Murphy turntable tt-182w
Hi i have just purchased this murphy turntable, when i place the needle on the record the needle scoots over the record, and wont play correctly,
  • Anonymous Dec 31, 2008
    Same as the the previous submitter - Styles jumps 3-4 ad sometimes 5 times the song disc !!!!! - What is wrong ????
3 Suggested Answers
arthurroger
  • 170 Answers
SOURCE: turntable arm slides across record, Am. D.J.-1500
See what type of cartridge is installed in the arm. Manufacturers use common cartridges in turntables, such as Stanton, Shure etc. Detach the head shell from the arm (it usually slips right off via a locking ring and four-pin mini plug) Look for the manufacturer and model number on the cartridge. No need to remove it from the head shell. On most modern cartridges, the stylus (as they are called, rather than the needle) simply slips off and on. No need to remove the entire cartridge (via screws) and re-align it. In fact, many DJs bring a set spare cartridges and styli on a gig, already mounted in head shells, and simply interchange them as needed. When you have the make and model of the cartridge, go to Radio Shack or use their website to order a new one...or  two. Or go to Google and enter "phono stylus" as your search term. You will find reasonably priced styli for nearly every cartridge imaginable. I operate 50 year-old turntables and am able to find replacement cartridges and styli on line. Ebay also has a number of listings, by make and model of the cartridge. When the new stylus arrives, observe how easily the old one comes out of the cartridge- usually pull and slide - and slide the new one in. Re-insert the head shell on the arm, tighten the locking ring, and you're good to spin!
Posted on Jan 08, 2009
Vinylking
  • 3 Answers
SOURCE: JVC - problem. The turntable does not move,
Most modern day turntables are semi-automatic. You move the tonearm from the rest post
over to the record and the platter will start turning. There is a small microswitch inside
either below the arm base or near. There should be a flat bar connected to the base of the arm
and this will actuate the microswitch. The switch is wired in series to the rotation motor.
Solution: 1. Obviously verify the belt is on. Take off the rubber mat and rotate the platter.
The rotation motor is on the left and it has a small brass spindle. The belt should
be visable through the holes in the platter. If not pull the platter gently up, there will
be some resistance. The belt wraps around a smaller inner ring on the underside
of the platter and the rotation motor spindle. If it is degraded it will be stuck to the
platter or fall apart. Generally there 3 common sizes. ( 21.4 / 23.6 / 25 inch) they
readily available on E-Bay, search term "turntable belt".
2. Obviously check power.
3. Check the microswitch, it should "click", verify with ohm meter.
4. Some turntables have a "cut" or stop function. The arm must return first to rest before
starting again, again the microswitch is the trigger.
Posted on May 17, 2009
Marantz tt 530 turntable
The needle skipping is caused by (A) a worn stylus. (B) not enough pressure. Which is solved by adjusting the weight on the end of the arm. It can only really be solved by trial and error. You increase the weight slightly, then play the record. You keep doing this till the record stays in the grooves but doesn't make a rumble sound. If it starts to rumble reduce the weight.
Aug 20, 2013 | Audio Players & Recorders
Replace the needle on Bush RPA1
Take the whole unit, open the window, toss the unit out the window and replace with something decent as this TT is a pile of junk and is probably ruining your records. Problem solved.
Nov 28, 2012 | Bush RPA 1 Turntable
The record keeps sticking in same place iv adjusted the hight weight and anti skate i know its not the carts or needles cos iv swapped those its been suggested to me tht the arm is damaged or bent even ???
Hi, have you tried manually moving the tonearm (with tt off) from its stating position across the platter to the centre? If you do this and find you get resistance at a certain point then there is damage to the tone arm base or bearings. Is the tonearm lifter going down completely?
Apr 09, 2011 | Technics SL-1200MK2 Turntable
The arm scoots across the record.
REPLACE STILUS(NEEDLE). MIGHT BE TOO OLD AND DULL OR, BROKEN.
GOOD LUCK!
RADIO SHACK MIGHT HAVE SOME LEFT TO ORDER.
Feb 22, 2010 | Audio Players & Recorders
My turntable starts in the middle of the record only after me helping it start spinning.
you need a flat key that slots in where the rubber grommit is on the turntable platform. Remove the rubber stopper, use a flat head screwdriver into the slot inside the hole, out an old record on the turntable, and try the play button to see where the arm now lands ( dont forget to put the stylus protector on to prevent needle damage! ) and then keep making small adjustments till the arm starts at the beginning of the record. I actually have an original sony flat key should you want it? but to be honest a long shaft screwdriver is perfectly adequate for the task? email me at lesliemurphy_964@msn.com if you want the key though?
Les Murphy
Aug 15, 2009 | Sony PS-LX250H Turntable
Looking for a needle for a turntable
Your source for all your antique radio, record player, turntable and phonograph needs!
Record Player Needles
Welcome to our record player needles and turntable stylus page! We hope you find this page to be very friendly and useful in locating a replacement record player needle or stylus for your phonograph. Use the picture charts of the record needles, and the information request form to help you identify which record player needle or stylus you need.
When it comes to stocking needles, we carry and stock more than just the "top brands", "most often needed" or "most popular" like other places you'll find on the web. Our inventory is very extensive and broad. Ranging from sophisticated high end types to plain straight steel needles for antique crank or wind up models.
May 14, 2009 | RCA Lawton 841.662 Turntable
Needle Skates
If you're a real DJ then the Technics is the best TT to scratch on. Don't listen to that fool about not scratching, lol. Your tone arm could be the problem. Have it checked out. I repair TT's
Mar 18, 2009 | Technics SL-1210 Turntable
NUMARK TT 1625
Any of the following cartridges will fit your turntables:
CARTRIDGES @ 1200s.com
I don't suggest using the originals that came with the turntables, as they aren't of the greatest quality. For a small investment (about $50), you can get some better quality cartridges/needles.
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
www.REPAIRNYC.com
Apr 22, 2008 | Numark BATTLE PAK v.4 Turntable
Marantz TT221 turntable anti-skating problem
Hi, sounds more like tje stylus tip is gone and therefore the needle isn't holding to the grooves rather than a tracking weight or anti skate problem. Styluscity@gmail.com
Mar 27, 2008 | Marantz Reference TT-15S1 Turntable
244 people viewed this question
 Grubhead
Grubhead
