Question about Canon PowerShot A720 IS Digital Camera
Cannot insert the memory card - push in, won't seat, springy feel
Cannot insert the memory card. I can push it in, but it won't seat. I don't see anything stuck in the slot.
    Problem Solver:
  • 4 Answers
Make sure that you insert the SD card in the correct orientation. If not, it will not lock into place. The SD card is push in to insert and push again to eject.
There is a small diagram showing the correct way to insert the card just below the left hand side of the slot.
Doug
Posted on Nov 08, 2008
My jaguar s type the steering column is lock how to unlock
Provided you have the correct ignition key. Fully insert the key into the ignition, then with your other hand pull down or push upward on the steering wheel, one way it will feel solid and the other way it will have a slight give (a spring like feel) push or pull into this springy feel and as you do this you should be able to turn your ignition on. Sounds like it's been on a hard lock when you turned it off!
Oct 14, 2017 | Jaguar Cars & Trucks
Hi, I tried to install this Transcend micro sdhc 8 GB memory card. I would have read the installation instructions, but my bionic eyes couldn't read the stupid instructions. So I inserted it properly...
You can only format a microSD card when it is unmounted. Unmounting a microSD card-To unmount a microSD card, follow the instructions below: [Menu] >Settings&tools>Press Ok key >SD card & phone storage(card memory)>Unmount SD card Formatting a microSD card>[Menu]>Settings&Tools>SD card & phone storage(card memory)>Format SD card.
Aug 23, 2011 | Cell Phones
I bought an sd card for my kodak camera to store more pictures and when i insert card it says it needs to be formatted how do i do this
Insert the memory card into your camera, then push down on the card until you hear a click. Verify that the memory card is firmly seated in your camera.
  1. Turn on your camera.
  2. Move the pictures/videos from the memory card to your computer desktop or other location
  3. Press the Menu button, then go to the Setup Menu.
  4. Scroll up or down to the Format option, then press the OK button.
  5. Follow the prompts to format the memory card
  6. For more information, see your camera User Guide ->http://www.kodak.com/go/manuals
Apr 14, 2011 | Kodak Cameras
How to insert sandisk in laptop?
face up. gently push till it clicks. it should only fit in the slot one way. (make sure the slot is the same width as the card. Do not use the Larger slots. Typically you insert (gold) contacts down, and in first. to remove, push till you feel click, then pull. Be aware that some new micro SD cards have formats that older,( 2 years ago) laptops will not recognize. I think they are marked HD. or HC. Cards. Most of my devices Wont recognize this new format. Camera included. Cheers
Aug 24, 2010 | SanDisk 2GB microSD Memory Card
How do you insert the memory card into the reader? I am afraid to just shove it in. I have a Sony MemoryStickPRODuo.
One corner of the memory-card is "bevelled", to prevent it from being _wrongly_ inserted, i.e., if it does not go "far" into the slot, then flip it over, and push it in until you feel "resistance".
Aug 22, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
The camera works fine without a card in, but when the memory card is put in it doesnt. i changed the card and no difference. PLEEASE HELP
The cause and solution may include one of the following:
  1. The card may not be certified SD. Please purchase a certified SD memory card. For example: Sandisk, Toshiba, Panasonic, etc.
  2. The card may be corrupt. Reformat the memory card.
    CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
  3. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
Feb 13, 2010 | Casio Exilim EX-S500 Digital Camera
I have a macbook and i dont see anywhere to insert a memory chip ?
The memory cards are inserted into 2 slots that can be accessed by removing the battery, and removing the 3 screws from the L-shaped metal cover. The screws won't fall out of the cover, so no worries about losing them. Once the cover is off, there are 2 slots with release levers... carefully push the lever and the existing memory card will release. Insert in same manner. If no cards, simply insert the card until the lever seats.
Dec 30, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Memory card won't stay in
dear dave how did you insert the memory ? it will only work in one way , the other way the memory card may be seated but infact it is not fully seated and won't want to goe further , Take out the memory card turn it around so that the label side is facing the other way and try to see if ti will fit in that way you wont have to push it hard just once light and than it will have to be in place
Mar 15, 2008 | Nikon COOLPIX S200 Digital Camera
Camera doesnt recognize a Secure Digitalor MultiMediamemory card?
The cause and solution may include one of the following: The card may not be certified SD or MMC. Purchase a certified SD or MMC memory card. The card may be corrupt. Reformat the memory card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Canon PowerShot A720 IS Digital Camera Logo
198 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
