Question about Hitachi 43F300 43" Rear Projection Television
Menu in 3d but no video to speak of
Greetings everyone, i can get the menu to come up. it's like it's in 3d (r.g.b.) and sorta skewed. i can even get to the magic focus choice on the video menu but when i select it nothing happens. there is no picture except for a some flashes of color now and then. this flash of color occurs in the area of the screen as if you were looking at a movie in letterbox format. it looks like the colors are in a whirlwind. that's the best way to describe it. from what i've been reading it sounds like a convergence problem and all (2 or 3) convergenc modules should possibley be replaced at the same time. any help will be greatly appreciated. it's been a great set and this is the first problem that i've had with it. thanks, reteplase
    President:
  • 3,130 Answers
Yes it is convergence IC's and could alsop be the convergence power supply feed or one of its componet.. The convergence IC's are soldered into place, so your going to have some solid state repair experience They are two black IC's that are standing up on a metal heat sink and they should have on the front of them STK-#######. The #'s are numbers. Replace them with the exact numbers and both at once. If you have no soldering experience do not attempt this repair as you will distroy or can distroy the printed circuit board assy.
Posted on Sep 29, 2006
SOURCE:
I have a uniden dect 6.0 how do I put in an answering message. I have lost the manual
press the menu button
select answering set up
press menu/select to start recording
wait until the system says --record greeting--before speaking
the message can be from 2 to 30 seconds long
press menu button to stop recording
the system will play back what you have said
to save the greeting press --end
if you are not happy with the greeting press menu again and start over
if you do not want to change the greeting the system has a pre-recorded message ---hello , no one is available to take your call. Please leave a message after the beep
Nov 10, 2017 | Uniden Lands Phones
How to change my recorded greeting on kx-tg6431
You can change your answering system message by pressing Menu (with the phone in standby). Then use the up/down arrows to select Answering Device and press Select. Navigate to Greeting Message and press Select again. Then navigate to Record Greeting. Use the up/down arrows to select Yes. Wait for the beep and speak your greeting. Then press Stop when your message is done; the system will stop recording after two minutes. Press Off to exit the menu system. Your greeting will be played if the Answering system is on and the greeting message time is not set to "Greeting Only". You can also access the Record Greeting sub-menu by pressing the following keys Menu # 3 0 2 .
See page 32 of the manual for more on recording a greeting. The manual is available from Panasonic here: https://panasonic.encompass.com/shop/model_research_docs/?file=/MSC/om/KXTG6431T.pdf . You can also see more about the phone's menu on pages 20-23.
I hope this helps.
Apr 12, 2017 | Panasonic KX-TG6431
How do I put my own message in my answer machine .?
you have not bothered to give the make and model of your phone so this answer is relevant to uniden dect 1635 but will be a guide to your unit as well as most use the same format
recording a personal greeting (2 to 30 seconds long)
1--open the menu with the phone in stand-by
select answering setup, then record greeting
2--press menu/select to start recording Wait until the system says --"record greeting" before speaking
3--press menu/select to stop recording. The system plays back your new greeting
4--- to keep the message press end
to re-record it press menu/select
in your manual look for the section " using answering system" or "personal the greeting"
Jan 07, 2016 | Lands Phones
DO SAMSUNG HC-P4741W TVS HAVE A TROUBLE CODE LIGHT?
if color is skewed or looks 3d its a convergence problem--select that in main menu and try to adjust--if will not adjust it needs the chips for that replaced.
Jun 07, 2012 | Samsung HC-P4741W 47" Rear Projection...
Appears out of fcous for the red and green colours with a red and green image surrounding all objects.
Look in menu to see if the set has a convergence adjustment in the menu--if older set and colors are skewed or 3d looking the convergence circuit needs repair---got a model number? If a Sony should begin with KP.
Apr 18, 2012 | Sony Televison & Video
How do you adjust color
NORMAL adjustments are made with the remote in the menu--if color looks skewed or even 3d go into menu and select convergence--with remote see if will adjust.
A better explanation of what the issue is might help and confirm model number if possible
Apr 15, 2012 | Mitsubishi WS-55411 55" Rear Projection...
How to put my own voice on answering maching?
Open the menu with the phone in standby.
Select Ans. Setup, then Record Greeting.
Press MENU/SELECT to start recording.
Wait until the system says "Record greeting" before speaking.
Press Menu/Selectto stop recording.
The system plays back your new greeting.
To keep the greeting, press End.
To re-record it, press Menu/select.
Hopfully this works for you
Jul 05, 2011 | Uniden DECT 6.0 Cordless Telephone...
Sorta looks like 3d red&green mostly also has red lines arching across bottom 1/2 of screen
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 14, 2011 | Zenith R57W46 57" Rear Projection...
How do you set up the message for the answering machine? Lost the instructions that came with the unit. I know the phone has a menu, but not sure if this is where I would program the answering machine.
Greeting message
When the unit answers a call, callers
are greeted by a greeting message. You
can record your own greeting message
or use a prerecorded greeting
message.
Recording your greeting
message
You can record your own greeting
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering device” i
{OK}
3 {V}/{^}: “Record greeting” i
{OK}
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
Using a prerecorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a
prerecorded greeting message for
callers and ask them to leave
messages.
Sep 11, 2009 | Panasonic KX-TG1033S Cordless Phone
Hitachi 43F300 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
