Question about Protron PD-DVR100 DVD Recorder
Cannot see menu
I tried holding the enter button when first turning it on. I see nothing but a split white and black screen that seems to roll up quickly. Thanks for your help.
Try pressing the P Scan button on the remote. It worked for me.
Posted on Nov 04, 2008
Toshiba lap top - satellite - when i turn it on it brings up a black screen with red writing - saying TOSHIBA and under that it says press F2 for boot selection - pressing f2 does nothing - if i hold
try pressing the F2 key during the boot process to enter set up (bios)
using the arrow keys navigate to advanced bios features press enter make sure its set to boot from your hard drive
press F10 to save to cmos restart
hope the helps
Oct 06, 2012 | Toshiba Satellite Computers & Internet
Viewpad turns on, the lock screen is able to be opened, but to a black screen. Can't access any of the four functions on the right side. Although I get a black screen, the white strip at the top...
Hi walthopkins,
Can you please describe your problem in detail ?
Try pressing different buttons simultaneously in a combination and you would come to know that which is the relevant combination for unlocking the functions.
Hope this helps ....:)
Sep 06, 2011 | ViewSonic ViewPad 7 Multitouch tablet
My screen is white i hold da sleep an nothing
Try holding both the home button and the power button for 10 seconds. This should hard-stop the phone, and the screen should go black (powered off)
Wait 5 seconds after it's off, and press the power button for 2 seconds to turn it back on.
Jul 19, 2009 | Apple iPhone 3G Black Smartphone
Screen changes colors only
Hold the Vol+ Vol- buttons down and turn on the power switch in the back of the unit.
The screen should turn blue and some square in the middle of it.
The noisy square is actually the bios being reset.
Once the unit turns itself off, you can turn it back as usual.
Note: Some of these units require a 3 button reset.
In that case hold Vol+ Vol- and Menu at the same time while you turn the power switch on in the back of the set.
I hope it was helpful.
Jul 07, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Wuz n menu settings, hit wrong button, now only hve rolling pix!
you pressed the color system format button/settings.on the remote press the P/N which means pal/secam and ntsc.press it several times or until you get a steady picture.when its black and white then you can press the set-up or menu button to correct your settings.
May 18, 2009 | Cyberhome CH-DVD 300 DVD Player
Getting message: "VGA mode not support"
Shut the computer off, hold the power button for five seconds.
Once it's off, turn it back on and tap the F8 button until you see a black and white safe mode menu. Use your arrow key to select Last Known Good Configuration and then press enter.
This should get you back to your previous settings.
If it doesn't work simply comment back here and let me know how far you got.
Chris
May 14, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Side BY Side Picture On TV Black And White
Try holding the stop button and the DVD dubbing button at the same time and waiting about 3 seconds. I had to do this twice, but it solved my problem.
Feb 27, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
How to turn off burn-in mode if botton on Monitor
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
Oct 07, 2008 | Sceptre DCL9a
I get a double black-and-white image when the TV is running through the VCR
I had this same problem once. Go on your dvd menu and go to settings and hit "reset default settings". That worked for me. Hope this helps.
Aug 31, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
OSD Menu won't turn off
Known issue -- can get a replacement if still under warranty. The planar rma techs are really really nice.
May 13, 2007 | Planar PE170 White (Black, White) 17 in....
Protron PD-DVR100 DVD Recorder Logo
59 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
