Question about Canon MP520 All-In-One InkJet Photo Printer
Canon MP520 Error 6A80 has occurred -
I have no manual but I know this has been caused because I unplugged the printer without switching it off by the on/off button. Can you help me please.
  • 2 more comments
  • Anonymous Nov 18, 2008
    Minde is the Canon MX700 - Same error message.
  • Anonymous Jan 14, 2009
    Same, but I didn't unplug the cable during operation...
  • kaymn Feb 19, 2009
    I got this same message while printing photos. I have turned it off and on several times,, and it still does not work... How do you fix this?
  • Anonymous May 01, 2009
    i have the 6A80 error on my canon pixma mx700 printer. i had a paper jam. got all the paper ou t.
Hi @ all,
i got the same problem. I did some google search and found the tip below:
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
But doing this another menue appeared and i pressed okay and swithched the printer off. I did 3 times and finally the error disappeared. Now i am really happy because my printer is still working. Hope it will help you to fix your problems with this error.
Posted on Jan 15, 2010
  • 421 Answers
6A80 error is an APP position error. It means that an error has occured when the motor was runnin during the purging operation on startup.
Canon specifies that on of three parts of the printer might be faulty to create this error. The sheet feeder, purge unit or logic board. This is a link to the official service manual:
http://www.tradebit.com/filedetail.php/4981053-canon-pixma-mp520-printer-service-manual
Posted on Dec 05, 2008
On mine the slide on the right side front coner was stuck used flash light and hand to slde white peice back with spring on it .You might have to pull the print head to right.I then sprayed with pen oil and seems to work well now
Posted on Jun 02, 2009
Error 6a80
Sheet feed unit (QM3-2647)
- Logic board (QM3-2599) PROBLEM
Oct 19, 2013 | Canon PIXMA MP520 InkJet Printer
My Canon MP520 has a 6A80 error and now the printer head is also stuck on the far right side.
6A80 error is an APP position error caused by the APP motor during the purging operation as the printer starts up. Canon states that one of three components is likely to have failed, the sheet feed unit, purge unit or logic board. All of these will be almost impossible to get as a spare part. The only thing worth trying is an EEPROM reset that can be done using the service manual. Get a copy here: http://www.tradebit.com/filedetail.php/4981053-canon-pixma-mp520-printer-service-manual
Feb 03, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Hi, I have a "dead"
APP position error or Error Code 6A80
Condition: An error occurred in the APP motor.
Problems and Solutions:
  • Check for foreign material or paper debris around the purge drive system unit
    - remove foreign material.
  • Check for foreign material or paper debris around the ASF unit
  • If other solution fail, replace one off the following part
    - Purge drive system unit
    - Logic board
for more info visit: http://pcmediks.blogspot.com
Dec 28, 2010 | Canon Pixma MP450 All-In-One InkJet...
Canon MP520 error message 6A80 - Have tried switching on and off at wall no help. Judy
May 31, 2010 | Canon MF8180C Color Laser MFC Printer
Will not print. screen just flashes up error code 6a80 and will do nothing
Solution:
  • Switch the printer OFF
  • Press buttons 1 + 2 + 3 and 4 (simultaneously using four fingers)
  • Keep pressing this four buttons for 10 seconds
  • Release the On/Off button (number 4) (Keeping pressing the others)
  • After a few seconds (when the printer go ON), release buttons 1, 2, 3
Jul 10, 2009 | Canon PIXMA MP520 InkJet Printer
Error 6A80
Error 6A80 indicates that "an error occurred in the APP motor
during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
I'd recommend bringing the unit into your local canon authorized service facility for complete diagnostic and repair.
May 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I have a Canon, Pixma MP520 and an error message is coming up 6A80 Printer error has accurred. Turn off power then back on again. If problems persist, see the manual. I can't seem to fix it, can you help
Put the colors out of the printer and do it on and off a few times and put the colors back in and a few times on and off again, that was working on my 6a80 problem.
Greetings Pieter.
Oct 19, 2008 | Office Equipment & Supplies
Message error 6A80. Comes up with "printer error has ocurred. please turn off printer then back on again. if problem persists see manual" manual has nothing in it.
Jul 27, 2008 | Canon MP520 All-In-One InkJet Photo...
Error cannon pixma mp520
Turned it on, off many times as instructions suggest,
etc no dice. Reinstalled software, did everything including giving it a few taps.I was very seriously ready to buy a new one and trash this one, even checking flyers. I read where so my are having this same problem.
In my anger I started pushing all the buttons randomly and suddenly the green light stayed on.
Voila the crazy thing works fine again. Must have reset the glych somehow ?(I have no idea how)
Give it a try before giving up, who knows!!
Jun 03, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Brand new PIXMA MP520 just connected up. Having just installed the print head and the ink cartridges, now getting message when turn on the printer. >>> 6A80 Printer error has occurred. Turn...
I opened the printer, and pushed gently on the lever that holds/releases the print head, and this seemed to release whatever was stuck. After this the print head moved freely on turning on the printer/copier.
Mar 05, 2008 | Computers & Internet
Canon MP520 All-In-One InkJet Photo Printer Logo
8,893 people viewed this question
old marine
old marine
