Question about Ascaso Dream Espresso Machine
No steam on the Dream
I am not getting enough steam pressure. The wand has been cleaned, descalled etc. what else can I do?
  • 2 more comments
  • debi5 Nov 03, 2008
    The steam comes out of the connection where the wand moves. There is an "o" ring there but it appears to be ok. There are two of those and I dont know where they both go. One came off when I took the wand off.
    The settings are correct. Ascaso Dream M.F You did not answer the o ring issue.
    If I put the o ring where it seems it should go it blocks the hole so please advise where it should be. Plus, is there a service center in MN that I can taske this to, or give me some tips to take it apart.
    At least you gave me a place to go to for the answers. Thank you
  • Ascaso Master
  • 19,396 Answers
Check that the steam wand is not obstructed.
Perform a complete self cleaning procedure (see manual).
If there is still not enough pressure there are to possible reasons:
The heating element is defective, and in htis case the brew will also be weaker than normal.
There is a leak on the steam lines, in this case the machine must be take apart and steam hoses, joints and gaskets inspected.
Posted on Nov 03, 2008
    Brigadier General:
  • 6,966 Answers
Initially, pls check for steam leaks. This model has been known to have issues with leaks preventing it from reaching the correct pressure/temperature. Since the leak could be visually checked, it would be a matter of determining at what point/component would the steam be coming out other than designated point. Often, it would be a joint with a rubber seal or a tubing entry point.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 03, 2008
    Both o-rings would go to the same tubing. In some versions, there would be an indentation or groove for the o-ring to slip into. Due to the high pressure developed, the double o-ring was used.
  • Louie  Role
    If for some reasons the o-rings or rubber seals would be blocking the port openings, then it is either:
    • the rubber has expanded;
    • the seat where the o-ring goes has still some build-up.
    Due to manufacturer's security, the service manuals are restricted. Offhand, your best bet would be to consult Ascaso USA contacts. Pls click here.
    Genius:
  • 1,011 Answers
Dear,
did u check the flow of water correctly or not...
plz check and tell me
regards,
    Brigadier General:
  • 3,614 Answers
What is the xact model..?
check and be sure that you have loaded the right amount of water on the unit. and the correct settings has been made.
Low steam pressure
descale the heating elements with vinnegar.
Mar 20, 2014 | Rancilio Silvia Espresso Machine
Water only comes out of the steam wand when machine is fully heated and the steam switch is off and the coffee switch is on.
Sounds like that the group may be blocked. Try descaling.If model has a solenoid valve then try backflushing. JURA descaling tablets
Aug 06, 2013 | Ascaso Dream Espresso Machine
Ascaso dream wand wont heat or steam
You should descale the machine, as you may have a blockage in the steam tap.
When descaling make sure that the descaled water goes through the steam wand as well as the group. JURA descaling tablets
Mar 26, 2017 | Ascaso Dream Espresso Machine
I have an Ascaso Steel Duo Professional semi-automatic espresso machine - the steam wand is restricted. how do I remove it to clean?
Hi There, If your ascaso steel duo is not producing steam,
Could be that:
The thermoblock may be blocked - Try descaling.
Steam wand may be blocked - try removing steam nozzle/steam wand and submerge in hot soapy water.
May 01, 2011 | Ascaso DUO PROF Stainless Steel Espresso...
Cant make hot milk or foam ascaso dream the wand doesnt work it just stopped. also my coffee is not hot, only lukewarm ive opened it up and everything looks ok, its all just electrics all of which look...
Hi Mike,
You may have 2 issues.
Steam wand may be blocked;
Try descaling the machine 1st before you do any thing else.
1.Try removing the steam tip, if you don't get steam with tip removed, try removing wand, if you don't get steam then the steam pin may be blocked.
If after descaling coffee is still jst warm you could replace thermostats http://www.bluestarcoffee.eu/ascaso--boiler-thermostats-x-2-193-p.asp
If you still don't have steam after descaling and replacing thermostats then you may need to replace the o rings on steam pin.
http://www.bluestarcoffee.eu/ascaso-gasket-kit-dream-arc-basic-114-p.asp
Ascaso descale sachets 10
Mar 31, 2011 | Ascaso Dream Espresso Machine
What are the specific instructions on how to descale our Gaggia coffee maker? I have the Dezcal descaler pouches.
Can't give specific instructions without knowing which model it is. If it is a super automatic such as the Titanium, you put it into descale mode and then follow the prompts on the display.
If you have a semi automatic such as a Classic or Coffee or Carezza etc. you simply mix the dezcal with warm water in the reservoir and run the pump a little to spurt a few ounces of water out the brew group - and some out the steam wand. Then stop the pump and let it sit for a few minutes - and then start the pump and spurt a little more out the brew group and the steam wand - and so on for about 20 minutes or so until the tank is empty. You get the best results if you let the solution sit in the boiler for a few minutes (maybe 5) between each time you run a few ounces out. After you've emptied the reservoir, rinse the reservoir really well and fill it with clean water and run the whole tank of water through the group and the steam wand (mostly through the group head). I like to rinse a few tanks full just so it is really rinsed well - but one or two tanks is supposed to be enough.
If your machine is a Titanium or Platinum, the readout will tell you what to do - they usually only spurt descaler out the steam wand and not out the brew spout since all the brew parts are plastic and don't need to be descaled. And the steam wand routes the descaler through both boilers so you get all the important parts that way. It'll keep cycling you through opening the steam valve and then waiting 5 minutes and then opening it again - until the tank is run empty (so you may want to mix up the dezcal using less than a full tank (more concentrated) - otherwise it'll take a long time to finish. The dezcal package will recommend how much warm water to use for a package.
The titanium will prompt you through the rinse cycle too - just clean out the tank after you've run all the dezcal through the system - rinse the tank really well and then fill it with clean water and let the machine do the rinse cycle - it will run the entire tank until it is empty. Then you will want to refill the tank with clean water and run a few blank shots - make sure the water from a blank shot is tasting like pure water and doesn't have a citric acid (lemon juice) taste to it - if it tastes like citric acid then you still need to rinse more. The citric acid is not harmful to you - but it will make the coffee taste a bit funny and the milk will foam up funny when you steam it.
Sep 21, 2010 | Gaggia Titanium Espresso Machine
Can't get steam from the a Starbucks Saeco Italila Digital Auto
Hi If you can get water to flow from the wand, you can descale the machine. You might have a bad steam boiler. There is also a fuse on the boiler that might be bad. Set your water hardness to 4 to keep the machine working for a long time. Descale more often than not enough.
Jan 26, 2010 | Starbucks Saeco Italia Digital Barista...
Frother stopped working. No pressure, Cleaned & descaled system.
If you have cleared the end of the wand with a paperclip then it is possible that the steam boiler is damaged or the thermostat on the boiler is damaged.
Oct 05, 2009 | Spidem Trevi Combi Plus S2231 Espresso...
I have a expresso machine ESP6. it is not letting out enough steam or frothing milk. what's the problem and how to fix it?
The steaming wand's tip gets gunked up with milk so make sure to clear that with a needle first. Make sure the machine is fully heated before using the stream function (should have an indicator light). Typically this model will expel water first, then a low pressure steam. After about 30 - 40 seconds it should produce meduim pressure steam. Make sure the pump is making the proper clunk, clunk sound or it could be failing. Also, the steam wand arm may be obstructed and descaler solution will have to be used to remove the deposits. Hope this helps.
Sep 15, 2008 | Breville ESP8XL Espresso Machine
Steam problem
If the milk scalds, you're getting it hot enough. It sounds like you're not incorporating enough air into the milk when frothing.
Make sure that the holes in the tip of the steam wand are clear. Soak in water for 5-10 min. and wipe with a cloth (no abrasives) and clear the holes with a paper clip end. Blow the wand out nice and hard.
How is your steam pressure? It should be about 1.2 bar.
It could also be your technique. The wand should never be more than 3 cm into the milk. For cappuccino froth, keep the tip right at the surface of the milk, lowering the pitcher as the level rises. You should hear a "shushing" sound, no squealing.
Aug 28, 2007 | Rancilio Silvia Espresso Machine
Ascaso Dream Espresso Machine Logo
757 people viewed this question
Top Ascaso Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you an Ascaso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
