Question about Philips Magnavox 27MS343S 27" TV
Picture Stretched I have a Magnavox TV Model Number 27MS343S where the picture stretched from top to bottom. To solve this problem I beleve I have to get into the Service Mode. Please solve and notify me ASAP. Send to trinimil@gmail.com
5 Suggested Answers
  • 87 Answers
SOURCE: Philips TV showing horizontal lines model 27pt6441/37
You likely have an elevtrlytic capacitor bad on the B+ line to the vertical ouput ic. If you continue to use the set like this it is likely the vertical ouput ic will fail.
Posted on Jun 26, 2007
  • 18 Answers
SOURCE: need to degauss a magnavox tv
Why do you think it needs to be degaused? What are the symptoms?
Posted on Aug 19, 2007
dumbtrucker
  • 102 Answers
SOURCE: magnavox 27ms343s tv won't turn on manually or with remote, help
If you are comfortable with tool sthere is a fuse inside the unit right where the plug goes in. I would check this first. Caution unplug it first VERY high voltage inside 30,000 volts!!!
Posted on Mar 24, 2009
  • 476 Answers
SOURCE: TV is 1995 Model 25TRC1-0101 Magnavox. Seems to
The tv has been accidentally set for "demo mode". Press the volume up and volume down buttons in front of the TV at the same time for about 5 to 10 seconds untill the demo disappears or sometimes the TV will turn off. You should regain control of the TV after this.
Posted on Jul 20, 2010
Testimonial: "Thanks so Much! Worked like a charm. Would never have figured this one out. Appreciate You."
Philips Magnavox 27MS343S 27" TV picture stretched or zoomed !
Take of the back and there is buttons inside, try turning them.
Nov 25, 2013 | Philips Magnavox 27MS343S 27" TV
Hello! I have an Olevia 232 T12 LCD HDTV and I am having a problem with picture distortion. In the center of the screen, the picture is fine, but at the left and right hand sides, it looks as though the...
Hello.
It does not look like there is something wrong with electronics in your TV. Most likely settings for picture are got messed up. It could be TV settings or source (cable box, etc. settings).
Using remote control of your TV find picture settings in menu and make sure it set to "standard" instead of "zoom", "stretch", "wide" etc. You might need to do the same with cable/satellite box menu. Some devices have button "picture" or "format" on remote control for this purpose.
You can also connect DVD player first and see if picture is stretched as well to determine if it is TV settings are wrong or it is outside of TV set.
Regards.
Russ.
Dec 01, 2010 | Televison & Video
Picture is stretched on top and compressed on bottom
the problem of your tv is in the vertical section,you need to replace the capasitor in vertical section .
Feb 18, 2009 | Konka FL2799U TV
Can't read stuff at bottom of screen
it is possible the picture format is set to stretched. look for a button on the remote that can do this. it could also be the signal. try looking at a different channel that has lettering along the top and bottom and determine if the entire picture looks like it needs to be moved up. if after all this you can still determine that the picture is misaligned post the model number and i can help you move it up.
Feb 05, 2009 | Sylvania Televison & Video
TV Screen is stretched beyond picture tube
sorry but that set has outlived it's life expectancy already .only a repair shop can give you any idea what might be wrong
Nov 05, 2017 | Televison & Video
The picture on my Daewoo DTQ-25S3FC is stretched
bad electrolytic capacitors vertical circuit. need tech.  not worth repair. guess100.00   not easy repair.
Dec 03, 2008 | Daewoo DTQ-25S3FC 25" TV
Picture is stretched on top and bottom of screen
you have a vertical linearity problem. change the vertical output and components.you need a qualified tv technician to solve this problem
Aug 15, 2008 | Emerson EWF2703 27" TV
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
32" rca picture stretched
Before you fool around with this, it may be under warranty. Check that first. Second, does the picture stretch in both directions or just vertically? If just vertically is it more pronounced at the top?
Thanks,
Dan
Apr 03, 2008 | RCA 32V420T 32" TV
Magnavox 51MP6200D/37
The conversion board needs replaced.
Dec 11, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
18 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
