Question about Brother DCP-8040 Copier
Bad Drum? I have a Brother MFC-8440 Copier. I may have left the Drum out in direct light too long while I was cleaning out the machine. After re-assembly, the first page prints fine but if I print multiple pages, by about the fourth page, the pages become progressively blotchy until they become so blackened you can't see the text. If I let the machine rest for a short period of time, and print, again, only the first couple of pages print fine. Could I have ruined my Drum by leaving it in direct light? Thanks, Phil
  • 788 Answers
Yes, printer drums work under photoelectric rules and any exposure to light can affect their performance.
Posted on Nov 03, 2008
Just installed a new drum unit in my Brother DCP1000, and it's still reading "Replace Drum soon"
this stands for brother mfc-8440 as in the title.
you need to reset the "drum counter" of your printer..
to do so try one of those
Brother Laser Printers:
After replacing the drum unit, keep the front cover open (make sure the power is on). Press and hold the "GO" button until all four LED's are lit. Once the four LED's light up, close the front cover. Make sure the drum LED is off. The counter is reset!
Brother Fax Machines:
Open the front cover. Press the CLEAR/BACK button. Press 1, when the display shows accepted.
Sep 19, 2011 | Brother MFC-8440 All-In-One Laser Printer
Hing broke on copier can i get parts for that
Spare parts are available here (Brother MFC8440 Doc Feeder Parts).
Left hinge is one part, right hinge requires one or two separate parts
LP2403001 HINGE ASSY Left
LE6244001 HINGE BASE Right
LE6245001 HINGE ARM Right
Dec 29, 2010 | Brother MFC-8440 All-In-One Laser Printer
How do I clean the drum on the Brother MFC-8440
It should be constantly cleaned by it's cleaning blade with every revolution. If that's not making continuous contact inside the drum unit, then it's time to replace the drum. The symptom to look for is not just a gray background, but images that repeat about 3 inches down the page as the drum rolls around to that point again.
If the background is gray without noticeable repeating image, it may be a defective toner cartridge. We've wasted a fair amount of money replacing Brother drums when it turned out to be the much cheaper toner cartridge. If it's a new cartridge, take it back to the store along with before and after print samples.
Jan 21, 2010 | Brother MFC-8440 All-In-One Laser Printer
Installed new drum on Brother MFC-8440. Still says chnage drum soon
With new drum you got to have a instruction how to reset counter of the drum. In every packet of new drum come with instruction how to change and reset.
Dec 15, 2009 | Brother MFC-8440 All-In-One Laser Printer
I have a Brother MFC 8440..the paper has vertical black lines
Try changing the toner, if it's generic that's your problem, and if it's either an old brother drum or a generic you may need a new one. There is also a glass to clean, it's right above where the drum sits inside, 1/2 inch wide across the top. Wipe with a dry cloth.
Sep 14, 2009 | Brother MFC-8440 All-In-One Laser Printer
I have a Brother mfc-8440. It prints light on the
Usually when it prints light on one side and normal on the other, it's either the drum (which you replaced) a dirty corona wire, or the toner is unevenly distributed in the cartridge. You can removed the toner cartridge and gently drop it from a distance of about 4-5 inches to dislodge any caked up toner. This is normal in a cartridge that has sat a while or if the fax machine is in a room with high humidity.
Hope this answers your question and best of luck.
Aug 02, 2009 | Office Equipment & Supplies
I have a brother MFC 8440
Have you checked the back paper door?, the paper tray?, and the drum/toner unit? If a paper was torn out of the machine, you may not be able to see the piece that is still triggering the jam signal. You can also pull down the paper guide around the orange fuser roller through the back door by pulling it gently to the left.
Sep 11, 2008 | Brother MFC-8440 All-In-One Laser Printer
Pls Clean Drum
The drum is the larger plastic unit that slides out an the toner cartridge fits into it. The corona wire is the very fine wire at the front top of the drum. Just slide the little cleaning tab back and forth.
Aug 03, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother DCP-8040 Copier Logo
179 people viewed this question
James Cagle
James Cagle
Jim Keysor
