Removal of renault modus door panel
How do i remove a Renault Modus door panel so that i can replace the wing mirror.
Cheers,
Chris.
  • billbunter Nov 18, 2008
    I need to remove the door panel. Found three screws but that seems to be it
SOURCE: Modus One Six spare parts
I had a blown tweeter in my Modus one-six and after no luck with IAG America (sounded like a teenager taking my call and told me it would be 3 months), I contacted IAG UK by email from their main website and got a reply in about 3 days. She said that since it was an older speaker, the tweeter had to be constructed. I was told the price total with shipping and that if I wished to purchase, to give them a credit card number. As sketchy as it was emailing someone my credit card number, the tweeter arrived within 2 weeks from Britain for a total of $66. Couldn't have asked for better service. Just tell them that their IAG in America is doing a poor job with customer service.
Posted on Jun 14, 2008
Pojtronix
  • 24 Answers
SOURCE: modus one six speaker not working properly
Hi. If you have an digital multimeter to hand you could always drop the drive unit (the metalwork with the paper cone) out from the enclosure and make sure the resistance of the voice coil is between 4-16 ohms. If there is no reading then the voice coil could be open circuit and the whole drive unit will need to be replaced. If the others rattle check the mounting screws are not slackened off. Especially if you have been driving them hard!
Posted on Dec 23, 2008
SOURCE: Renault Modus 2005 Diesel
how do u reset service-light on facia display on 2005 renault modus after self-service?
Posted on Jun 13, 2009
SOURCE: I need to buy one Wharfdale Modus 8 speaker only.
I have two modus 8 speakers in great condition wanting to sell will be inexpensive if you are interested please email shanhaycraft@yahoo.com
Posted on Sep 05, 2009
  • 396 Answers
SOURCE: What is the easiest way to replace a tweeter on
big red
some pliers and a philips screw driver
Posted on Oct 23, 2009
Renault modus fual door wont open
Fuel flap actuator has failed to open simple open trap door in boot right hand side panel inside you will see a black box approximately 10cm by 7 cm with a hook that can be pressed upward to open the flap
Jul 13, 2014 | 2005 Renault Modus 1.5
Renault modus climate fan whirring
Probably needs to be serviced the fan motor gets dusty and came make the noise.
Apr 29, 2014 | 2005 Renault Modus 1.5
Renault modus radio code
notify dealer will need your vin and proof of ownership
Sep 10, 2013 | Car Audio & Video
Where are the spark plugs located on a 1.4l renault modus
Could this help? It's not from Modus, but similarities may help you...
Apr 02, 2013 | 2006 Renault Modus 1.4
Renault Modus How can I remove the near side door panel
look for any screws in the panel around the door handle and arm rest remove these then use a wide flat head screw drive place this between the panel and the door and pry out this should release snaps or Christmas tree snaps located around the entire door panel work your way around the panel prying out as you go
Jul 30, 2012 | Cars & Trucks
Headlight bulb replacement on renault modus
Replacing a dipped head light bulb on a Renault Modus.
Having recently purchased a 2008 Modus with the passenger side dipped beam head light bulb not working. Concerned that posts on this matter talked about removing several body parts or a costly visit to the Renault dealer.
It's a simple 10 minute job. It is a little tricky with limited access and restricted view. However - its as simlpe as - remove circular cover from rear of bulb holder - remove the clip on connecter and push to side. You need to pull the wire clip above the bulb slightly to the side from its holding and it flips down and out of the way Be careful not to detach the clip from its holding points below the bulb - it's extra hassle to put back in.
You can now remove the old bulb - replace with the new bulb. Make sure its sitting correctly in housing. Re attach the clip to its holding point above the bulb. Replace the connector.Replace the circular cover to the rear of the bulb holder.
It takes 10 minutes - cost me under five pounds for the replacement bulb. Hope this helps.
Feb 05, 2012 | Renault Modus Cars & Trucks
Renault Modus repair manual wanted
1.5 modus deisel wont start orange light on dash says ignition fault
Jun 12, 2009 | 2006 Renault Le Car
Renault modus dashboard warning light 'check emissions' and rotten egg pong and lumpy drive. Car has done less than12K but did fill up at Asda previous evening before problem started.
Not necessarily catalytic convertor. this happened on mine recently and it just needed a coil replacing. Costs about £87 at a Renault garage if this is the case
Jun 07, 2009 | 2005 Renault 181
Apr 27, 2009 | 2005 Renault 181
706 people viewed this question
 Grubhead
Grubhead
