Question about Xerox WorkCentre Pro 575 Plain Paper Laser Fax
Xerox WorkCentre Pro 575 error message
I have a message that I can't get rid of and hence a fax machine I cannot use. My machine says "top cover is open or no process unit". The manual says nothing about a process unit; where and what is that and how do I fix this!
Please help!
  • Vincent de Beer
    Vincent de Beer Jan 06, 2009
    Hi
    I have the same problem. The machine is a WorkCentre Pro 535 and comes up with "no proccess unit m100%". No amount of switching the machine on and off fixes the problem. I thought it might be a faulty toner and ordered a new one. No joy after installing it though.
    Any help would be great
    thanks
    Genius:
  • 2,120 Answers
Could be the tab that actuates the top cover switch is broken off.
The process unit is your drum,toner, and developer unit. It sits right under the top cover. Big black removeable cartridge.
Posted on Nov 03, 2008
What we can do for brother fax-2820 " DRUM ERROR"
open front cover with the machine on and press the options key.message will appear replace drum unit then select 1 for new.close cover
Oct 25, 2012 | Brother IntelliFax-2820 Laser Fax
How do you clear the memory when the machine says memory full 100%
You can find your answer at the link below. Just type "memory full" in the search dialog box and it will provide you with the many results and solutions for clearing the error. The message can be the result of many issues, so you may need to perform a few different steps:
http://www.support.xerox.com/support/workcentre-pro-575/support/enus.html
Jun 22, 2011 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Back cover open message although cover is closed
Open the top and back covers. If you see any jammed paper or
other item, gently pull it out, then close the covers. If the error message
remains, open and close the covers again. If the FAX/MFC cannot reset
itself and return to the date and time prompt, it will display MACHINE
ERROR XX. Please call Brother Customer Service
and tell them the Machine Error number at:
In USA:
1-800-284-4329
In Canada:
1-800-853-6660
In Montreal:
1-514-685-6464
Jan 15, 2011 | Brother IntelliFax-2820 Laser Fax
I have a workcentre pro 575 and am receiving the message, "memory full". Nothing will print, and I hope you can tell me how to get the stored memory to print out. Thanks.
You hopefully just need to clear memory, delete phone numbers or delete jobs.
If those don't work the Main Board might be bad 160K72560
Whit
Item, Inc
Aug 17, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    I'm getting drum error message, it says move blue tab back and forth, I don't what the drum is and I don't see blue tabs
    Open your document feeder cover (it pivots away from you), then open the forward top cover (it pivots towards you). Inside the machine is the drum / toner unit, remove it. On top of this assembly is the blue tab (plastic handle) either on the left or right side. Slide that tab back and forth ~ 4 or 5 times. Reinstall the drum / toner unit. Close the top cover, then the document feeder cover. Done...
    Dec 18, 2009 | Brother IntelliFax-2820 Laser Fax
    Where is the top cover switch? I can't find it.
    This is the manufacter's official manual link:
    http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_750_770_EN_85.PDF
    On page 63 it shows you how to open the top cover. You must open the front cover first then open the top cover by pressing the blue levers on both sides of the top cover.
    It also has a diagram.
    Hope this helps!
    WizardRepair
    Jul 17, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
    What is Error 2200 when I try to fax something?
    Error 2200 is a scanner stall error.. there are a couple things for you to try to fix it:
    Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
    Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
    Open the top cover of the AIO.
    Using the carrier belt, move the cartridge carrier to the middle of the unit.
    Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
    IF THE ERROR MESSAGE DID NOT COME BACK....
    Power off the AIO and remove the power supply from the back of the unit.
    INSERT THE COLOR CARTRIDGE ONLY,
    Close the top cover, reinsert the power supply, and power on the AIO.
    IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
    IF THE ERROR MESSAGE IS GONE,
    Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
    Power back up as in previous steps...
    NO ERROR? SHOULD BE GOOD TO GO..
    ERROR?? TRY DIFFERENT BLACK
    If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
    Jun 29, 2009 | Lexmark X7170 All-In-One InkJet Printer
    Can not send or receive fax.
    Is the phone line plugged into the "line" jack and not the " phone or Ext " Jack?
    Jun 09, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
    Xerox WorkCentre Pro 575 Plain Paper Laser Fax Logo
    227 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
