Question about Indesit W 123 Front Load Washer
How to remove filter on Indesit WIXE 127 front loading washing machine
How can I remove the filter, which i have found at the front of the machine, but it is reluctant to turn either way, the way it sits in the hole doesn't seem right it is not perfectly rounded to just unscrew seems to have two bits thats are not flush with it. Hope someone can understand what I am trying to say. Any help would be much appreciated. Thanks Karen
    Problem Solver:
  • 5 Answers
You will find there are something like coins trapped in the filter, stopping it turning, get some pliers & try turning it backwards & forwards to dislodge the blockage. If this doesn't work you may have to force the filter & buy anew one
Posted on Nov 03, 2008
My indesit WIXE 127 IS WORKING BUT MAKES ONE HELL OF A NOISE WHEN SPINNING
If it sounds like an aeroplane it's probably bearings u/s
Jun 19, 2013 | Washing Machines
Indesit wixe 127 door error
Most likely have to change the door lock and latch assembly.
Sep 04, 2012 | Washing Machines
Indestit wixe 127 is leaking water from under the machine and sound like an aeroplane when spinning ??
The only way you can find out where the leak is coming from is by removing the back and putting water in it. Using a torch try to see where it is leaking from. TBH its usually the door boot (the rubber seal around the inside of the door). As for the noise.... Open the door and take hold of the shiny part of the drum inside. (Just that bit). Try moving it up and down. If there is any play in it and it rocks a little that is your bearings going and can be an expensive repair. Hope that helps.
Oct 16, 2011 | Indesit W 123 Front Load Washer
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
Model WIXE 127 instruction manual I have lost the one provided with new machine
Go to -
WWW.INDESIT.CO.UK
In the menu on the left, click on--- Indesit user manuals.
Then in the search box, enter your model number, and download the instructions.
Please rate my solution to your query.
Thankyou.
Jan 15, 2010 | Indesit Washing Machines
Fault code F05 on an indesit washing machine WIXE 167.it not emptying the water
Locate and remove large black fastened to bottom of drum.
Hop[e this helps you.
Dec 28, 2009 | Washing Machines
Wixe 127 how do you get max spin 1200 on spin cycle can only get 800 down to off?
It can actually depend on the programme you have selected.
You have to select a programme that will accept a 1200 spin, as not all programmes do.
Hope this helps.
Dec 16, 2009 | Indesit Washing Machines
Fabric conditioner not going
Check the solenoid belongs to that tray.It may struck.
Jul 05, 2009 | Indesit WA 125 Front Load Washer
Manual for Indesit WIXE 127
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Apr 07, 2009 | Washing Machines
My indesit wixe 127, wont drain and is stuck on error code f05. what doi do?
i think there is a problem with low water level sensor
My 127 fill up with water and i have f-08 error code which is a high level water sensor faulty
Aug 11, 2008 | Indesit Washing Machines
Indesit W 123 Front Load Washer Logo
684 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
