Question about Xerox DocuColor 12 Printer
Fiery xp12 is loading without end
After power switch Fiery xp12 is loading and loading whithout ready for printing
  • 1 more comment
  • Anonymous Nov 05, 2008
    Same as above. X12 boots into NT but just hangs at loading forever
  • gumaaura Nov 14, 2008
    the Fiery server start rebooting itself, it happen few times, after that its loading  ......     no end
  • TheCasaKID Nov 17, 2008
    Fiery X12 Is loading without end.
    If i start the Fiery x12 i pushed simultan the fourth button from the right side of the display a fwe time.
    The menu appear.
    What is the next step to do?
    1.Install software
    2.Restore Backup
    3. Install Option
    4. Starting
    If i push starting, the Fiery x12 load without end.
Hello...
I've result my problem. The Hard Disk from the Fierry x12 was deffect.
The Technician from Xerox have replaced this.
Have thanks for all answeres...
Posted on Nov 20, 2008
  • 62 Answers
The only thing to do is reload from the software you(hopefully) get when you got the machine delivered. 3 discs saying system software, put disc 1 in and recycle the power. follow the on-screen instructions and then it will eventually load having used all 3 discs. It takes ages to reload as this fiery is really slow, but should do it. If it doesn't work then the hard drive, generally, is the best bet to replace. (the fiery can't see more than 8gb hard drive!)
Posted on Nov 19, 2008
    Problem Solver:
  • 7 Answers
Have you checked the paper trays are filled and ready? Also unplug for a couple of min's and see if that clears the memory as it may be trying to forfill a print request the never compleated.... Had this happen a few times....
Hope this helps.....
Posted on Nov 03, 2008
Hi Dear Can use xerox DC12 with MAC OS without
There are some Mac OS drivers.I think your printer is not compatible with Mac.
The level of functionality and compatibility with the new Mac OS X 10.6 drivers are identified in the following document.
> For a list of Xerox equipment compatible with Mac OS X 10.6, click here.
DocuColor 12 Copier/Printer
Dec 14, 2010 | Xerox DocuColor 12 Printer
How to fast print image? my problem is a image size 5.71 mb then in printer show 85.5 mb after 4 minutes it print! this prociger is too long? i have P4 dual core pc with 2 mb ram its harware problem? what...
I suggest you get used to it or upgrade to a newer machine. I have 2 doc 12 and files that took 45 minutes to rip with the XP12 fiery and 20 minutes with the XP12e fiery or about 2 minutes my new equipment
Apr 06, 2010 | Xerox DocuColor 12 Printer
Fiery patches
hi better u try to xerox.com/drivers..
Oct 01, 2008 | Xerox DocuColor 12 Printer
First 30 pages of a print run after 24hrs idle are blank
don't upgrade the xp, it runs a limited version to ensure that the command workstation works ok. A reload is probably in order to start again. Any updates can generally be found on the xerox website, and installed via command workstation
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Xerox Fiery Xp12 - Problem (INVALID LICENCE) apears on the screen
You will need to use what came with your machine.
The note from Xerox states this.
NOTE: You will need the Fiery Restore / Update Server Software CD and the User Documentation v2.0 CD that came with your EX12 v2.0 Software
And here is the loading process
  1. Visually check to make sure the Fiery LCD is at the Idle screen before you proceed. This will make sure the Fiery is not in use.
  2. Insert the Fiery Restore / Update Server Software CD into the Fiery EX12.
  3. Press [Menu] button on the Fiery Server.
  4. Press the [Down arrow] button.
  5. Press the [Shut Down] button.
  6. Press the [Reboot System] button. The message 'Rebooting System' will display and disappear after a few moments. The Fiery Server will reboot and complete internal testing. The Restore / Update CD menu will be displayed.
    NOTE: Ignore the message 'It's now safe to power off the system'.
  7. Press the [Up arrow] or [Down arrow] button to scroll to 'Restore System' so this is highlighted. Press the [OK] button. The 'All data will be Deleted. Continue?' message will be displayed.
  8. Press the [Up arrow] or [Down arrow] button to scroll to 'Yes' so this is highlighted. Press the [OK] button. The 'Restoring System...' message will be displayed.
    NOTE: The System Restore will take approximately 7 minutes, during this time the message 'Restoring System...' will continue to be displayed.
  9. Press the [OK] button when the 'Restore Complete!' message is displayed.
  10. Press the [Up arrow] or [Down arrow] button to scroll to 'Exit' so this is highlighted. Press the [OK] button.
  11. Remove Fiery Restore / Update Server Software CD from the EX12.
  12. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
    NOTE: Wait 10 seconds before powering ON.
  13. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  14. The EX12 will prompt you to insert the User Documentation CD. Insert the CD and the Fiery will continue with the process. When the process is complete, the Fiery LCD will display the message 'Please remove CD'.
  15. Remove the User Documentation CD
  16. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
  17. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  18. Using the Configuration Report as reference, re-enter the network settings on the EX12.
  19. Install any required patches, as needed. Refer to the Updated Information section on the Configuration Report.
  20. If needed, restore any data that you previously archived. See the Related Items.
Jan 10, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
982 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
