Lexmark X4270 All-In-One InkJet Printer
Problem for Lexmark X4270 All-In-One InkJet Printer
Dial Tone - Lexmark X4270
By reporter on Sep 29, 2006
I'm setting up this new unit. First step is to wire to phone line and connect power supply. After doing this I lifted the phone to check for a dial tone. That part was fine, but on hanging up, it does not break phone connection and I soon get the "If you want to make a call, please hang up" message from the phone company. Only way to cut connection is to unplug phone wire from the phone jack. Can this unit be saved?
Same Problem
Feb 29, 2008
-   what should i do when I see the words: error 1203, we cannot receive fax.-   annleddspa
Dec 28, 2007
-   it won't hang up-   Guest
Solution #1
posted on Sep 29, 2006
Somewhat Helpful)
dugiehowsa
Rank: Wiz
Rating: 77%, 876 votes
The user manual for this device suggests a few things on faxing.
http://www.lexmark.com/publications/pdfs...
1) Use the On Hook Dial options.
2) Try using *9* on the number pad to disconnect.
Was this helpful?
Yes
No
Solution #2
posted on Mar 03, 2008
Not Rated)
cuppie2
Rank: Apprentice
Rating: 0%, 0 votes
ive had this printer in storage for a while and want to use it again. problem is that i dont know what parts to use. i really only need it for the printer right now and i have the ubp hooked up. do i need to connect the phone line to use the printer?
Was this helpful?
Yes
No
Solution #3
posted on Sep 03, 2007
Not Rated)
igla
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem & i realized that the phone headset was plugged in to the wrong jack.The handset plugs in to the jack on the side.
Was this helpful?
Yes
No
Solution #4
posted on Aug 07, 2007
Not Rated)
CanDo
Rank: Wiz
Rating: 81%, 180 votes
There is usually more than one phone plug one for the hand set if yours has this and one for the phone line. And one for something else possibly another phone. Make sure you are plugged into the right one. Then you will have to program it with your phone number and set settings to your taste or need. This can help you to clear up your problem. I did the same thing on mine. Play with it alittle bit and you will get the hang of it.
Was this helpful?
Yes
No
Solution #5
posted on Apr 04, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
1.Chech the Receiver cable It should properly inseted or not?
2.Reset settings(Choose Factory Settings only)
Popular Solutions for Lexmark X4270 All-In-One
Questions and Unsolved Problems for Lexmark X4270 All-In-One
Do you recommend Lexmark X4270 All-In-One InkJet Printer?
Answer
Answer
I have a lexmark X4270 printer/fax machine. I replaced the black ink cartridge but the machine says... (More)
Answer
it says alignment page printing but to paper does not move
Answer
My printer doesn't print and I've tried troubleshooting.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , CA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
