Question about Paradigm PDR 10 Speaker
Paradigm PDR-10 Sub Box
Had this around 2 years and it has started making a high pitch whistling noise.. Do you know where I can get hold of a Curcuit Diagram
    Problem Solver:
  • 21 Answers
Since this is a sub I assume the sound is not coming from the speaker but is mechanical and coming from the amp in back. The tranformer can be the problem if it has delaminated or may be loose. Try removing the amp and tightening the screws. If there are rubber grommets to isolate the tranformer don't overtighten. www.pardigm.com for contact info and parts. They are very nice. If the noise is coming from the speaker then you are still under warrantee and they will replace it free.
Posted on Aug 27, 2007
My Paradigm PDR 12 subwoofer has started to make crackling noises. Is this an amplifier malfunction?
Depends when it makes these crackling noises.
If it's when the sub isn't being driven, then it could be the amp. (Check for bulging capacitors on the amp board). If it's when you move cables about then it could be a broken lead or a dry solder joint on one of the inputs.
If the crackling is when the sub is running then it might be the voice coil has distorted due to being overdriven with a poor and highly distorted signal.
Sep 07, 2014 | Audio Players & Recorders
Makes high pitch whistle
indicates wind turbulence noise
possible around rear view mirrors , weather shields , door edge , bonnet edge , headlights
trial and error is to place tape over adjoining edges to see where a placed tape stops the noise
Nov 27, 2017 | 1999 Jeep Grand Cherokee
Subwoffer will not power up
PDR-8 Specifications
Design
Single driver, bass reflex system with critically tuned resistive port and built-in amplifier Amplifier High-current, discrete output, 90 watts RMS
Amplifier Features Soft clipping, thermal protection Frequency Response On-Axis 29Hz - 150Hz Low Frequency Driver 210mm (8 in) extended travel with 38mm (1-1/2 in) voice-coil, aluminum former Low Frequency Extension 29 Hz (DIN) Finishes Black Ash, Light Cherry, Dark Cherry Inputs From A/V receiver/processor or Paradigm X-Series Subwoofer Control Unit mono-sub out or preamp left/right output;From receiver/amplifier speaker terminals or main/satellite speaker terminals Weight 25 lbs. (11 kg) Dimensions HxWxD 13.25" × 9.75" × 15"
(34cm × 25cm × 38cm)
Specifications are subject to change without notice.
© 2016 Paradigm Electronics Inc. Conditions of Use Privacy Policy Unauthorized Dealers WARNINGSouth Africa
Dec 26, 2013 | Paradigm PDR 8 Subwoofer
Paradigm pdr80 no sound
If it is a powered sub, the sub power supply may have failed. There might be an open fuse.
Dec 25, 2013 | Paradigm PDR 12 Speaker
Do you have the brakes taken apart once a year,
on all your vehicles, for rust removal,inspection,
needed work & lubing,that is required
Have to flush brake fluid every 2 years, if you
don't want moisture in the system ruining it
Don't know what the noise is,work on the
brakes & then get back to the noise, if it's
still there
Jul 24, 2013 | 2010 Mercury Milan
PDR-10 subwoofer has no output. 120vac to unit is
I have exactly the same situation with my PDR-10. Paradigm techs were of no help, don't me to take it to a service centre which i did. Of course when it was there they plugged it in and it stayed on for a day and a half so no problem right? Get it home, nothing, plugged and replugged, got it on once but not for long. Opened up back, everything including fuse looks solid and fine....to naked eye anyhow.
Dec 20, 2009 | Paradigm PDR 10 Speaker
High pitch whistling noise in engine compartment of 2005 envoy
There may be a small hole or cut in a vacum line or possibly just loose. Also make sure the air filter box and the big hose to it are secure and clamps etc are tight. Pulleys and belts can make a high pitch sound also.
Mar 22, 2009 | GMC Envoy XL Cars & Trucks
Hum coming out of Front left/right speakers but not center
There is a chance that your wiring is producing this problem. Manufacturers don't always make equipment that is compatible with each other. The biggest problem's are "ground loops". Radio Shack has a non-electrical device that separates the common ground from all equipment. You basically connect it between your amp out's and in's - cables included. It is possible that other manufactures also make and sell this device too. It's main "Google" name would most likely be - "Ground Loop Isolators". If you are using the actually speaker outputs into your subwoofer amp input(s), check your polarity wiring again. Good luck with your system - it sounds like it'll rock when it's all setup correctly.
Nov 06, 2008 | Paradigm PDR 12 Speaker
Power problem with Paradigm PDR 10 Subwoofer
Yes it can be.You can check it with ohmmeter the impedance should be 4 or 8 ohms.But if you can disassembly the sub its better then you can see and check everything.My guess is that one of the cables on the speakers connector is broken and its just touching the conntact.
Mar 08, 2008 | Paradigm PDR 10 Speaker
Power Indicator Light on Front Doesn't Light
The indicator light needs to be replaced, there is a loose or poorly soldered connection on one of the led's leads, or the circuit providing the signal (voltage) for the light isn't functioning.
Sep 17, 2007 | Paradigm PDR 10 Speaker
2,624 people viewed this question
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
woodzowl307
Don Hart
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
