Question about PANDIGITAL (DPF802) Digital Picture Frame
No Power to 7inch Pandigital photo frames
I have two 7 inch Pandigital Photo Frames but they do not turn on. I plugged in the DC power adaptor and verified that the switch is in the "ON" position. I know the frame is getting power because I hear a clicking sound from the speakers when I turn it "off" and "on".
Any suggestions?
  • 5 more comments
  • Anonymous Nov 04, 2008
    I have two that do the same thing, all I hear is a buzzing sound.
  • skircr Nov 27, 2008
    Same problem the when the frame is on it just buzzes, but the screen does not coe on.
  • rakm139 Dec 02, 2008
    I have the same problem with my 7" Pandigital frame, no power from the power adapter.
  • Anonymous Jan 27, 2009
    When turned on there is a slight buzz and then the screen is black.  It worked previously and was briefly unplugged and will not come on again.
  • connie parks Feb 20, 2009
    frame will not come on i have it plugged up but i her or see nothing
    frame will not come on and it is plugged in.
  • jackie_fluhr Feb 21, 2009
    The frame was working and then it stopped suddenly. Tried turning it on again and the screen was black.
SOURCE: the Pandigital LCD Photo Frame's "frame extender" won't extend
Just pull it.... straight down. Too much torque may break it.
Posted on Dec 28, 2008
  • 3 Answers
SOURCE: Not all jpeg images will load on 7'' Pandigital Photo Frame
I was having a problem too with my Smartparts frame. All the pics were from the same camera but some of the vertical (portrait) orientation shots wouldn't show right. Just a bunch of thin colored lines. After some phone calls I did try to "resize" the photos to the "resolution" of my frame (had to look that up too). My frame is 640 width by 480 high. So I took a shot and changed all the goofy photos to 480 width (since they were vertical) and let Photoshop change the the other number. Low and behold the buggers are showing up fine now. Well on to my next problem - focusing with the new D90. I think that one is going to be more challenging yet. Hope this helps you out.
Posted on Dec 30, 2008
robmcd27
  • 423 Answers
SOURCE: Need PANDIGITAL PanDigital 8.0" Digital
I don't like pasting information, but this is the link to the manual.
http://akamaipix.crutchfield.com/Manuals/692/692PAN902B.PDF
Don't forget to rate my solution, and thanks for coming to FixYa.
Rob
Posted on Feb 21, 2009
SOURCE: pan digital 7 frame screen goes white
Removing the internal battery will clear all settings. I have done this on two different versions of the Pandigital frames (seems to be a very common issue) and it has corrected the issue instantly both times.
Good luck.
Posted on Jan 26, 2010
marked
  • 6487 Answers
SOURCE: I lost the manual for my pandigital 7 inch frame.
You can use this user manual since 7 and 8 inch only has one user manual.
http://www.pandigital.net/userfiles/file/Downloads/UG_E-FRC_PAN80XXT_V2_5_01-14-09.pdf
Posted on Jun 20, 2010
Does not turn on
Hi
First of all try another power unit and if you did so and it still not working I think that maybe micro fuse inside burned off and you must open the cover to see it
Sep 18, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
My sreen for months hs been stuckon screen that says androidsystem recover
Try the simple stuff first ... turn the picture frame off. Then remove the AC power adapter from the a/c socket in the wall. Wait 30 seconds then plug the adapter back into the wall outlet. Turn your picture frame back on and notice any error messages that may get displayed.
Jun 06, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
Instruction_Manuals_For 7 inch cibox photo frome
If you mean the PanDigital DPF701, Retrevo has a link to the manual here: http://www.retrevo.com/support/Pandigital-DPF701-Digital-Photo-Frames-manual/id/7008ag810/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Oct 20, 2011 | PANDIGITAL 7-Inch Digital Photo Frame with...
My external is hooked up to the frame through the usb, but itwill only let me choose internal memory or slideshow folders, it wont let me choose usb when i try to select media sources. how do i get it to...
The external hard drive is diferent from a regular USB stick, so this is probably the case. You could check the manual of the photo frame and the manual of the externa drive, probably you will find some settings that reffer to this.
You could also check that the external drive is plugged in to AC, and turned on, many drives require alternative power source when conected to low power readers like your photo frame.
Apr 07, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
How do i upload pics from my pc
I have a Mac and tried to drag and drop my photos as mentioned above. The results?
- Wiped all pictures off of the frame.
- When I tried to reload from my laptop it shows "format not supported" as a placeholder for the pictures. The images are in jpg format.
How can I fix this problem?
Mar 18, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Need english manual for 512 mb 7" LCD
[PDF] 7Digital Photo Frame User Manual File Format: PDF/Adobe Acrobat - View as HTML
Digital Photo Frame. Please read carefully and follow all warnings and instructions in this User's ... Product: 7”LCD Screen Digital Photo Picture Frame ...
www.x-digitalmedia.com/PDFs/7inch.pdf - Similar pages
May 07, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Where to get power supply?
http://www.shopping.com/xPC-GeCube-Pandigital-8-Inch-Digital-Photo-Frame-with-2-Interchangeable-Frames
Mar 09, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
PANDIGITAL (DPF802) Digital Picture Frame Logo
661 people viewed this question
Top PANDIGITAL Photography Experts
Gareth Cockram
Gareth Cockram
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
