Question about InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector
InFocus LP120 Projector shuts off automatically
My InFocus LP120 projector recently starting shutting down sporadically. It turns on and recognizes the PC/Laptop, but after appox. 5 minutes shuts itself off. After about 5 minutes it will start up, if it has been unplugged and plugged in again. The fan is working and it doesn't matter whether the lamp has been powered up or not.
  • Anonymous Jan 24, 2009
    Hi I have the same problem too!  Have you figured anything out?
  • 2,237 Answers
Overheating or power supply problem.
Posted on Sep 03, 2009
InFocus Projector-Searching
most likely it is your cable. If a for sure brand new cable doesn't fix it it is most likely the main board. Also try flashing the software again.
Apr 28, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
InFocus LP120 that will not power on.
it project?..but in 10 sec.it off? im pretty sure that the lamp ballast of your projector is defective. but if deadset? check the power supply and your power cord. if still not working your power supply board is defective.
Oct 28, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus LP120 projector with the shakes
if you are refering to the image shaking, you need to replace the colorwheel. if you mean the projector physically shakes, replace the fans and/or the colorwheel. they are the only 2 moving parts in the machine.
Oct 14, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
InFocus LP120 Powercycles/Shuts Off/Does Not Stay On
what is the led doing? what coloris it? and if it is blinking, how many times? this will tell you the problem.
green (flashing and solid)- all is well
red flashing:
1 time- lamp won't strike after 5x
2 times- lamp has over 2000 hrs. replace lamp
3 times- lamp failure. replace lamp
4 times- fan not working.
5 times- projector running too hot. needs cooldown
red led lit solid- undiagnosed issue. send in for repair.
if your projector is under 2 years old, it's under warranty, but it seems unlikely.
Aug 10, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus Lp120 stops working after 30 minutes
lamp expiring soon or overheating. also check colorwheel.
Apr 02, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Projector shuts down after about 5 minutes of run time.
possible overheating. clean it out with canned air and make sure the fan works. it should get faster the hotter the projector gets. also, the flashing led will tell you what the problem is.
Mar 11, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Fan stopped
Its internal circuitry might be telling it to not run--a remnant request during the last cool down. Hopefully it is the fan itself. Try the master reset command. If you do not get an image before its shuts off, look in your owner's manual, count the way you manipulate the menu buttons to get to the reset, and try it between the moment you first turn it on, and it shuts off. Unfortunately some units will not let you input commands untill it is 'up to speed'. My Eiki is like this--nothing untill it is fully bright. Depending on your 'exploration' desire, short of going to a repair place, or buying a new one, you might try seeing if your unit is dirty, see if you have power to the fan (voltage meter--maybe 5-7 volts), or something is jammed in there. Depending on its age, the fan just might be dead, Jon.
Feb 24, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
LP120 : fan stopped error
you can purchase and replace the blower assembly- part # 505-1917-00. it's tricky, but you can do it. find an infocus authorized service center form their web site to buy it.
Jan 19, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus LP120 counts down then restarts counting down
this can usually indicate one of several things, a lamp service life issue, an overheating problem, or that the lamp service cover has not been properly secured
Dec 08, 2007 | InFocus LP120 / 1000 Lumens / XGA / DLP...
InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector Logo
1,526 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
