Question about Archos Audio Players & Recorders
Archos 5 (250Gb) upgraded firmware from original Beta version. Then tried to load the 'Add-ons' resulted in unit upgrading the firmware again. But when switched back on keeps asking for a PIN tried default of 0000 with no joy...
  • 3 Answers
Start unit up, then quickly press volume up key. This then enables you to format the drive and reload the OS.
Posted on Nov 11, 2008
200E freezes up
A 200e that locks up usually need a memory and a firmware upgrade. The original 200's only have 32mb of internal memory. The upgraded mini print board that is used in the 730 has 64mb of memory. This 64mb board was used in the 200 as a upgrade and this stopped the lock up problem. Also over the years Bernina has improved the firmware and this also cures the lock up problem. The latest and probably last firmware version for the 200e is version 5, also called the cutwork version. The easiest thing for you to do would be to take your 200 to a dealer and have them install a 64mb mini print board and also upgrade your machines firmware to the latest version 5. Also if you have loaded embroidery designs in your machine, remove them as they use up the machines memory. When you get too many designs loaded even if you have a 64 MB board in your machine you can still have lockup problems.
May 28, 2014 | Bernina Artista 180
Archos 704
Did you try power cycling the unit?
Feb 05, 2008 | Archos 704 WiFi Digital Media Player
Hi Just got my new archos 101 8gb Spec said 2.2 but it came with2.0.54. on plugging in to PC the upgrade didnt happen so upgraded to 2.1.04 Everything that I have thrown at it works but I dont have...
Betty,
Archos has been saying Flash would be officially available for some time now, but it's still not out. There is a beta version that I'm using, works great for me:
First step to getting Flash working is to go to your settings menu, then Applications, then check the box to allow for Unknown Sources to be installed.
To get a Beta version of Flash working use this link (from your Archos tablet):
http://ge.tt/36fA44X
You should be prompted to install this APK file on your Archos 101 after it's downloaded, this will give you a decent version of Flash (it's taken from a Droid X which has similar hardware to the Archos 101).
The Version number of your Archos 101 firmware is different from the Android Operating System. Version 2.1.8 is the latest Archos firmware as of Feb 28, 2011, this is Android 2.2.1.
To force an update, you actually need to connect the Archos 101 to the internet, not to a PC. Once you're connected to a Wifi network and have access to the internet, go to your Settings, then scroll to the bottom to About Device. On this screen is a Firmware Update option, this will check for and download the latest. Once it's downloaded you'll be prompted to plug your tablet into the charger and restart it to apply the firmware.
Feb 05, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
Coe 102
Your post/description indicates a possible problem with the firmware. It would seem that the Archos 6052_bing.gif would load but fail to finish and there restarts itself. This could only be possible if somehow the firmware has been corrupted or you tried a firmware upgrade but failed halfway.
There are several versions of the 605, you need to determine which one you have.
Things you can try:
1. Do a soft reset. Press on the power button for about 15 seconds;
2. Do a full/hard reset by removing the batteries and pressing the master reset button;
3. Try again the Systems Recovery. You may need also to format the internal HD but that would mean you loose whatever data is inside.
Alternately, you may need to update/re-install the firmware. A more complete and better explained firmware update procedures are here. Briefly, you have to download and save in your PC the ???????.aos file (there are several versions of the firmware. You need to determine which one is appropriate to your model), connect your 605 to the PC, copy/paste (drag & drop) the said file to the Archos device listed in "My Computer" (you may have to overwrite the older copy), disconnect 605, proceed to System Settings, tap on "Update Firmware". Follow on screen instructions.
If the above is not corrective, am afraid that your unit has been partially bricked. Some have reported serious hardware or firmware problems with the 605 that would require replacement by the manufacturer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 12, 2010 | Archos 405 Digital Media Player
I have a US Robotics usr5461 wireless router. It
You might want to check your firmware version to make sure you have the lastest.
BETA Firmware Version 3.93.35.0.9This firmware fixes the following issues:
  • Printing issues with CUPS version 1.2.
USR5461a-v4.3.93.35.09.usr 1.8 MB 06-05-08
Firmware Version 3.93.35.0.8This firmware fixes the following issues:
  • DST (Daylight Saving time) Firewall issue with how IAC (Internet Access Control) works.
  • PPPoE server disconnect/reconnect
  • PPPoE inactivity timer
  • PPTP client disconnect/reconnect
  • backup/restore settings
Note: If upgrading from Version 3.91.37.0.3, follow these instructions before proceeding.
  1. With a thin tool, such as a paper clip, briefly press the RESET button on the back of the router.
  2. Wait about 30 seconds.
  3. Continue with instructions below.
Important: To ensure a successful upgrade, please perform the firmware upgrade from a client that is physically wired to the router. A wireless client may become disassociated from the router during the upgrade process resulting in an incomplete upgrade.
  1. Download this file to a temporary location on your computer's hard disk drive.
  2. To upgrade your USRobotics Wireless MAXg Router with all operating systems, open an Internet browser and enter the router's IP address. The default IP address of the router is 192.168.2.1
  3. Enter your User name and Password. Click OK.
  4. Click Device in the main menu.
  5. Under the "Upgrade Router" section, enter the location of the USR5461-v3.93.35.0.8.usr file in the text box, or click the Browse button to search for the file. Then click the Upgrade button to begin the upgrade process.
  6. When the upgrade process is complete, the router will reboot. To re-establish a connection with your router, wait approximately 15 seconds and click Continue.
USR5461-v3.93.35.0.8.usr 1.8 MB 10-25-06
Dec 31, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
NetGear RangeMax WPN824 Wireless Router (WPN824NAR) Wireless connection drops in and out regularly but frequency of this is unpredictable duration is usually a few seconds. Works find on direct ethernet...
Upgrade the Firmware of the router :
First you should check the version of you WPN824 (v1,v2 or v3). If there are no Version after the model number, it should be a version 1. Download the Firmware of your router given the correct version at this link :
http://kbserver.netgear.com/products/WPN824.asp
This is assuming that other wireless laptops has the same problem onyour wireless router. If other Laptops works great on your wirelessrouter without dropping any wireless connection, then you shouldconsider upgrading the wireless adapter on you own laptop.
***(If you haven't tried connecting otherwireless laptop wirelessly to the netgear, then you should try it firstto be sure that the netgear is the problem)
Steps on how to upgrade Netgear firmware :
  1. Download the correct file depending on your location and unzip the file to a convenient place such as your desktop.
  2. Log in the router at http://192.168.1.1 or http://192.168.0.1 (or www.routerlogin.net ) (Which ever will work)
  3. Default User name : admin / password : password
  4. Click Maintenance > Router Upgrade.
  5. Click Browse and locate the file you just downloaded.
  6. Click Upload. While the firmware is loading, do not interrupt the upgrade process.
***Therouter reboots when the upgrade is complete.
***Tocheck that the upgrade was successful, log in to the router again at http://192.168.1.1and check the firmware version.
***DONOT UPGRADE FIRMWARE USING A WIRELESS LAPTOP/PC
Oct 26, 2008 | Computers & Internet
I have a archos 504 that says recovery code 4.Then it asks if you would like to recover your system.The chocies are no ,repair disk and format disk. no matter what chocie you make nothing happens.
Your post/description indicates a possible problem with the firmware. It would seem that the Archos would load but fail to finish and there restarts itself. This could only be possible if somehow the firmware has been corrupted or you tried a firmware upgrade but failed halfway.
There are several versions and you need to determine which one you have.
Things you can try:
Alternately, you may need to update/re-install the firmware. A more complete and better explained firmware update procedures are here. Briefly, you have to download and save in your PC the ???????.aos file (there are several versions of the firmware. You need to determine which one is appropriate to your model), connect your Archos to the PC, copy/paste (drag & drop) the said file to the Archos device listed in "My Computer" (you may have to overwrite the older copy), disconnect the unit, proceed to System Settings, tap on "Update Firmware". Follow on screen instructions.
If the above is not corrective, am afraid that your unit has been partially bricked. Some have reported serious hardware or firmware problems with the Archos that would require replacement by the manufacturer.
Apr 05, 2008 | Audio Players & Recorders
Firmware Upgrade Failed
Firmware upgrade is a simple but a delicate procedure. Make sure you are loading the correct firmware. You should get your firmware from the website of your router. Installing a THIRD PARTY firmware to your router voids the warranty of your router. Here is a tip for a successful firmware upgrade. BEFORE FIRMWARE UPGRADE(push the reset button of the router for 30 seconds then unplug the power of the router for 10 seconds). Upgrade the firmware. After the upgrade push the reset button again for 30seconds, unplug power for 10 seconds.
Mar 10, 2008 | Linksys Wireless-G Broadband Router
Firmware upgrade results in arclibrary boot failure
I managed to overcome the problem by doing a factory reset. Unfortunately doing this initially created more problems in that on reboot the main screen appearance looked as it should but was almost inoperable. When the usb cable was connected to my pc the disc did appear on My Computer . The system folder was only 1MB. By good fortune I had copied and saved my Archos files before I carried out the factory reset. Copying the original system files ( about 20MB) back to my Archos returned normal behaviour. Further, two additional buttons appeared. One was a manual arclibrary update button and the other a USB setup button . I cannot get file transfer to operate under windows media player mode and Windows media player 11. No problem though. I use PC hard drive mode and carry out a manual arclibrary update. None of this was possible prior to the factory reset. I believe I would still be having serious problems had I not saved and restored my system files
Feb 08, 2008 | Archos 605 WiFi Digital Media Player
128 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
