Question about EliteGroup 661FX-M7 (661FXM7V11) Motherboard
661FX-M7 Problems Hello, i have just installed this motherboard into a new system, when i power the system up the fan seems to instantly start running at 100% which im certain is not right. Also this is followed by a long beep, then a pause and another long beep ect, and no signal is getting sent from the pc to the monitor. Any solutions or ideas?
  • 1 more comment
  • danhss Nov 03, 2008
    Sorry i should also add that i have unplugged all the I/O devices with still no luck, and i have tried the RAM in a different system and it seems to be working fine.
    And fitted a same rated and power output PSU
  • Dick
    Dick May 11, 2010
    What does your manual say that beep code indicates? Nothing in the manual about it? What does the manufacturer's website and google say it indicates?
    Problem Solver:
  • 10 Answers
The fan running at 100% may be fine, depending on how you hooked it up. However, you seem to have a conflict with the video. The short beep you hear is usually the motherboard recognizing the boot drive. The long beep means something isn't configured correctly possibly the video card...?
Look in the owners manual for the keystroke to get into the bios settings. Then right when you turn it on, before the long beep, hit that keystroke and get into the bios and check settings.
NOTE: if you don't get any video when you enter the bios, there is clearly a compatibility issue with your video. All video cards should put out signal for the bios - even if the proper drivers aren't loaded for Windows.
Posted on Nov 15, 2009
HP Compaq Presario SR1738NX will turn on, but nothing besides the fans seem to work
Unless you are familiar with removing and installing the internal components of the computer it is unlikely that you will be able to fix this computer yourself. It sounds like there is a hardware fault. It could be as simple as something overheating or even a fan cable coming loose but at almost 10 years old it's amazing the system is still going. I'm sorry I don't have a simple answer to give you to make your computer just work again.
Good luck.
Feb 02, 2014 | HP Compaq Presario SR1738nx-b Desktop...
Hello, my system has Asrock P4I45GV Motherboard.
your possessor fan dos not properly work or fan casein do not properly instal or your power supply faulty.
Sep 04, 2013 | Asrock P4I45GV R5 Motherboard
INTEL Core i5-750 (BX80605I5750) 2.66ghz quad-core processor w/8mb cache socket 1156 retail boxed w/cooling fan (Retail) =INTEL BOXDH55HC=CRUCIAL 4GB DDR3 1333-(2GB x 2)=ASSEMBLE/TEST This is what im...
if that's the case it seems you need utility to clean up your system...try installing one ...spybot or malwarebytes are my best a free version and see what it takes...
Sep 08, 2010 | Intel DH55HC Motherboard
Gateway gt4016 won't boot. Fan runs but nothing else
Try a different CPU. and also try a completely different set of know good memory. If after this the system still doesn't boot up then then the motherboard they installed in defective and if that the case? Get your money back.
Jun 16, 2009 | Gateway GT4016 Desktop PC
Motherboard will not start
It seems like there could be a short in the system. Check to make sure that the board is tight in the case, and that no foreign objects are causing the motherboard to short. If there is no obvious problem and the motherboard is new, I would return it as a defect.
May 12, 2009 | Gigabyte Computers & Internet
My emachine shuts itself off, fan working ok, help help
Hi there. When you turn on your system, enter the BIOS setup screen. Depending on your BIOS, you may have a section that tells you the PC Health Status. If you do, you can check what temp your processor is, and it may even let you adjust the warning temp, (it may be set too low). Some BIOS's will shut down a machine automatically if this temp is reached, to save the integrity of the system.
Yes, you may have a faulty power supply. Try testing it with another and see if the same thing happens. Also, make sure that your power supply is connected to your motherboard properly. Easiest way is to just disconnect it from the motherboard, check for any bent/broken pins, then just click it firmly back into place.
If you need me to clarify anything, just post a comment.
Apr 20, 2009 | Computers & Internet
Motherboar fail, no video, power supply ok help
Firstly, remove the RAM and turn on the system, if you hear the beep sound continuously that means everything is perfect expect RAM.
Clean the track of RAM at both sides by pencil eraser completely.
Also clean the port of RAM.
Secondly reinstall the CPU with CPU FAN and also clean the FAN.
Third one is that remove all the add-on's card and than turn on the system.
Apr 12, 2009 | Biostar P4M800 Pro-M7 Socket 775 mATX MB...
Hello devyani,
i think the problem is the hard disk.bring a new one and install a fresh copy of operating system
Jul 21, 2008 | Intel Motherboard
Compaq eve n610c
i think you need to take your laptop to computer shop for repairing. your system's operating system might be crash so you need to do either recovery or do a fresh installation of opearting system by putting the os cd in your cd/dvd drive.
Jul 12, 2008 | Computers & Internet
hello, it seems that your laptops vga or motherboard is damaged and so it wont start up. repairs required, a new motherboard costs from 100 to 1000 usd
contat your dealer, or a local professional / toshiba.
Mar 30, 2008 | Toshiba Satellite A135-S2276 Notebook
EliteGroup 661FX-M7 (661FXM7V11) Motherboard Logo
388 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
