Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Persistant beeping I have been having a persistant problem that occurs while I'm sewing. I can sew for about 2-4 inches, the machine stops, beeps and then is okay for the next 2-4 inches. I've checked the threading of both the top and bobbing thread and everything looks okay there. Do you have any suggestions? Thanks for any help you can give
  • 3 more comments
  • donvicki919 Nov 05, 2008
    It looks like that worked. I am working on something really really thick and I haven't tried that yet, but just messing around with the more light weight material, all is quiet and my husband is happy again!
    Thanks Dupina, I will let you know the final result!!!
  • Anonymous Nov 06, 2008
    I had the exact same thing happen to me during embroidery, and moving the button hole level helped me too.
  • donvicki919 Nov 06, 2008
    Hi Dupina,
    Well I have put this to the test and you hit it right on, I didn't even know that buttonhole lever was there, but just like you said, that was the problem! If I have any more problems, I will be right back here to find the solution!!1
    Thank you again!! It is great to have a place to go
  • Anonymous Nov 09, 2008
    The machine beeps and stops sewing. The presser foot seems to be the problem since the buttonhole lever is all the way up. When the beeping occurs on an embroidery stitch, the stitch pattern gets messed up.
    I tried to send this in once, but it didn't go...
    My machine beeps and stops. The button hole lever is all the way up. The presser foot seems jammed, and the embroidery stitch gets loused up.
    Scholar:
  • 110 Answers
Look for the buttonhole lever, just behind the needle threader lever. Pull it down and push it up again. The machine gives a warning message if you want to sew and the button hole lever is down. Good luck!
Posted on Nov 04, 2008
My future will sew 2 stichs and beep and stop help. its a quartet
Consult the owner's manual for what the beeps signify. Quite possibly it is a sensor that is either defective/obstructed or there is something wrong with your machine, ie threading, etc...
Can try searching for:
Make Model beep
Nov 02, 2017 | Sewing Machines
While sewing a straight stitch after about seeing 2 inches the machine stops 06 stitch lights up and beeps
Since you didn't provide the make & model of your machine, we are unable to help. However, you can check what the error code means by looking in the troubleshooting section of your owner's manual or search for:
Make Mode error code 06
Sep 23, 2017 | Sewing Machines
Singer curvy beeps twice and quits sewing
I have the same problem and no any solution, someone can help, please.
Mar 05, 2013 | Singer Curvy 8770 Electronic Sewing...
Singer 8770 beeps twice then stops stitching
do you have a manual?
try a new needle
adjust the top tension
try rethreading the machine top & bobbin
May 16, 2012 | Singer Curvy 8770 Electronic Sewing...
Machine is threaded correctly on both the bobbin and top.I have followed the manual step-by step and tried suggestions from other users. The machine will stitch about 2 inches and then beeps. The thread...
It sounds as if you have tried all the usual fixes so it might be a problem with the actual circuitry causing this. I'd take it into nearest Singer the sewing machine dealership or shop where you bought it and ask them to service it (or if still under warranty, for them to diagnose the fault).
Jun 11, 2011 | Singer CE-100 Futura Computerized Sewing...
My machine will start sewing but after about an inch or two of stitches it beeps and stops sewing until I take my foot off the presser foot and start sewing again. Can anyone tell me how to make my machine...
If it is threaded correctly, especially on top, there is a sensor that is giving you the beep error message. Common problem but it requires trip to experienced singer tech. Sorry solution is not for consumer, too hard to get to sensors and it is not an specific action for remedy.
Jul 10, 2009 | Singer CE-200 Quantum Futura Computerized...
Machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
Apr 08, 2009 | Singer CE-200 Quantum Futura Computerized...
Beeps several times and stops sewing.
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develops in the threading process and you are able to sew a few more stitches before the beeping starts again. If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. Also you can try to push to spool holder in as close as possible to the spool pin to alleviate any gaps. If the beeping continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house. Good Luck!
Apr 27, 2008 | Kenmore 19233 Computerized Sewing Machine
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
162 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
