Question about Cameras
Battery stuck in Nikon D80 - Cameras
  • Anonymous May 03, 2009
    Stupid Wolf Camera sold me a battery and the guy said it was for the Nikon D80 but was it? NO!!! it only had two contact points, and you know i just thought this was because it was the cheeper generic brand.  I go home charge the battery and put it in my camera, at first it would not go in, so i pushed it a little harder.  My camera did not signal that the battery was in, and i could not turn it on.  Worst of all the battery was compleatly stuck in my camera.  I tried to pull it out with paper clips but that did not work.  Now i have glued the flat end of a screw to the battery with JB Weld, hopefuly that will adhere itself enough so i will be able to pull on the screw and bring the battery with it.
cammedic
  • 667 Answers
SOURCE: Nikon D80 battery door
Here is the contact information for Nikon parts in the USA:
841 Apollo Street, Suite 100, El Segundo CA 90245
(310) 414-8107, (310) 322-6979
Posted on Feb 29, 2008
randy320sgi
  • 121 Answers
SOURCE: Battery stuck
Don't take the battery out of the case (you are talking about the dual battery that goes on the charger right? that's how it is, you'll damage it and risk damage to the camera. check the manual.
Posted on Dec 23, 2008
randy320sgi
  • 121 Answers
SOURCE: d80 shutter issue
contactjoni,
Your shutter will stick if it gets dirty or dust gets in the camera, a reputable camera shop can inspect the shutter, the sensor for dust & dirt and can clean it for you. If the battery is low while shooting the shutter can also stick on longer exposures.
randy320sgi
Posted on Jan 06, 2009
  • 508 Answers
SOURCE: Battery Door
http://www.bocaphoto.com/products/new/nikon/nikonacc.htm
GoodLuck!!!
Posted on Jun 24, 2009
amanagni
  • 184 Answers
SOURCE: i broke my nikon d90 battery door. searching
Dear i have a link better than for you.
in this link you could see the manual of your nikon battery door.
https://www.paypal.com/us/cgi-bin/webscr?cmd=_flow&SESSION=a7JqcrKsQQGVfav71QTTIc0JLuta7te9SDOjhDCCaISkL1Kh6V2nBJcZMaK&dispatch=50a222a57771920b6a3d7b606239e4d529b525e0b7e69bf0224adecfb0124e9b5eb2336391e7cbed125f6c5bdaf8a1cdeb9b6b1b7e42e65e
Posted on Feb 15, 2010
D80 will not turn on...battery fully charged
I would contact Nikon tech support at www.nikon.com. They may be able to give you some suggestions. It appears from what you said that the camera is not seeing the battery and that may indicate that your contacts in the battery compartment are dirty and need cleaning.
Jan 22, 2013 | Nikon D80 Digital Camera
Everything on control panel is flashing. Can't operate camera.
Hi Shirley,
It sounds like your camera's CPU is stuck in a loop. First, I'd remove and transfer any pictures on the SD card in a card reader connected to your computer, followed by formatting the card. Leave the SD card out of the D80. Set the power switch on the D80 to "off" and install a freshly charged battery. If it is still flashing, a "Full Reset" may help.
Nikon recommends that a full reset be done only under direction of Nikon staff. The procedure is outlined along with graphics on this page under "Full reset". I suggest calling Nikon support to see if they think this procedure (or maybe another that they have) will solve the problem.
Nikon Technical Support
8AM - 12AM (Eastern)
7 days a week
1-800-Nikon-US
1-800-645-6687
Jan 09, 2013 | Nikon D80 Body Only Digital Camera
I unplugged my Nikon D80 from the computer without clicking the safe to eject drive button and now it seems to be stuck in PC mode!
Try resetting the camera by removing the battery for 20 mins, then replace the battery and go to the Menu setting and set the Date and time.
May 27, 2012 | Nikon D80 Digital Camera with 18-55mm Lens
I broke my nikon d90 battery door. searching online, i found a battery door for d80. my question is - is the battery door for nikon d90 and d80 the same?
Feb 15, 2010 | Nikon D80 Body Only Digital Camera
Battery stuck
Nov 19, 2008 | Nikon D80 Digital Camera with 18-135mm...
D80 shutter is stuck
Followed the mirror lock procedure as outlined in the manual for cleaning the sensor. That solved the problem.
Nov 12, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80, setting not remembered
I'm thinking it's an internal problem - probably needs fixing at Nikon. I can't think what else you can do.
Sep 23, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 SD Card slot problem
Is it slightly thicker on the contact end, Or is something stuck on the flat corner? try getting a needle and picking out any plastic that could be stuck there. Is the card under warranty
Sep 09, 2008 | Nikon D80 Digital Camera with 18-135mm...
D80 shutter issue
contactjoni,
randy320sgi
Jun 28, 2008 | Nikon D80 Digital Camera with 18-200mm...
Feb 29, 2008 | Nikon D80 Body Only Digital Camera
Cameras Logo
181 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
