Back to:
Tags:
iLO -3200 32 in. LCD Television
TV does not turn on
posted by C-May on Sep 29, 2006
I just purchased my TV and I can not get anything to happen besides the green light to come on. There is no picture or sound. Thank you.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 29, 2006
Thanks for Trying (70)
jomaru
Rank:Guru Guru
Rating: 87%, 451 votes
Your Instruction book should have a phone number for custumer service,give them a call and tell them the problem,they should guide you step by step,see if the store you purchased the unit from has a 30 day exchange,you should not be having any kind of problem,I am assuming you have an antenna conected to the back to the tuner input or a DVD conected to the video input of the set.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on TV does not turn on:
I don't want to Accept this solution
Can you Help with these Flat Panel Televisions problems?
tv turns off by it self after 30 or 45 mins , must unplug...
if so what connections do i need to connect to my hp media...
picture stays on for 5 mins then turns off, i have checked...
i can only turn on can not change channel or use the...
Ok my remote was broken. Now i am trying to get to the av...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
