Whirlpool washer mod lbr4121jq1
My washer is making a high pitched noise during to spin cycle also during the washing- when ever the drum is turning. what can it be/
thanks, micki
catriver
  • 878 Answers
SOURCE: washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
Posted on Dec 01, 2006
SOURCE: Squeak upon spinning
I fixed my issue. Mine was a very small finish nail that had been sucked into the water pump. When I took the pump off the motor, the nail fell out. I made sure the pump was still turning ok and not damaged, then reassembled it all and it's worked fine...and quite...ever since. Mel
Posted on Feb 27, 2008
zeusfaber
  • 247 Answers
SOURCE: Maytag Epic Washer high spin shaking, AND high-pitched sound coming out of washer
When someone reports severe vibration during spin on a brand new washer, the first question always has to be whether the transit brackets have been left in.
Washers are designed so that the drum and motor float on a collection of springs and shock absorbers. To prevent damage to these during shipping, a set of brackets is used to bolt the floating assembly to the case. If these aren't removed before first use (the manual will say how to do it) havoc ensues.
The irritating whine is a new one on me.
A.
Posted on Jul 04, 2008
SOURCE: Neptune washer load noise.
I do know there is a set of bearings on the drum drive shaft. There is an inner and an outer. Some places mention that these bearings are no longer available. However, I found on ebay a gentlemen who sells these bearing and the seals in a kit for about $80.00. It comes with instructions on how to repair and will save a lot of money. I have done this once already to the same washer, now I am doing it again. If you search on ebay maytag neptune parts you will find his listing for a bearing kit. He also describes the jet engine noise.
Posted on Sep 13, 2008
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Noisy during agitate cycle whirlpool washer
Originally posted as solution to Kenmore 24992300 failure to agitate and loud whirring noise during spin cycle.... Hope this helps:
The problem as I noticed it was that the washer would start making a super high-pitched and very loud whirring noise during the spin cycle, and that when I would open the lid, the drum would not be spinning, but when I would close the lid, the drum would start spinning. I was okay with this during that load but after reading here and taking it apart, I realized what had happened:
The agitator dogs are supposed to have a 3-toothed profile on each one, but they become worn over time due to being made of a soft plastic. The dogs should "throw out" into an inner ring gear during normal operation, turning the entire drum. But when they became worn enough to slip, they would still throw out, grinding them at very high speed into the inner ring gear. Since they are made of a softer plastic than the gear, they were just getting more and more worn.
I assume the way this was supposed to fix itself was that when the outer tooth on the dog became worn, the next one would engage, but that didn't happen.
Because the dogs are made of such a soft plastic, I was able to cut a new tooth profile into each one, so that when they were put back in they would function correctly. It takes very little effort and a few minutes with an x-acto knife to cut the right profile.
I'm going to buy the replacement dogs, which being a manufacturer substitute will hopefully be made with a better tooth profile, from harder plastic, or both.
As another note, who knows how long the dogs weren't engaged correctly during agitation, causing clothes to sit without really being washed, but without the high pitched air raid siren. So probably a good idea to replace or repair them immediately, even if you can get it to work intermittently.
Sep 12, 2013 | Sears Parts Direct Whirlpool 4313896...
My Kenmore Elite 3T washer has a loud whistling noise in the spin cycle. ??? Thanks!
Hi.
When that happens it is often because the drum bearing is starting to go. The first symptom is a loud high pitched noise during the spin part of the cycle. As problem gets worsening you will notice that the drum will be a bit wobbly if you spin it by hand.
Here parts and diagrams.
Regards.
Ginko.
Mar 10, 2011 | Kenmore HE3T Washer
The washer just started making this real loud high pitched noise while running the spin cycle?
have u lost a bra wire ?? it could be caught under drum or your bearings are gone in drum ... turn drum by hand it should run smooth .
Feb 27, 2011 | Whirlpool Washing Machines
Whirlpool Calypso Mod: GVW9959KQ2, stops and shows "ob" as code for fast final spin. Also making high pitched whine during wash cycle. Appl svce place has suggested bearing or xmission. Any possible...
Sorry to say but they are right. The Calypso washer was a horible design given to whirlpool from maytag. I would suggest you go buy new machine. Buy someting that looks simple and easy to use. The more complicated the unit the more problems you will have down the road.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Whining noise, only in rinse and spin cycle, sounds awful.
Check the pump to make sure there isn't something stuck in it.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
110 people viewed this question
Top Washing Machines Experts
