Question about Toshiba DKT-2010 Corded Phone
Toshiba DKT2010-SD Phone
Hello, I have a DKt2010-SD Toshiba phone and can't change the time on it. I've tried everything on this website and others but it doesn't seem tot work.
  • 1 more comment
  • melodie411 Nov 06, 2008
    I cannot set the time on my phone. I've tried the # 652 and nothing happened.
  • twhite43 Nov 07, 2008
    the information here just DOES NOT WORK no matter how I do it, every time I hit the intercom button and then the # button it goes to a fast busy signal, either when I pick up the hand set or leave it hung up. Nothing works.
  • langleygold Mar 15, 2009
    I tried to do the 'Intercom, #652' method and I could not get it to work...also tried it by picking handset up first. It just gave me the busy signal.
OK, model on bottom of phone is DKT2010-SD, but I found a little cheat card in a file for a STRATA DK8 & DK16 so I used a combination of things. First pick up handset and then hit intercom button, # 652 (for time or #651 for date) and enter time in HHMMSS (hour, minute, second) format, once complete hit the redial button.
Posted on Nov 06, 2008
You have to do this from the "primary" extension - "Port 00" - usually extension 200. I've done it every few months, as our clock drifts.
1) Leave the handset on-hook.
2) Press the INT (intercom) or primary DN extension button and press # then dial 652.
3) Dial in the time in 24-hour clock format HHMMSS. Enter a leading 0 for single digits.
4) Press the REDIAL button to save the settings. Confirmation tone should be provided.
5) Press SPKR.
Posted on Apr 13, 2009
    New Friend:
This will not work i have tried it several time
Posted on Mar 19, 2016
The following should work... Intercom # 652 (for time) enter hr min & sec. then redial to save.....for the date its intercom # 651
Posted on Nov 04, 2008
Hello, my company has an DKT2020-SD, please tell me how to change the time on this phone system. Thanks - Big Dawg.
Posted on Nov 03, 2008
Toshiba DKT2010-sd calls no longer go to voicemail
go to the website http://www.telecom.toshiba.com/ go to the call forward settings in the book turn off Call forward All and turn on Call Forward NA (No Answer) by default it should go to the VM system. If it does not figure out what you dial in the keypad when you want VM to answer.
Nov 22, 2013 | Toshiba DKT-2010 Corded Phone
Please provide website that I can download operating manual for the Toshiba phone system DKT2010-SD Thanks!
Try www.toshiba.com and look for driver downloads to see if they offer a manual download for your model. Next try customer support if you come up empty.
Jan 14, 2011 | Toshiba DKT-2010 Corded Phone
Please download me instructions on how to change time in our Toshiba Phones at work with Model No. DKT2010-SD. Also I am requesting a Manual for the Toshiba DKT2010-SD phone system. Your tech support...
Changing the time on a Strata DK system must be done from the "main" or primary phone. It is usually extension # 10, or # 200. 1.- With the phone on-hook, dial intercom, #, 652 (depending on the system type, the # may or may not apply) 2.- Enter the correct time using HH/MM/SS, like 07:24:00 3.- Press redial As far as the system manual goes, I'll need to know the type of system you have. Toshiba DKT2010's work with a number fo different Toshiba systems. To find out, go to where the phone system is located and look at the top corner. It should have a number designation there such as DK 40i or DK280 etc.
Nov 08, 2010 | Toshiba DKT2010SD Phone
I have a toshiba dkt2010-sd that I need to mount to the wall
The base is removed and turned 180 degrees and put back on phone notice the slide tabs are in correct position and can noe be hung by screws or a wall jack. Where the cord plugs in there is a breakout tab, that is the insert to hold the reciever on the phone when hung up.
Sep 09, 2009 | Toshiba DKT-2010 Corded Phone
Toshiba DKT2010-sd ringing in ear while on a call
1) To stop the ringing in your ear, press Redial and Vol Down at the same time
The following must be performed from station 10 or 200.
2) To change date : Press INTCM, #, 6, 5, 1, Enter date YY/MM/DD, press redial
3) To change time : Press INTCM, #, 6, 5, 2, Enter time HH/MM/SS in 24 Hr Format, press redial
4) To change day of week : Press INTCM, #, 6, 5, 3, Enter day (1=Sun, 2=Mon...), press redial
For more information regarding your Toshiba DKT 2010 Phone and the system that you're using, feel free to browse our extensive guides and manuals that you can find here
Or you can call me at 1-800-903-9190
May 05, 2009 | Toshiba DKT2010SD Phone
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
Need Help
I couldn't find the manual for your specific phone, but you can try manual these similar phones.
http://www.tel-programmer.com/Time%20setting/toshiba_time.htm
May 08, 2008 | Toshiba DKT-2010 Corded Phone
Changing Voice Mail Password from the TOSHIBA DKT2010-SD set
you will need to download the manuall you should be able to get it off this sight hope this is some help
Oct 30, 2007 | Toshiba DKT-2010 Corded Phone
Toshiba DKT-2010 Corded Phone Logo
3,082 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
