Question about Yamaha DSP-A2 Receiver
Yamaha dsp a2
Bought a dsp a2 of Ebay. Main speaker outputs not producing any sound. have checked speakers, cables, speaker set up. All other ouputs (front, rear, centre) are functional. Is there any easy solution or have I been taken for a ride??
  • Anonymous Apr 16, 2009
    I also have a similar problem with my DSP-A2,i have no sound from my 2 front or 2 rear speakers,my center speaker works fine.I have checked the sound on the test mode,and the fault is still the same, the A and B switches are turned on and all the speaker cables are connected ok.
    Any ideas would be greatly appreciated as i.m baffled now
    New Friend:
It could be that the couplers between pre-out & Main-in are missing
On the back panel, to the left of the Main speaker terminals, there is a set of 10 phone terminals with the label 'Coupler / Output' above.
The 4 terminals below the word 'coupler' should be joined together, left to right (or pre-out to main-in) with a small horseshoe coupler which plugs into the phono sockets, effectively joining them together.
Without these couplers, your front end main speakers would not work as the amp thinks you are using a power amp to run the main speakers and not this amp.
Posted on May 24, 2014
  • 33 Answers
The speakers a and b have a realy inside that baiscly switches them on and off when you press the buttons can you hear the realys click if not then it may be a dry solder joint or you may have to get them replaced
Posted on Oct 31, 2009
Check the A or B switches it could be they are turned off!
Posted on Jul 04, 2007
My receiver no longer produces sound to the speakers unless I push the "Pure Direct" button.
verify that the optical cable (or the tv optical output) is not the problem. try using a different audio source with optical output such as a cd player if you have.
Oct 05, 2015 | Yamaha RX-V673
Yamaha A-960 amp hookup instructions
The inputs and outputs have to be connected accordingly.
first of all check the speakers and connect them one by one while checking the terminals for the rear/.main and frint speakers. Connect the ouput of the sources, be it the CD, VCR, etc., to the respective inputs marked. You can use the optical cable for the DVD or Blueray.
Now switch on select input and set the tones.
Please give me more inputs if the tips are not enough.
Nov 22, 2011 | Yamaha Audio Players & Recorders
No sound. Tried disconnecting/reconnecting all input/output HDMI cables. Only computer is connected via RCAs (for sound only). No sound at all. Audio works on HDTV, which is going from cable box,...
Did the speaker relays light up ? and did you hear the third speaker relays ON clicking sound? If both no, DSP problem. If both yes, DIR problem. If the speaker relays lit up but NO speaker relay clicking sound, check relay driver +24V power supply.
Sep 17, 2017 | Yamaha RXV467 Receiver
My yamaha DSP AX1 amp does not work when audio is connected via optical or coaxial any suggestions how to correct this. no sound comes from any speaker except the subwoofer.
Are all the speakers turned off (set to None) in the speaker menu.(except the sub)?
2 channel direct analog stereo may still work, but any surround modes will use the speaker settings and the full DSP digital section.
Check also the input mode isn't incorrect - although if the sub is wired correctly and gives sound this can't be whats wrong.
Aug 26, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
I want to connect YST-Sw1500 sub woofer to the AX-596 amplifier .How can I do the connections .
on ur subwoofer u will see HPF output, connect this output to MAIN IN of ur power amp (first remove jumper between pre-out and main in from ur power amp) connect pre-out of ur power amp to input 2 L&R (Left is also for mono input). the HFP selector switch will cut off 80Hz or 100Hz to the main input depending on the position enabling u to have high frequency sound on your main speakers. connect the speakers to the main output terminal of ur power amp. do not connect speakers on the woofer ouput.
make sure u are using the right impedance speakers. do not switch speaker impedance selector while the unit is on.
Apr 04, 2010 | Yamaha AX-596 Amplifier
Rx-v463, no sound from rear speakers, and hookups
Sounds like an internal software issue dealing with this device.you may have to return it to the manufacture for this repair.
Jan 28, 2009 | Yamaha RX-V463 Receiver
Very low sound in main left chennel.
disconnect the cabel of left channel from your amp disconnect the cabel of right channel and put it in place of left channel if the problem goen your problem is in left speaker itself (cabel or speaker).if the problem excit the problem will be in amplifier output stage
Jan 28, 2008 | Yamaha DSP-AX1 10-Channel Amplifier
No center main volume
Make shure your initial setup on the amp is for center as an active speaker,then to check volume on center at zero. Possible to check speaker and wires for open or short.BIGRED
Sep 16, 2007 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha DSP-A2 Receiver Logo
513 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
robert landry
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
