Question about Rockford Fosgate Punch P4004 Car Audio Amplifier
AMP CLICKING OUT
I have a Rockford Fosgate p4004 amp that has been in my truck for about 6 months, just 4 days ago it started going into safe mode if I turn the volme above 9. It is running my component speakers and I have another amp that is running my sub, that one is working fine.I have 5 guage wire powering it. What could be causeing it to click out? I have already pulled it out and checked to make sure there was nothing distorted on the bored and made sure all my wiring was tight but that hasnt helped.
    President:
  • 3,130 Answers
Could be the sub has a shorted or rubbing voice coil, the speaker wires could have rubbed and touching or pinched with the chassis or ground, or the amp has a idle bias proble. The first two can be checked in the vehicle, the last one should be set up on a bench with a steady power supply and speaker load resistors attached and a osilliscope attached to the load resistors and a variable 400 to 1000 HZ tone at the input. You the raise the input and see where the waveform statrts to clip. If it starts to clip right away most likly there is a problem in the output or drivers or the connecting componets.
Posted on Sep 28, 2006
Wiring Rockford p4004 amp
how to install or where to install?
May 18, 2014 | Rockford Fosgate Car Audio & Video
Rockford fosgate p4004
You need to check the ohms on your subs an amp . try unbridgen the amp . Go to Rockford Fosgate dot com on the amplifier wiring diagram hopefully that helps 6_28_2013_8_51_12_am.jpg
Jun 18, 2013 | Audio Players & Recorders
I have a Rockford fosgate P4004 with two 12'
I think you are right about the "fried" part. It would have to be opened up and repaired to be able to use it again
Oct 29, 2012 | Car Audio & Video
I have a rockford p4004 and the protection light is staying on and am not getting anything out of the amp to my subs. what can i do. i hooked up a different amp to it and it worked fine.
The unit is internally grounded. Something has broken inside and grounding out the power, the amp will need to be serviced or trashed. Try calling Fosgate. They may have a serviceman or "fix it" department
Nov 05, 2011 | Rockford Fosgate Punch P4004 Car Audio...
Audio cutting in and out protect light turning on Rockford fosgate p4004
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping. Try adding a capa A thumbs up would be greatly appreciated if this answer is helpful to you. audio-cutting-in-out-protect-light-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
Jun 20, 2010 | Rockford Fosgate Punch P4004 Car Audio...
I need parts for an amp
callem up im sure someone in tech dept. call help ya jus cus its not on a screen dosent mean rockford doesnt have it....i mean they made the amp n all .....u know
May 14, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Its a shame that you dont have the covers for this awesome amp. You can run amps without the covers but if metal crosses any conductors your screwed. If you try emailing Rockford they might be able to help(inquiry.sales@rockfordcorp.com). I am cheap and would either buy one that doesn't work and use covers or make a box to bolt amp into. If you build a little box make sure to vent it so the amp can cool.
Mar 23, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Is this ok?
yes 2ohm should be fine for that amp no problem
But dont bridge it any lower than 2 ohms.
Nov 26, 2008 | Rockford Fosgate Punch P4004 Car Audio...
P4004 - Blown Components
if burned components are on output stage or amplifier section on board..Then look at the oposite side of amp..Both amplifier section should be a mirror image oof componentc from other..that way you can know the values of parts.If they are on power supply section ..Then you might need manual if available..
Dec 23, 2007 | Rockford Fosgate Punch P4004 Car Audio...
In thermal mode
if i understand correctly its possible that the amp shorted out during the bump...check all connections and fuses, if all is fine then the amp needs repaired.....watch out for those bumps next time.
Nov 11, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Rockford Fosgate Punch P4004 Car Audio Amplifier Logo
139 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
