Cable, plugged in tightly to it?
Does the screen Inverter look damaged?
Post back in a Comment, and we will go from there.
Regards,
joecoolvette
Jun 09, 2012 | Dell Inspiron 1420 Laptop
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
Inspiron 1420 unusual colored line at bottom screen
yeap..itz the monitor's vertical roll over problem..
better to contact ur system admin/vendor, if u aren't an expert..!!
Oct 28, 2009 | Computers & Internet
SP2208wfp monitor goes into sleep during videos
Assuming you are using Win-XP, go into control panel, Appearance and Themes and Choose a screensaver. There should be an option below the screensaver choice to adjust Power Saver settings.
Sep 19, 2009 | Dell 22" SP2208WFP Widescreen Flat Panel...
White Vertical Band on Screen
Hi...there,
It's seems you got a busted screen panel...
Dec 15, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell SP2208WFP Flat Panel Monitor flickers out and goes black.
Hi again,
Any luck with the Dell people?
A favor if I may, at your convenience, would appreciate if you can rate our Live Session as you see it fit.
Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 05, 2008 | Dell 21" M1110 .22DPI 1600x1200 *SUPER...
Split screen on a dell 1100 note book
Try with the FN + F8 keys, with a secondary monitor plugged in.
Nov 01, 2007 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
Alun Cox
