Question about George Foreman GR44BWVT Indoor Grill
Grill died I have the double-sided grill with clear bun-warmer pockets on top. After about 18 mo of excellent use it suddenly died. No heat - no led lights etc. Wa able to open up the compartment n bottom with safety hex screws. PC board in there so couldn't do much more. Since both sides went out I had thought it was a power cord issue. Maybe the power to the PC board. Looking for repair depot in the toronto Canada area. Or where coul I get that board - probably should do te trick. The only thing beyond it is the 4 heating elements: Top, bottom - left, right. I'm sure they didn't all go out at once.
  • 3 more comments
  • law666 Dec 28, 2007
    George Foreman Double Knockout Lean Mean Fat Reducing Grill with Bun Warmers
    Product Ref:
    10814
    Key Features include:
    780 cm2 grilling surface
    Automatic warm up feature
    Electronic temperature controls
    Translucent Clear Bun Warmer
    On/Off switch electronic controls on both sides.
  • law666 Feb 21, 2008
    where in the uk can i get a new pc board for this
  • partagas150 May 07, 2008
    both sides of the grill died while cooking bacon.....have taken it all apart. i find no fuse, i have continuity in the elemnts, the pc boards seem fine, as well as the control boarbs on both sides. i see no burn or hot area on any pc board......have power coming in....can not find where it dies yet....any help????
  • richie05 Jan 20, 2009
    Left the Grill in Stand-by mode and when I returned to it found it to be dead. This is the second grill of the same model that has done this
    I contacted the repair centre in the UK. Salton Europe Ltd. The advised a fault with the circuit board and recommended sending it to them in Manchester to see if they could repair it.
    i'll post if it was successful.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
I have the same George Foreman Grill, Model # GR44BWVT with the same problem DEAD. The power board is not the problem, I replaced the thermal fuse found next to one of the heating elements covered by a white sleeve. Hope this helps you.
Tony
Posted on Aug 20, 2009
I have the bottom off right now. The id I see is TSK2721b/T-POWER. Hope this helps.
Posted on Jul 10, 2008
  • 944 Answers
Contact these guys; http://www.esalton.com/control/contactus and they should be able to give you a repair centre list - i think you are right about the board - if you can post again with the board number we can try to source it seperately Hope this helps :)
Posted on Mar 27, 2007
The temperature markings on the top oven/grill have worn off - can anyone help
the first knob has tree positions in the middle is off to the left the top (grill) heats to the right top (grill) and bottom heat, the second knob indicates the temperature in the following way ..50....100....150....200....250..good luck
Nov 27, 2012 | New World E70DOa Electric Double Oven
Grill outage
I'm not sure what you mean by the Grill side. All the information I see for the SCE30600 shows a rather normal over with 4 burner stovetop, but nothing I would call a grill. Can you explain in more detail, or is it possible you chose the wrong model?
Sep 03, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Hi Guys I have a Stoves 720EF Double Oven and Grill. Whilst halfway through cooking some sausages on the grill this evening, the grill suddenly stopped working (plus the LED for the grill knob showing...
If the element and the indicator light both stopped working this suggests a problem with the power supply for the grill control. Either the grill control has no power going to it or it is faulty and requires replacement. If you are not sure what you are doing you'd better get a tech. to look at it, it can be fairly complicated for the untrained person.
Feb 24, 2011 | Stoves 720EF Electric Double Oven
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
Grill is not working
Is The small amount of heat you are getting coming from the bottom element in the top oven or is half the top Grill element working.To start with you have a double grill element and either the whole element has gone or just half the element.This is controlled by a selector switch which could be at fault or the Thermostat that controls the temperature.
Hope this helps.
Jul 07, 2010 | Electrolux Insight EKC6049X Stainless...
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
Parts for George Foreman Grill GR20BW
Hello Rod01,
After some research, I found no parts resource for your GR20BW bun cover (I'm not saying that such a resource doesn't exsist though). So other than replacing the grill or repairing (if it's broken) your existing cover, that buying a used one at an online auction site (or wherever you can find one) for parts (if the cover is intact on the parts grill) would be a place to start looking. I tried and didn't find anything for your GR20BW, but did find a few GR10BW grills.
I hope this helps, and Good luck.
Mar 07, 2008 | Kitchen Ranges
These are the guys you need to contact; http://www.esalton.com/control/contactus If you get no luck with them, then i am sure any reasonable machine shop should be able to make one up quite easily Hope this helps, please post again if not :)
Apr 01, 2007 | George Foreman GR44BWVT Indoor Grill
George Foreman GR44BWVT Indoor Grill Logo
316 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
