Question about Sharp R-1480 Microwave Oven
Sharp Microwave/convection oven
We have a Sharp microwave/convection oven in our rv that when using the minute plus setting or setting any time from the keypad, it will not run longer than one minute before shutting down.
What would cause this?
Thanks.
We had the same problem, and the service technician quoted over $300 to fix it. My wife found this thread online (click on link below) and after following the advice here ours is now fixed for a total cost of under $40, and that included a new soldering iron (see below)!
http://www.fixya.com/support/t902145-sharp_r1870
The problem is either the damper motor or the damper switch. You can order both from Tritronics and ours shipped un less than a week. It is not possible to tell which it is without disassembling the microwave, so I ordered both. In our case it was the switch (one of the electrical contacts was black like it had burned out).
Read all the advice about discharging the capacitor; I would recommend downloading and printing out the service manual (especially page 18 which is an exploded parts diagram which helps you identify what is what (click on link below)
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
Page 14 is also useful because it gives you the part numbers to order from Tritronics. The two items you may need are 1-11 Damper switch and 1-22 Damper motor.
The space is rather tight, and you need to be very careful you don't cut your hand on the sharp (no pun intended) metal. It definitely helps to remove the long mounting bolts that runs through the space. Be very careful when disconnecting the electrical connections: the little metals tabs they use on the ends of the wires break very easily - hence the soldering iron. The most difficult piece is undoing the screw on the right hand side that secures the motor; it's just cramped and you need a very small/short phillips screwdriver to get to it. I would advise removing the switch first (it's secured by a couple of little metal tabs) because then the cam which drives the damper door will be able to drop free when you remove the motor. Finally, when installing the new motor, make sure that the tab on the cam wheel is correctly inserted into the little slot on the bottom of the damper door.
As I said above, read all the advice on the other thread and the general advice on working around microwaves on the http://www.microwavedisplay.com/ web site. It's all good stuff. Good luck!
Posted on Dec 23, 2008
I have a R-9H83 Sharp Carousel II Microwave Convection Oven that I have had for years and now when I use the convection to bake, it only will stay on for a few minutes and then just shut down. Any...
If you use a sensor function, the sensor may be obstructed, please clean the sides and top of your microwave with a dishcloth, warm water, and soap to dislodge any rough or stained spots.
If setting a timer, when setting to bake please pay close attention to the unit of measure so that you set it right, minutes vs. hours as you may leave the oven to do its business and return without noticing it did exactly what you told it to do but you had thought you entered a longer time.
Nov 21, 2013 | Sharp Microwave Ovens
This oven is fitted to my new (to me) rv. the convection bit is fine, but the microwave trips the 15A breaker. have changed the breaker, still trips.
Yes the breaker is to stop firs etc, you should NEVER EVER simply re-set a breaker without finding out WHY it tripped. I suspect your oven has developed a Short Circuit fault. Please DO NOT touch it while plugged in you risk electric shock. Please remove from power and get it looked at by a qualified person. Please ask for "Quote" before proceeding with any work. a lot of the time replacement is cheaper than repair.
Mar 19, 2010 | Sharp R-1874 Convection/Microwave Oven
Sylvania microwave convection oven overheats after
you need to remove the cover and after it operates and shuts down(CAREFULLY) feel the magnetron tube sides (BE EXTREMELY CAREFUL<HI_VOLTAGE ON TUBE FROM CAPACITOR) still, then if its not too warm there is a small temp sensor held by 2 screws on the side of the tube and they can go bad and shut off current to the tube,the tube will run warm, but should never run HOT,if its hot its defective
Oct 28, 2009 | Sharp R-353 Microwave Oven
On convection or convection/microwave it runs for
Here is a link to your manual that you can copy and paste in your internet address bar;
http://www.nodevice.com/manual/newmans/upsharp/R303CWPDF/get52699.html
or
www.curtisint.com/html/custservice/.../SUN_SMW5500_EN.PDF
Oct 10, 2009 | Sharp R-303CW Convection / Microwave Oven
I need a manual for Sharp Microwave/ Convection R7A85
You can download that here free.
Aug 30, 2009 | Sharp R-7A85 Microwave Oven
Convection oven stops every 5 minutes and won't continue
to trouble shoot hold the door securely shut for longer than 5 min to see if it runs longer if it does the you should replace the interlock devise
Dec 25, 2008 | Sharp R-930AK Convection/Microwave Oven
Sharp R-1480 Microwave Oven Logo
105 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
