Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
1 USB Port Failure
Hi Guys.
Yesterday all was ok, but today when i started up i was unable to input my windows password as the keyboard would not work. the usb port was not working for the keyboard so i changed the port to another and hence it is working, i then put a 4 port hub in the same failed port and it works.
Also the mouse will not work in the same failed port as the keyboard.
So how is it that a 4 port hub will work in the failed port and not the mouse
or keyboard all very strange to me not had this problem before.
And also done System Restore point to last week but still the same.
Anyone got any answers for me as i see others have this problem
Dell want to charge £25 for trouble shooting.
Hi Guys
Unfortunately after looking at the computer installation details i was at fault, although i have had
the computer for well over 2 years and this is the first time it has happened.
My Dell Dimension 5150 has 7 USB ports 5 at the back and 2 in the front and it appears that i have
connected the keyboard and mouse to the wrong ports.
There are two ports at the bottom allocated for the keyboard and mouse and for some reason i had
them in the top three ports hence my problem but still not sure why it happened.
Anyway my Dell Dimension 5150 is now running OK and no further help is needed.
Many Thanks.
Posted on Nov 04, 2008
Starts up. Password required but keyboard not typing correctly. Blue tooth keyboard not recognized.
The most likely cause is that the keyboard needs a new battery in it, inserted on the underside. After that it may be that the small keyboard comms dongle in a USB port is not making proper contact. Pull that out and insert it a few times.
Mar 26, 2016 | Tablets & eReaders
Keyboard stopped working after a Windows update yesterday at 4:28 PM. External USB keyboard now attached. No BIOS keyboard settings found. Dell Studio Laptop.All keyboard drivers are up to date. Help????
First thing I would do is get the dell diagnostics disc (hold f12 at start up) and run that, while trying to use the keyboard. (move the arrow keys around and see if they work. you might have to unhook the usb keyboard first) if the keyboard works in the diagnostics area, then its not a hardware issue. (kbd failure would mean no keys worked, or, only some worked sometimes.) You would then need to go into windows device manager and try rolling back the keyboard drivers. If you have full kbd functions outside windows, then you have a windows driver issue. try rolling back, or removing the drivers.
Nov 05, 2009 | Dell 0Y3740 Keyboard
The keyboard on my laptop is locked and i cant use it to search but upon startup it works and i can input the password to open it and then it locks again
It sounds like your keyboard device driver. It may have been "updated" automatically.
Do you have a spare USB keyboard or can you remove one from a desktop temporarily?
Power OFF the laptop and plug in the USB keyboard. Power ON laptop.
Use the USB keyboard, not the laptop keyboard for this procedure.
First, does the USB keyboard work w/o locking up?
Anyway, Go to the "Device Manager" by right-clicking "My Computer" and select "Manage".
A list of Your computer devices will appear on the right window. Expand the +Keyboard and find the HID Keyboard Device associated to your laptop. (Pick one by checking the properties of each one to see which one may not be working)
(( btw, HID = Human Input Device ))
You can either "UNINSTALL" it or "UPDATE DRIVER"
When finished, reboot, remove USB keyboard if you want to and the laptop keyboard will work just fine, or the OS will "find" it first , then start working ok.
Follow the steps, it will work.
Sep 17, 2009 | Acer Aspire 5100 Notebook
Password will not work
may b a key board failure. Go to safemood aln check also.
When the machine boots up press F8
then go there and check. If its not a virus, it will work fine
If not you need to clean the keyboard
Thanks
Please rate the answer if it helps u
Jun 24, 2009 | ASUS Eee PC 701SD
I have four Compaq EVO D510 computers that all have the same problem. They are used computers that were pulled out of an existing site. I have a USB mouse & keyboard connected to the computer (no...
Hi sdd555,
Restart the computer after plugging the USB keyboard into a different USB port, or remove the keyboard in Device Manager and then refresh the system to work around the issue. This will cause the device to be re-enumerated and the driver will be reloaded.
Good Luck,
Mark
Jan 13, 2009 | Compaq Evo D500 PC Desktop
When i start my pc acer aspire m1641 after microsift corporation
go into the bios and make sure the USB controller are enabled, save settings and reboot if still same drivers are missing from the operating system, if you haven't got a password boot to windows and plug the keyboard in a different port to re-install the drivers. if you can't, does the computer support ordinary keyboards?
Nov 21, 2008 | Acer Aspire M1641-U1521A PC Desktop
Microsoft Wireless Keyboard 5000 keeps opening and closing the windows start menu once connected
Did you try the following.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Oct 26, 2008 | Microsoft Wireless Optical Desktop 5000...
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
Keyboard will not work during post or boot
The problem you are experiencing is caused by a setting in your BIOS. I recommend getting or borrowing a keyboard with a PS/2 port or getting a USB to PS/2 Adapter for Keyboards. Once you do, you can change the setting in the BIOS to accept USB keyboards. If you are already familiar with BIOS then you don't need to read further to enable USB support, other wise I recommend continuing to get familiar with what you are looking for.
When you get a keyboard that uses a PS/2 port, go to the BIOS for your computer. Go to "Advanced" and search for "USB Legacy Support" or something similar in terms of "USB", "keyboard", or "input". Once found, you will have to change the setting to enable USB. If the name of the setting has "USB", then you want it enabled. If it has "keyboard" or "input", then look at the available options for USB and use it unless it has something similar to "dynamic" or "auto-detect" which are better choices.
After finding the right setting and selecting the correct option, go to "Exit" and select "Exit and save changes". Then the BIOS will save and reboot the computer or continue on as if you didn't open up the BIOS.
Aug 15, 2008 | Logitech 967233 Keyboard
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
247 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
