Question about Aiwa CDC-MP3 CD Player
Unit will not power up and when door is lowered or removed there is a red light blinking
So for a bit it worked fine, THEN it would not tune. NOW it will not even power up! I have not ripped it out yet, but thought I'd post here first. When the face is removed there is a red light in the middle of the back end which blinks.....I imagine that is to indicate it's got power, but then again that's just a wild guess. Anyway have any thoughts? Thanks, David West Palm Beach, FL
  • 78 Answers
The light behind the fascia tells you that it has a permanent 12v supply but not necessarily a switched 12v supply, so if you remove the radio and check if you get a 12v positive supply when you turn on your ignition, if not there is your problem
Posted on Nov 21, 2007
Sharp Aquos LC45GX6U & TU-GD10U. The unit doesn't power up, and has a red blinking light from the moment you plug it in. The unit works fine in service mode.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 27, 2015 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
The light on the Garage door blinks but doesn't stay on.
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
Garage door light blinks but doesn't stay on
(Winston-Salem, NC)
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
My tv worked fine bulb went out replaced it now it won't come on the green power light blinks then goes to the lamp and stays on red
Be sure the lamp door is shut properly and the door screw is in place and tight. If you had taken the entire back off, be sure all the screws are in it especially the ones on the lower right bottom .
I hope this helps,
Skyassoc
Dec 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
NEC VT595 Projector - Status light blinks red constantly
We had this same problem. In our case it turned out that a little bit of plastic broke off of a tab on the inside of the plastic lamp cover. Without that piece it was not pressing against the sensor that tells the projector that the lamp cover is closed. Without that, it doesn't start. We got it working again by drilling a little hole and sticking a screw through that spot to replace the missing plastic, but I'd rather replace the cover if I could. Really dumb that a little piece of plastic can mess up thousands of dollars worth of equipment (Smartboard 2000i).
May 26, 2010 | NEC VT595 LCD Projector
The ice maker is not working and red blinks on the
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Apr 01, 2010 | KitchenAid KSCS25FKSS Side by Side...
No Picture or sound
The lamp cover door was not secured tightly. Door does not "push" shut easily. Got a little rough with it and latched it shut, then the tv worked fine.
Jan 27, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Aiwa CDC-MP3 CD Player Logo
106 people viewed this question
Top Aiwa Car Audio & Video Experts
fordexpert
Andrew Taylor
Andrew Taylor
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
