Question about Vtech Cordless 6041 Phone
Using phone it cuts out and 'no line " appears
I have replaced these batteries ,had phone service at house and still these phones cuts out when in use.Hand set #2 bearly works ,lights up for only short periods thought of replacing that battery again? Thanks for any help you can give!
    Genius:
  • 1,550 Answers
Unplug the unit for 30 minutes and plug the connection to phone .
This will solve your problem .
Posted on Nov 03, 2008
  • 19,396 Answers
Ensure that there is signal in the line.
Try using a different phone cables.
Try unplugging all phone cables and power cords, and plug them back after ten minutes.
Ensure that the phone are built and sold in the same country where you are using them, phones designed for a different country won't recognize the line signal.
    President:
  • 1,952 Answers
If you subscribe to DSL service for this telephone line, DSL filters must be plugged into EVERY phone jack that has a phone. The DSL signal can cause static/noise, squealing (similar to fax tones), caller ID disruption and other issues on your line. DSL filters block the high frequency DSL signals from being transmitted to the telephone. If you are not using the DSL filters provided by the telephone company, this will cause static/noise and possibly caller id issues on your phones.
In most cases, we recommend you connect the plug end of the DSL filter into the telephone jack, then connect a telephone cord between the filter and your phone.
Please contact your service provider to obtain DSL filters and installation information.
You may have a line problem. To test for a line problem, test your unit at another location. If your unit works at another location, contact your local telephone company
    President:
  • 2,712 Answers
Could be a problem with the charger plates and/or contacts and hence your phone is dying out quickly. I would check that first. If that is the problem, then simply buying new batteries would not help as they are not getting recharged.
    Brigadier General:
  • 3,614 Answers
What is model and #..
as of the moment check for the connection and the battery of the unit.
    Brigadier General:
  • 6,966 Answers
Initially, a couple of ideas to start with:
  • check the battery, battery terminals, battery wiring. In most cases, it would require that the terminals, pins be cleaned sometimes scrape. Pls ensure that there are no dirt, grime or greenish substance anywhere. Any corrosion would prevent the full potential of the battery to supply the handheld;
  • check if the channel/frequency used could be changed to another. It is possible that a neighbor is using a similar device on the same frequency;
  • since these units operate on radio frequency, they are susceptible to radio interference (RFI) and anything electrical/electronic could produce such intereference. Examples are electronic lamp dimmers, WiFi network devices of computers, some new garage door openers, satellite receivers;
  • additionally, you may want to check the location of the base. Since they operate on radio frequency anything in between the base and the handheld would reduce signal strength.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 08, 2008
    Hi again,
    Any development(s) so far?
When receiving calls on my triple cd445 cordless phone it would ring once or twice and then cut off.How can i solve this problem
Unplug them all overnight, phone jack and power bases. Plus any other phone line devices, faxes etc. Plug the base unit and get someone to phone you. Then plug each unit in one at a time with a phone call in between. One of the units may be exceeding the REN number of units on your home phone line with all the devices you have.
If that doesn't pin point it, contact your phone service provider as you may have line problems including bad connections to the house itself. All your wires sit in boxes outside..
Jul 05, 2016 | Lands Phones
Screen has black vertical lines
We regret to inform you it appears the telephone has an internal issue that a battery simply wouldn't change. We recommend you use the Panasonic.com/repair address to locate an authorized service center in your area.
Mar 18, 2014 | Panasonic GigaRange KX-TG2432 Cordless...
How do you get a touch screen to work the phone is working but the touch screen isnt
LG has released a line of cellular phones that come equipped with a sleek touch-screen LCD display. Since these screens are high-tech and sensitive, they can be prone to damage or scratches. If the touch screen on your LG is damaged, and you don't have the money to take the device to a service technician, you can open up the phone and replace the touch screen yourself.
1. Turn off your LG and slide the back battery door down and off of the device. Lift the battery out of its compartment and use your Phillips screwdriver to remove the four screws located on each corner of the compartment.
2. Use your fingers to remove the back panel from the phone. The green motherboard will be revealed underneath.
3. Unplug the four ribbon cables that connect at the middle of the motherboard. Unplug the antenna cable in the top-right corner of the board. Lift the motherboard out of the phone housing and set it aside.
4. Use your Phillips screwdriver to remove the two screws located at the top of the phone housing, then separate the back frame from the front housing of the phone.
5. Lift the damaged LCD screen out of the phone housing. Replace it with a brand-new LCD screen (available from your LG retailer or online) and reassemble your phone in the reverse order you took it apart.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | LG Vu CU920 Cellular Phone
I have aquired a toshiba dkt2010-s digital business phone, and when i hook it up to the line at my house all i hear is clicking, what am i doing wrong?
phone line is not on. call service provider and have them cut the line on....they will only cut on the line you are using, and not ALL the jacks in the house!!! ...call and tell them you want this one cut on, someone may have to come out, but may be able to do it over the phone! Good luck
Jun 12, 2010 | Lands Phones
I have a Uniden dect6.0 cordless phone, when I plug it into my phone jack ,the screen reads check phone line. So we have replaced the phone line with another brand new cord.Same thing. Can not get a dial...
When the "check phone line" message appears, it is referring to telephone service and not the wire. It appears that your phone jack is "dead" or that there is no working service in the home. Do you have another phone that you can use to check the jack? Is there another jack that you can plug the phone into for a test?
Nov 20, 2009 | Uniden Lands Phones
Two phones in use with Motorola VT1005 result in very low volume
disconnect the POTS line incoming to your home on the outside of your house. This will make the phone wiring within the house a standalone network. Plug the Line 1 jack of your TA into any available phone jack and the remaining jacks in the house will be energized. This will create the same environment as you had with POTS.
Jun 07, 2009 | Panasonic KX-TG2740 Cordless Phone
Cuts of in the middle of calls
I too had the same issue and replaced the batteries. The phone works fine now.
Feb 17, 2008 | British Telecom Freestyle 2200 Trio...
Sakar Telephone Problem
This Telephone doesnt have a capability to work with shared connections where u use more than one phone in one connection.......... And this phone cannot be charged it works in either battery or Adapter...... Good Luck......
Dec 10, 2007 | Sakar Talking Caller-ID Speaker Phone
Line cut off problem
That is a common problem with this model, normally happens after a storm passes through. Unfortunately there is no easy fix for on site, it would need to be sent in for repair or replaced. You can google Siemens Cordless Repair to find service facilities.
Dec 18, 2006 | Siemens Gigaset 2420 Cordless Phone
Vtech Cordless 6041 Phone Logo
62 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
