Question about X-Micro Technology EVA MP3 Player
One side mono hearing
I can only hear one side of the record on my mp3 player. It doesnt play stereo.
  • djclemens Dec 05, 2007
    plays the first half of every song in stereo and then it jumps to mono on one side of my headset (earbuds). If I forward to the next song it resests to stereo again. Over and over the same problem happens on every song.
    Thanks for any assistance,
    Doug
  • 22 Answers
Maybe it's a headphone problem? buy a cheap set of $0.99 headphones, and see if that cures your problem, before buying anything else.
Posted on Aug 08, 2007
You have to sold the jack to the board again, probably one of the conectors lose contact. good luck
Posted on Apr 18, 2007
I have a Magnavox stereo console: Astrosonic Series. The record player was playing fine until a month ago. The volume is now so low you can hardly hear the record playing
Since the volume of the radio seems to be fine it is doubtful that the amplifier is malfunctioning. I will check the stylus to see that it's fully seated and examine the wires in the tonearm that connect to the cartridge. If they seem okay then I suspect the cartridge may be bad
Mar 02, 2015 | Audio Players & Recorders
When i plug in my mp3 into the phonic system it doesnt play certain notes of songs and there is no bass
It sounds like the cables you are using, or the way you have it wired into the system are not correct. If you are using the stereo channels on the mixer, then the system also needs to be wired in stereo to the proper amp and speakers. Otherwise you hear the left or right side of the stereo mix, and not all of the music correctly.
Another problem may be the kind of cables you are using to wire the MP3 player to the mixer with. If you are using a 1/8" adapter to the MP3 player, make sure it is a STEREO 1/8" adapter, and that both left and right channels are plugged into the mixer, preferably on the first two inputs to test and see that both channels are indeed coming through. Then you may move them to a stereo channel. Again, make sure that the system is wire in stereo in order to hear both sides, Good Luck
Mar 23, 2011 | Phonic Am240d Compact Audio Mixer W/...
I PLUGGED THE GUITAR INTO THE GUITAR INPUT AND PLUGGED ANOTHER JACK INTO THE SEND UNIT TO MY AMPLIFIER BUT CAN'T HEAR ANY SOUND EVEN THOUGH I GET A READING THAT SHOWS SOUND IS HAPPENING. THE OL LIGHT IS...
try this: plug a stereo headphone into send & check if you get something on one side of the headphones (should be left side) if yes check the cable you use, it's possible that a mono plug (as used for guitars) is disabling the send output, using a stereo plug & adaptors may work (especially if you get the sound in the right side of you headphones check also the manual you may find a description how to connect/insert a guitar effect when recording or live mix
Nov 12, 2010 | Tascam Dp-02cf Digital 8-track Recorder
When I record and listen to playback, I only hear the left side.
This is normal for recording. Even professionals do the same. What you need is to set your input to mono(either hardware or software), or explore your software look for effects like STEREO to MONO with some delay which I prefer for my recording. I did have a good result. Good Luck
Mar 07, 2010 | M-Audio M AUDIO MOBILE PRE - USB MIC...
Recording vs880ex - can't hear the headphones in stereo
what you do is treat her like a lady wants to be treated.
touch it
when you input make sure your only putting one device in the hole.
kiss it after your done
Are you recording in mono?
That could be the problem
Jul 21, 2009 | Computers & Internet
After i record my voice with the microphone, it comes out 1 side
The Samson C01U records in mono, not stereo. This is why you hear sound coming only out of one (the left) channel.
Mar 29, 2009 | Samson C01U Consumer Microphone
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
bd.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
No good sound quality
ARE YOU RECORDING IN STEREO OR MONO
Sep 01, 2008 | Samson C01U - USB Studio Condenser...
Playback only on left speaker
The quick, easy solution is to change your microphone to mono recording. In the attached YouTube clip, I'll show you how to do that.
The short and simple is to go to your Mac HD -> Applications -> Utilities -> Audio MIDI Setup. Select your C01U USB device, and set it to 1ch 16bit. This will set the microphone to record in mono, equally over both speakers.
Nov 26, 2007 | Samson C01U Consumer Microphone
X-Micro Technology EVA MP3 Player Logo
136 people viewed this question
Top X-Micro Technology Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a X-Micro Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
