Question about Frigidaire GLER642A Electric Dryer
Fridgidaire dryer A high shrill noise when dryer starts. Stops after about 10 minutes
  • nbarstad53 Nov 28, 2008
    my dryer makes a shrill noise at the beginning and ending of the drying cycle. does the belt need to be tightened?
  • Anonymous Mar 31, 2014
    MODEL# FASE7073LAO
    Sergeant:
  • 291 Answers
In dryers, the small clothes can get caught in one of the drum seals and make a scrapping noise, ( remove power, grab a flash light and have a peek inside through the door opening ) or the cloth can actually pass through one of the heating duct holes at the back of the drum and touch something electrical like the heating element, thermostats and so the noise comming.
Posted on Nov 23, 2008
My fridgidaire dryer has begun making a howling noise that turns into a grinding noise after about ten minutes of use.. have back top and front off and am running it now.. Its comming from the motor
If you are sure the noise is from the motor and you have the belt off and still makes the noise then replace the motor it has a worn shaft bushing..
Sep 29, 2016 | Dryers
Shutting down power on my fridgidaire 2008 dryer that stops and lights start flashing
without make/model we have a real hard time looking for a solution
Mar 22, 2015 | Dryers
My dryer makes a really shrill sound when drying. Could it be a bearing going bad?
Hi jaglassburn
Yes your noise is quite possibly a bearing.
Go to the following webpage for parts and a breakdown schematic for your dryer.
Please take time to rate me
Bud
http://www.appliancepartspros.com/search.aspx?model=gleq2152es
Oct 13, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Starts loud getting louder and after about 10 or 15 minutes stops. will start again after cools down
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Oct 18, 2010 | Crosley Dryers
My Whirlpool Gold dryer makes a high-pitched squealing noise for about 5 minutes when first turned on, then stops and dryer continues cycle. The noise doesn't sound like metal on metal but more like a...
CHECK BELT,TENCHEN ARM (KEEPS BELT SNUG),ALSO ROLLER WHEELS...
SOMETHING IS GOING BAD BUT ONCE IT WARMS UP IT STOPS MAKING NOISE.
YOU NEED TO FIND THE PROBLEM BEFORE IT BREAK DOWN???
LATER FREDDY
Feb 11, 2010 | Whirlpool Dryers
Dryer stops after about 10 minutes. can be re-started but stops again and again. Thermostat was replaced about two months ago.
the motor could be overheating,you might need a clean out on the dryer?vac out the inside where the motor is,clean out the duct where the lint filter slides into and then go outside and make sure the air is blowing out with force,i've been finding alot of cages outside that stop animals from crawling into the vent line but the cage also catches lint and stops the air flow,if so take the cage off or clean it every month,if you have a long run blow out the vent line with a leaf blower,you could also have a bad motor
Jan 19, 2010 | Dryers
Dryer starts with heat. After 10-15 minutes, when dryer calls for more heat, here a metal clicking noise, flame does not ignite. When it's clicking, I can look down the back from the top and see a glow....
Your gas valve coils are defective. Part #694539 and 694540 are required. Once the coils get hot they collapse internally and the gas valve shuts off. This is a common problem when valve coils get weak from use.
Nov 09, 2009 | Whirlpool LGQ9857L Gas Dryer
Fridgidaire dryer stops with code PF
pf isd power failure
with so many differant possiblities
it would be hard to nail it down here
but i would check my outlet chord and termianl post
where the chord connects to the dryer
one or more of the connections could be loose
Jul 01, 2009 | Frigidaire Electric Dryer
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Frigidaire GLER642A Electric Dryer Logo
126 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
