Question about Sony NWZ-S615F Walkman Video MP3 Player
Help!!!!!!!pls help! i accidentally deleted the folders for all the files..how do i ever restore them they're not even in the recycle bin..pls help...
Connect to your PC.
Open up MY COMPUTER. Select the Walkman device. Re-create the folders as if you were doing folders on your hard drive.
Posted on Nov 09, 2008
What can I do to rescue data deleted by pressing "Shift+ Delete" on Windows 7?
Using Shift+Delete to remove files/folders bypasses the recycle bin which is your normal means of recovering accidentally deleted files. You can go to download.com and search for file recovery programs. Some are available that will search your hard drive and can maybe recover what you lost. It is important to do so as quickly as possible because once files are permanently deleted on the hard drive, the sectors that they occupied are no longer protected and can be overwritten by any program or file.
Dec 25, 2014 | Computers & Internet
Is there any possibilities to recover the deleted files on the recycle bin after empty the recycle bin? What is the solution?
Yes, it is technically possible to recover any deleted file (Even those removed from the Recycle Bin) by using recovery software.
Check out how to recover deleted files from recycle bin from link blow.
http://www.asoftech.com/articles/how-to-recover-files-deleted-from-recycle-bin.html
Jul 02, 2011 | HP Computers & Internet
I deleted the files in recycle bin
Yes, it is technically possible to recover any deleted file (Even those removed from the Recycle Bin) by using file recovery software.
Check out the data recovery software called asoftech data recovery from link blow.
http://www.asoftech.com/adr/
Apr 20, 2011 | Computers & Internet
Accidentally uninstalled Games directory, can I get a replacement?
if you accidently delete the games folder, you can restore it from the recycle bin. To do this double click on recycle bin then right-click on games folder and choose restore, it will restore it at its original place.
If it is not in recycle bin : you need other software to restore it. I can suggest "Active Partition Recovery" that also contains a file recovery application and is about 20.00$ you can download it on the web if you seach for in google.
Sep 04, 2009 | Acer Windows Vista TL-562G Notebook
How to delete a folder of files in MS Works but not the files?
Right click on the folder then click delete; comfirm then once deleted see if it messes anything up with MS works, if not go into the Bin and empty recycle bin; if there is an error you probably deleted the wrong file, just simply go into the recycle bin and restore all items.
Apr 26, 2009 | Computers & Internet
Recycle bin
Check out the data recovery software from link blow.
Aug 26, 2008 | Kodak EasyShare C360 Digital Camera
I deleted the recycle icon by accident i would like to get it back please?
Assuming you didn’t turn off all your desktop icons (right-click your desktop, choose View from the menu, and choose Show Desktop Icons if it doesn’t have a check next to it, which will turn them back on), it’s easy to get back, so stop your sweating and follow these simple steps.
  1. Right-click on your desktop and choose Personalize
  2. Click on the Change Desktop Icons link in the upper left hand corner
  3. In the Desktop Icons Settings window, check the Recycle Bin box and click OK
WORKAROUND in case the above does not work loadTOCNode(1, 'workaround'); If you cannot restore the Recycle Bin by using the resolutions that are listed in this article, work around this issue by creating a shortcut to the Recycle Bin: 1. Click Start, and then click My Computer. 2. On the Tools menu, click Folder Options. 3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box. 4. Click Yes when the warning message appears, and then click OK to close the Folder Options dialog box. 5. Click Folders on the toolbar.
Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons. 6. In the left pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop. 7. On the Tools menu, click Folder Options. 8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.Note This procedure does not re-create the original icon. However, this procedure restores most of the features of the Recycle Bin, including the following: • Delete a file by dragging it to the Recycle Bin icon on your Desktop. • Retrieve a file that you deleted by double-clicking the Recycle Bin icon on your Desktop, right-clicking the file that you want to retrieve, and then clicking Restore. • Empty the Recycle Bin by right-clicking the Recycle Bin icon on your Desktop, and then clicking Empty Recycle Bin. When you use these step to work around the problem, you cannot right-click the Recycle Bin shortcut to access the Recycle Bin Properties. To set properties for the Recycle Bin, follow these steps: 1. Double-click the Recycle Bin shortcut on the Desktop. The Recycle Bin folder opens. 2. In the upper left corner of the Recycle Bin folder, right-click the Recycle Bin icon, and then click Properties.
Aug 20, 2008 | Gateway Computers & Internet
Recycle bin
Mar 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Recycle bin got deleted
Sony NWZ-S615F Walkman Video MP3 Player Logo
37 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
