Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Bottom half/ color separation and distortion of image/top half normal.
How do I fix the problem
  • 21 Answers
Sounds like you need to go into the setup and do convergence. Be careful if you place any speakers or devices that have magnets in them such as a vaccuum cleaner. Even just moving the television can make the convergence go out temporarily. There is a auto circuit that should take care of this if it is moved.
If you have no magnets etc close, then I would check the convergence.
Posted on Nov 03, 2008
LG60PC1D Flat Screen
You need a lower Y-buffer board
Jun 18, 2013 | Televison & Video
Samsung LE40R7 colors got distorted (they have become electric similar to this example http://vickismithartist.com/images/paintings/azofadifferentcolor2009.png ). Next day they were back to normal, but...
Distorted picture issues are almost always caused by a bad tcon board, match the part number on the board not the model number if you order a new one
Nov 10, 2017 | Samsung Televison & Video
Colours are getting out of sync, picture distortion
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 29, 2009 | Mitsubishi WS-55908 55" Rear Projection...
Red and green have separated. is this fixable?
yes this can be fixed
it is the convergence IC's that controls each color image alignment ,also other components(resistors , diodes , capacitors , ect..) in circuit with these convergence IC's(STK's) also need testing to see what other component has also failed or needs replacing.
Mar 19, 2009 | Zenith R57W46 57" Rear Projection...
PHILIPS 60PW936317 - COLORS GOT DISTORTED AS I WAS WATCHING TV
Your convergence chips and convergence resistors are going bad. When they fail the screen colors will look distorted/3d looking.  Another symptom is one or more colors can't be converged using the convergence menu. You can purchase the parts over the internet. Just make sure you get Sanyo brand convergence chips and the correct flame proof resistors. You can also check the site www.TvRepairKits.com. They are working on a complete kit for this model.
Nov 12, 2008 | Philips 60PP9202 60" Rear Projection...
Color distortion for Sony KPR-46cx35
there maybe cold solder around the chroma section, or in the CRT board....
Aug 11, 2008 | Televison & Video
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Picture and color distortion
I am having the same problem hopefully some one answers us.
It's a Blue Convergence issue but how to fix it I am still waiting.
Apr 13, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Double image
Yes,it can be fixed...most likely the problem requires the
convergence IC's to be replaced....You can DIY if you are
mechanically sharp and able to solder well....Part(s) come in a kit for your 43UWX10B....................# X 480293........T.
Mar 30, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Picture separated on 1/2 of screen
This sounds like a convergence problem. This is a common problem that is usually fixed 98% of the time by re-placing the STK392-020 ic or STK392-110, and check the fuse devices on the covergence PCB. I'm sure the actual parts numbers depend on the peticular brand. Good Luck!
Nov 09, 2006 | Toshiba TP43H95 43" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
60 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
