Question about Krups 358-70 La Glaciere 1.5 Quart Ice Cream Maker
Motor runs, but paddle doesn't turn
I can hear the motor running, but paddle doesn't turn.I removed the paddle to make sure there was nothing that would obstruct its rotation.
  • Anonymous May 15, 2008
    Paddle can't turn in any kind of loaded situation, like the transmission is slipping
Manual can be found online at makeicecream.com
Posted on Aug 20, 2007
    Genius:
  • 1,074 Answers
Groove has worn out replace it if you can get parts.good luck.
Posted on Apr 18, 2007
I need to down load a manual for ge ice cream maker model 106765
  • 1
    Place the mixer bowl in the freezer. The amount of time required depends on the temperature of your freezer, but you should expect to leave it in the freezer for about one day prior to use. To check if the bowl is frozen, shake it gently. If you don't hear any liquid sloshing around inside, it's ready to use.
  • 2
    Place the mixer bowl onto the motor base when you're ready to make ice cream. Insert the mixing paddle into the bowl and place the cover over the bowl.
  • 3
    Turn on the ice cream maker and pour the ice cream mixture into the hole at the center of the appliance until it reaches the fill line. Do not exceed the fill line, as the ice cream will increase in volume as it freezes. Use the low setting if you want a firm ice cream and the High setting if you want a softer consistency. Do not add nuts, candy or chocolate chips at this stage as they can become hung up in the mixing paddle and stop the machine.
  • 4
    Cover the center hole with the cap and allow the ice cream maker to run for 30 to 45 minutes.
  • 5
    Add mix-in ingredients such as nuts and candies two minutes before shutting down the machine.
  • 6
    Turn off and unplug the machine prior to removing the ice cream from the bowl. GE recommends using plastic or rubber utensils to avoid scratching the inside of the mixer bowl.
  • Read more: GE Ice Cream Maker Instructions ' eHow.co.uk http://www.ehow.co.uk/how_7784888_ge-ice-cream-maker-instructions.html#ixzz1ahXwP2GR
    Sep 09, 2011 | Gel Canister 106765 1.5 Quart Ice Cream...
    Paddle is not turning when pluged in and tyrned on.
    Be sure the little gear is inserted between the paddle and the motor. I have found that it falls out of the motor and then out of the paddle if you are not watching._437.jpg
    Dec 10, 2010 | Krups 358-70 La Glaciere 1.5 Quart Ice...
    Machine is model 750-27can you help me? runs for only about 5seconds not long enough to make ice cream
    Welcome to FixYa
    An electric ice-cream maker is a tabletop appliance for mixing and freezing ice cream at home. A small electric motor drives gears that turn the canister filled with the ingredients for ice cream. The canister is surrounded with ice and rock salt to freeze the contents. Alternately, a hand crank on top replaces the motor.
    Although durable, ice-cream makers can require a few repairs. A common problem is damage to motors or gears from mixing too large batches of ice cream or from neglecting a jammed mixing paddle. The electrical cord can fail and motor bearings can dry out.
    Read Following ...
    • Use your cylinder bowl correctly. If the cylinder isn't handled properly, your ice cream won't set. Make sure it is dried completely after washing so ice doesn't form on the walls, make sure to leave it in the freezer overnight before making ice cream and don't leave the bowl out at room temperature before using.
    • Check your freezer door. If it isn't sealed properly, or if it's constantly being opened during the freezing process, your ice cream can't set properly.
    • Handle the ingredients correctly. Don't let the ingredients warm and don't overfill the bowl. Check the manufacturers recommendations for the maximum bowl capacity.
    • Clean and dry your machine thoroughly. Use a damp cloth on the motor assembly; never immerse. Make sure to wash the lid, blade and cylinder according to directions and make sure the cylinder is absolutely dry before freezing.
    • Contact the manufacturer's support site only after you have exhausted your options. They may walk you back through the steps you've already taken, but at best your problem will get fixed far more quickly because you eliminated the easy problems in advance.
    I hope this Instruction guide will help you Click here Read carefully Instructions[Specifically Page27, 29,31]
    OR click here
    Just Check this Link too
    Thanks for Contacting FixYa...
    Jun 27, 2010 | Taylor 632-27 Ice Cream Maker
    I need an instruction manual for my Deni 5000 ice cream maker
    Are you looking for operating instructions or reciepts?
    Find receipts via Google.
    Operating instructions:
    place the mix into the can with the paddle inside. Place the can into the bucket. Attach the motor or crank as appropriate.
    Crush some ice (aboout 5 pounds) and pack about 2 inches around the base of the can with the can in the bucket. cover this ice with rock salt. Put two more inches of crushed ice on top - spread more rock salt (the smaller the ice, the smoother the mix). Continue this process until you are at the top. Make sure the drain is clear, start cranking (or motoring. When the motor stops, unplug it. Cover all with a heavy towel for about 30 minutges (if you can stand it) If for some reason the motor doesn't stop - you didnt put in enough salt. Expect to use about 1/2 of a 5 pound bag.
    Remove the towel - the motor - the top - the paddle. Give the paddle to the kids with a couple spoons. Dig in for the adults.
    I sometimes add a quart of water but you dont have to.
    The ice makes the water cold - the water provides the freezing power, the salt lowers the freezing point of the water - the extra water might speed the process a little bit ... maybe not
    Enjoy your delicious home made ice cream.
    (BTW - the paddle does not move ... the can spins around the can causing mixing.
    a
    Oct 14, 2009 | Deni 5000 Scoop Factory 1.5 Quart Ice...
    When plugged in& on cylinder turns but paddle
    ... as it should
    The paddle is stationary
    When making ice cream,make sure your ice is crushed fine and you use enough rock salt.
    Sep 27, 2009 | Maximatic Elite 4 Quart Ice Cream Maker
    Paddle does not move. Machine is about two years old.
    sometimes the brushes take a set when unused.. Unplug the motor. Without using rnough pressure yo break anything, try turning the motor by hand using the paddle. You will be trying to turn the motor through ithe gesrs so use slow steady moderate pressure. This does work. as long as you watch what you are doing wiyh yhe force you apply. Good Luck. and enjoy the ice cream
    Sep 07, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
    Ice cream not firm
    The freezer bowl is sensitive. Go ahead and thaw it out until you can hear the liquid swishing around inside - usually letting warm water run through it is sufficient for thawing. Then refreeze the bowl, making sure the bowl is sitting flat/level in the freezer. When making ice cream with this unit, letting the freezer bowl sit out for even 20 minutes can unfreeze it enough so that you only get sludge. Do not remove the freezer bowl until you are immediately ready to pour the ingedients into the bowl. You can even pre-chill your ingredients by letting the ingredients sit in the freezer for about 15 minutes - although I have found that this usually has the opposite effect of what you have just experienced --> the ingredients usually freeze up so fast that the mixing paddle is no longer able to turn.
    -Tha Mp3 Doctor
    Mar 16, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
    Mixing arm/bowl will not turn once machine is turned on
    The only thing I can really suggest is to make sure the easy-lock button is fitted into the right place on the lid, and to make sure that the ice cream mixture is not too thick. But, if the turning paddle is locked into place properly, and the mixture is still in liquid form, then there is a problem with one of several parts - could be the metal sliding switch or even a motorized part. These parts cannot be replaced. It is worth a shot to replace the mixing paddle - the unit has a 3-year warranty, so I would Call Cuisinart to get the part instead of ordering it online - they may or may not give it to you for free. If the new mixing paddle still won't spin, get the unit replaced either thorugh the store (depending on the store -each has a different policy) or get it replaced directly through Cuisinart. This model is actually pretty solid, so a second one shouldn't give you any problems.
    -Tha Mp3 Doctor
    Mar 05, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
    Cuisinart ICE-20 AND TURNING PROBLEM
    The problem is either the mixing paddle itself or the lid that it fits into - both parts can be ordered from Cuisinart.
    Aug 09, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
    Deni Ice Cream Maker Manual
    I don't have a flatbed scanner to scan it, but here are the operating instructions (at least for the 5201).
    1. Place canister in freezer for 8 hours (must be frozen solid-so that you can't hear liquid in canister sloshing around)
    2. Prepare your ingredients ahead, and chill them for best results.
    3. Take canister out of freezer and place on motor base. Use canister immediately after removing from freezer, as it will begin to thaw once placed at room temp.
    4. Place the paddle inside container. Be sure the tould side of the paddle faces up.
    5. Lock the lid (the clear plastic piece that fits over the container)onto motor base. The tabs on the bottom of the lid should line up with the indentations in the motor base. This ensures that the lid is locked in place. When fitting the lid onto the base, the stir paddle should "fit" into the lid.
    6. Turn the On/Off dial to the right (on position).IT IS IMPORTANT THAT YOU TURN THE UNIT ON BEFORE POURING IN THE MIXTURE. THE CANISTER ROTATES WHILE THE STIR PADDLE REMAINS STATIONARY.
    7. Slowly pour the mixture in the top opening of the lid. It is at this time that you place the top on the clear-vue lid and leave the machine on for about 5-30 minutes (time varies, depending on the coldness of ingredients and canister, and desired consitency) If making ice cream, your result should be a soft, custard-like ice cream
    8. When the frozen dessert is ready, make sure the unit is off. Remove the lid and the mixture from the bowl with a plastic spoon or scoop. NEVER USE METAL INSTRUMENTS IN THE CANISTER.
    9. Ice cream will be custard-like. If you prefer hard ice cream, place in freezer in air tight container and allow to set until it reaches your desired hardness. Don't put the ice cream in the canister in your freezer for more than 30 minutes, as the ice cream will freeze solid to the container and possibly damage it.
    Hope this helps... If you need something else, let me know. I will try to check back soon.
    Apr 14, 2008 | Deni / 5201 / 5202 / 5203 / 5205 Ice Cream...
    Krups 358-70 La Glaciere 1.5 Quart Ice Cream Maker Logo
    485 people viewed this question
    Top Krups Ice Cream Makers Experts
    Marvin
    Marvin
    ray gallant
    Ruth summersides
    Are you a Krups Ice Cream Maker Expert? Answer questions, earn points and help others
