Question about Beko 24 in. D3421F Free-standing Dishwasher
Beko washing machine
My beko has filled with water for the wash, the programe clock shows 18 minuets for example and the wash begins but the clock does not run down and the machine just washes and washes and washes, I tried to altar the dial to drain etc but it just keeps on washing so you have to turn the machine off, the only way of getting the water out is threw the filter which is not blocked, this causes an awful mess, HELP!
    Scholar:
  • 123 Answers
Hi there.......this problem could be caused by a failed heater element ...if the element is not heating the machine will just wash wash etc...the front panel will have to be removed to check the heater element....if the element is ok...check the heater NTC ( little white plug in the heater element)...if all ok here....then you have a main PCB board failure....
it may be more economic to have beko send an engineer to you...
regards Sir Galahad
Posted on Sep 03, 2009
I have a 4 year old Beko washing machine model excellence 71442W It is displaying a error code 18 and want to know how to reset it,holding start button is not working. Thanks
That is a code for water fill issues. Here is a repair video which will help you find the exact problem--and fix it yourself:
Sep 17, 2017 | Beko Washing Machines
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
How do I open the door of my beko washing machine, when it stopped half way through washing cycle
I would think unplug and wait should hear a click after a few minuets then it should open
Feb 23, 2015 | Beko Washing Machines
Why wont my beko washing machine will not fill up with water when put on a wash cycle what can the problem be
If you are able to select the program and the ON button is accepted but no water then either the water inlet tap is shut off or the water inlet valve is faulty. Need full model number to provide more information.
Sep 04, 2014 | Beko Washing Machines
Beko washing machine wme7247w showing E08
Beko Washing machine? What is that a French Model? LOL
Your water inlet valves (hot/cold) are bad and need replacing.
Jan 19, 2014 | Beko WME7247W Washing Machine
BEKO WME8227 fills with Water then program stops, machine will drain but not spin
does it drain within 90sec if not look at the pump and the two pipes to it
or check motor brushes
Sep 20, 2013 | Beko WME7247W Washing Machine
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Washing machine wont begin a programme
Hi sam this might help if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
May 17, 2012 | Beko Washing Machines
Beko washing machine WME 7267 fills with water but will not continue through the cycle
See if the filter is clean or if the exhaust hose isn't blocked.
Feb 23, 2012 | Beko Washing Machines
Beko 24 in. D3421F Free-standing Dishwasher Logo
732 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Eric Taylor
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
