Sharper Image Weatherproof Atomic Clock Model OQ007
When I replaced the batteries, the clock reset with the wrong time zone. Now the time is an hour earlier than ours. I no longer have the manual & do not know how to correct this problem. I thought it would be right when Daylight Savings Time started, but it automatically set itself an hour earlier. I have punched the Mode button, but it doesn't give me the option to select a different time zone. The up & down buttons do not seem to do antyhing. Any help would be appreciated.
  • 2 more comments
  • dchristianid Nov 11, 2008
    Solved my problem exactly! Thank you for your help.
  • rhrumford Mar 09, 2009
    I am not able to set the time for central Us time and have the clock automatically reset to the correct time.
  • glascowolfor Mar 19, 2009
    I have repeatedly set the time for my time zone however when the device cycles overnight it automatically resets the clock one hour ahead (CST). Any help is much appreciated.
  • Anonymous Mar 24, 2014
    How do I reset my time zone for Brookstone smart set clock model number a C101A
  • 3 Answers
Press and hold the "Mode" button for a few seconds until the display flashes. The briefly press the Mode button to cycle through each setting. When you get to the "Zone" setting, press the up button to advance the time zone. Press the mode button repeatedly to finish cycling through the settings.
Done.
Posted on Nov 07, 2008
What is the zone number for the Central Time Zone?
How do I secure a user manuel for a OQ007 atomic clock
Posted on Mar 10, 2009
How do I change the time zone on the Sharper Image Big Digit Atomic Clock Model SN001?
To access TurboTax, you need to have a valid username and password for the system. Now, different people use different versions of the device. Turbotax Support Number Some users opt for the online version or browser based version, while some users opt for the simple desktop version.
Oct 22, 2016 | Sharper Image Audio Players & Recorders
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
Cannot get my atomic clock to reset to proper time
Make sure that it has fresh batteries, set it for the correct time zone, set the DST switch to ON (unless your time zone does not use DST), then place the clock on a solid surface, outside if possible, so that the face of the clock is pointed roughly towards Fort Collins, Colorado. It should reset in a couple of hours - or less.
Aug 07, 2010 | SkyScan 86709 Atomic Wall Clock
Oregon Scientific Model 323a--Atomic clock...the atomic clock keeps setting itself to one hour behind what time it actually is in my time zone...I mannually re-set the clock to the correct time...but when...
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
Mar 21, 2010 | Oregon Scientific RM323A Travel Alarm...
Time setting
The clock will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
Jan 19, 2010 | Sharper Image Wireless Caller ID with...
How do I adjust the time zone. I set the clock and in a few days it is 3 hours earlier Pacific Time and I am in N. It is a skyscan atomic clock CN6 V00U. Thank you, Kent
Take out the batteries, let stand for about 30 sec replace batteries and reset clock, when ask if you want to auto set daylight time "yes", and continue.
Oct 16, 2009 | SkyScan 86709 Atomic Wall Clock
I need to change time zone on atomic clock to EST
I need help setting the time zone on the sharp atomic clock model #spc364.
Apr 18, 2009 | Bose Wave Radio
Need Manual or how to use this!
Press reset button in battery case make sure your plug in also
Press Wave for 2 seconds press + or - to set zone
Press wave set year + or-
Press wave set date " "
Press wave set time to 24 hr real time + or -.
Press wave set to 12 by + or-and it will set temp F
Mar 04, 2009 | Audio Players & Recorders
Sharper Image Projection US Atomic Alarm Clock (model number OQ311)
try looking up the manual on the model number you might find it online. I have the maual for this model.
Jun 10, 2008 | Audio Players & Recorders
2,022 people viewed this question
 Grubhead
Grubhead
