Question about RCA CC6263 Camcorder
Canon EX1 I have an old (BUT GOOD) canon EX1 Hi8 camcorder that refuses to power up.Its not the power sourse Battereries or Mains ) so it seems to beb inside. Ant Ideas? Andy J
I have a EX1 Hi8 too and I have had the same problem. This camera is very old and it has a lot of capacitors inside that are leaking and drying out. They need to be replaced. This is a huge and difficult job and it makes no sense to repair. I did it anyway.
Posted on Jan 17, 2009
CANON EX1 HI8 SERVICE MANUAL
What about it ? Do you have one for sale, do you wish to purchase one, or are you just confirming its existence ? If either of the first two, I should try Ebay - if the last, then thank you for the information.
Nov 16, 2016 | Canon Video Cameras
Why am I having difficulty rewinding and playing tapes?
Is the Canon UC9 a HI8 camera?? If not it wont play HI*.
Aug 21, 2015 | Canon UC9 Camcorder
Canon ES5000 hi8 camcorder won't load a tape.
that is the mechanism alignement(mode switch)
plus a little gear who match with the other
you will need a very good tech to fix it.usely its the problem.
hope that will help
regards Alan
Jun 02, 2010 | Canon ES5000 Camcorder
HI8 EX1 capacitors problem, is a repair a good solution?
capacitors are unexpensive, can be obtained in almost any electronics store or even pulled out from any other piece of electronics, if it matches the specs of yours; you need to have the specs for the original capacitor
To have it replaced, the repairman has to be skilled and careful while removing the soldering of the older one and most careful installing the replacement
I have had capacitors replaced in mother boards and if done with care, they back to working status
total cost of repair is low
Mar 16, 2017 | RCA CC6263 Camcorder
I HAVE a sharp viewcam vl-h860 hi8
If you're pretty sure the camera is just dead and have already resigned yourself to buying a new one you could just pry the door off and get your wedding tape out. There are lots of places that can transfer it to VHS or DVD for a small fee. On another note, I have a camera just like it, have lost the AV cable and can't seem to find a replacement online. Care to sell me yours? If so send me an email at turnerts@charter.net. Thanks!
Staci
Mar 04, 2009 | Sharp Viewcam VL-AH130U Camcorder
Transferring hi8 tape to Everio hard drive
I play the hi8 video back to the T V lcd 32 screen
Because you video in not in digtal format
From the Telly i set up the try pot install the camcorder jvc 30
everio zoom in to size start the camera camcorder
for video start the hi8 video in the telly pres the recorder
on camcorder and record. This is the way the piratcy is done in the Cinamas
corra
Jan 03, 2008 | JVC Everio GZ-MG130 Camcorder
8mm/Hi8/Digital 8
As this was quite some time ago, you probably already have your solution, but I just ran across this. Just in case you can use any other 8mm camcorder or deck if you can find one. Also if you still had it I would like to buy the Instruction manual from that old Canon ES780. Please write me back at bpgray@verizon.net if you have it. Thanks.
Dec 14, 2007 | Canon ES870 8mm Analog Camcorder
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
LINES DURING PLAYBACK
Fast forward and rewind a cassette several times without using A/C, to drain the battery. Recharge the battery; and you may have found your solution. If that does not work, replace the battery- online auction sites have them for about 10 bucks. If that does not work, start saving your pennies- the prices have come down so much on these things that you can get a high quality Samsung that will everything but outperform your existing camcorder- for $135 USD. Good Luck
Nov 04, 2007 | Video Cameras
RCA CC6263 Camcorder Logo
1,036 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
