Question about Sharp Microwave Ovens
Microwave Arcing inside
I have a sharp carousel R-4W38 microwave, about 8 yrs old that just started arcing inside when used. The arcing has burned thru the cover plate. I am sure it's the microwave generator "Magnatron???" but cannot find the part number or what that part will cost.
I repair comupters all day so I am confident I can disassemble this thing and replace the part if I can find it....
My questions are:
1. Can someone help me witht he part number and cost?
2. Is there any adjustment that needs to be made after the part is replaced that I cannot do because I don't have meters?
3. Any other gotcha's that I might not be thinking about here?
  • 3 Answers
Found the online service manual and did the troubleshooting necessary to determine it was the magnatron. I have one ordered.
Posted on Nov 05, 2008
Hi. Our 1 1/2 year old Sharp KB6524PS Microwave Drawer: While cooking oatmeal, at start of cycle, the microwave started arcing, then smoking. Shut off at 15 seconds. Microwave-safe china used.
I expect the arcing came from the waveguide cover or aerial cover having either a crack or carbonised food particles on it.
A new cover may affect a cure if the magnetron is not damaged.
Aug 18, 2017 | Sharp Microwave Ovens
The unit started arching inside the front panel on the upper left corner.
Arcing Inside the Microwave - Martin Microwave Inc.
microwaveglasstrays.com/shop/articles-arcing.html
Microwave Glass Trays, : Arcing Inside the Microwave - Microwave Glass Trays ...glass tray, microwave plate, glass trays, turntable, microwave oven, carousel, ...microwave energy, and will eventually it will start producing arcs and put out one heck... the damage is non-repairable and the unit should no longer be operated.
Notes on the Troubleshooting and Repair of Microwave Ovens
www.repairfaq.org/REPAIR/F_micfaq3.html
Microwave oven does not respond to START button. First ..... but with the leakage from the spot welded waveguide inside the unit. ... My clue in was a spark between the waveguide and the case, when I was messing with the Controller PCB.) ...
MICROWAVE OVEN ARCING ' MICROWAVE OVENS
Dec 15, 2015 | Microwave Ovens
I have a Sharp Carousel Microwave R-1460A. The disk on the ceiling, opposite the warming plate and about the same size, has severe burn marks (probably from food splatters). Any idea what that part is
see this indication and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity pain
Nov 08, 2013 | Sharp R-1460 Microwave Oven
Arcing sparking to carousel wheel. have 8 year old GE advantium 120 microwave oven. Was working just fine with a burnt out lightbulb but when I replaced the over head lightbulb it started to arc to the...
I think the problem is just coincidental to the lamp replacement.
i would say there is grease or food debris on the turntable support or turntable motor coupler.
The service manual is here and you can order parts from the Pros here.
Sep 23, 2013 | GE Advantium 120 Convection/Microwave Oven
Sharp carousel R 430 EK 1200 watts
This is not good, the magnetron is arcing because metal is exposed, this will eventually destroy the magnetron making the oven useless. I strongly suggest it get looked at for safety and potential fire hazard.
Mar 05, 2012 | Sharp Carousel R530EST Microwave Oven
After running for around 5-10 seconds, a large "spark" can be seen arcing inside the microwave accompanied by a "shorting out" sound.
It is the magnetron that is arcing and potentially very dangerous, the magnetron is failing or there is exposed metal or to much food particle build up. I suggest unplugging the unit and have it checked out for safety reasons.
Feb 21, 2011 | Sharp Carousel R530EST Microwave Oven
Our microwave began arcing and shooting light/flame from the metal panel on the RH side. We had used it the night before with no problems.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 26, 2010 | Sharp Carousel R530EST Microwave Oven
Sharp Microwave Oven Model R-403kk-T
Are you talking about the light inside the microwave? The front vent I think will allow you to get to the bulb. Should be a couple of small scrrews holding the vent cover on, remove them take vent off. Start it up again and see if the light bulb wiring or socket is arcing
Sep 16, 2009 | Frigidaire FMV156EM Microwave Oven
Microwave Ovens Logo
363 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
