Question about KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher
Dishwasher leaks water
When you start the dishwasher and when it starts the wash cycle water runs out at the bottom of the door.
  • Anonymous Mar 22, 2014
    Water when done
  • 734 Answers
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Posted on Dec 12, 2008
  • fondren958 Jul 30, 2011
    I have a Kenmore Model 665.15835793 (same as Whirlpool Model 665.*** I had the same leak and change the door seal which was no help. It would leak from the bottom left side of door. I fixed mine today by removing the inner panel of the door, by removing the 6 to 8 torx screws. and then removing the Vent from the top left of the door. At this point you can just lift the inner door out so it will easy to work on. My vent was clogged up with what looked to be mold,which prevented the water from returning to the main washer and was being flooded and sending the water down the inside of the door.. I cleaned and reinstalled the vent assembly,which fixed the problem. After removing the inner panel you can pull out on the vent cover from the bottom and then you will see two small tabs that need to be depressed, which will release the back portion of the vent. If yours is clogged up, this is probably your solution. Just clean it up good and put it back together. Doesn't cost anything to fix, just about an hours work. I have been searching for a fix for several weeks in many forums, and no one ever mentioned the vent being clogged up. I hope this helps someone, and if it does please put on your forums to help others. That's what I am doing now. Good luck
I Have Kenmore Elite that is leaking at the bottom of the door after it starts the wash cylce. Could this be from it overfilling and could this be caused by a worn float switch?
Posted on Jan 14, 2009
Why is my dishwasher leaking soap foam from the lower left area of the door?
A leaking dishwasher can be caused by excessive soapsuds. Excessive soapsuds are the most common reason dishwashers leak. Excessive soapsuds will cause dishwashers to leak from the door. Good dishwasher detergent will have no more than half inch of suds on top of the water. So any time your dishwasher is leaking from the door open the door, if there is more than a half inch of suds your problem is in your soap. One drop of hand soap, hand dish washing soap, or any other soap will cause dishwashers to leak. Now, I am not suggesting that you intentionally put this soap in the dishwasher because if you did the soapsuds would be from top-to-bottom of your dishwasher. Now if there are a lot of suds you can fix it by pouring vinegar or cold water into the dishwasher and running it, this will kill the subs.
Jul 08, 2013 | Computers & Internet
I have a kitchenaid dishwasher model KUDMOITJBLO installed as new unit in Oct. 2002 in a new home. Current problem is water coming from front door, bottom as unit starts wash cycle after filling. Leak is...
Hello, Thank You for using FixYa. I will be helping you today.I would start by removing the outer door panel remove the screws around the inner door to do this.Then close the door and start a cycle. Sometimes you can see obvious signs of leaks just by removing the panel too. But if not let it run and see if you see water leaking anywhere. You will see water in the bottom corners its normal. If water is splashing over those corners the check the lower spray arm gor damage or cracks it can cause this problem also make sure the screws under the spray arm are tight. also check the upper arm.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | KitchenAid 24 in. KUDM01TJ - Multiple...
Fdb1050rec1 frigidaire dishwasher door leak
I think you most likely have a basin Float water level sensor that is no working correctly, the door seal is not water proof, if the water level gets over the lip of the basin it will leak on the floor.
May 01, 2017 | Frigidaire Dishwashers
Dishwasher slowly fills up with water after wash cycle completed
Inside the bottom of the dishwasher under the lower rack to the side there is a float that regulates water level. jiggle it up and down a few times , it will be OK. Vitally
May 12, 2009 | Dishwashers
Dishwasher is leaking and backing up with water
Sounds like the door gasket is leaking allowing water to come out
Apr 29, 2009 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwasher sounds like it is running, but no water is circulating
also, if water has leaked into the tray below the dishwasher, it won't'll have ti take off the bottome panel to see
Dec 29, 2008 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Open Questions:
See all KitchenAid 24 in. KUDI01ILBS Stainless Steel Questions
KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher Logo
753 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
