Question about JVC TH-M606 System
Musical outut is loud and clear, voice can hardly be heard
If I attempt to turn the sound level up so that I can hear voices, a click is heard in the large box and the green light goes off - then there is absolutely NO SOUND AT ALL
  • Anonymous Aug 31, 2008
    Subwoofer turns off by itself (taking all the sound with it) when you play anything semi-loud (35-40+). Started happening after 2.5-3 years of use. Lame!!!
  • 979 Answers
Reset your surround parameters; you are asking too much out of your system, as it's going into "protection mode"....accordianman
Posted on Jan 14, 2008
Cannot hear my voice in the headset when speaking
Been a long time since I used a head set but never heard my own voice through it when speaking.
Jun 03, 2017 | Creative Labs HS-600 Headset
I just bought the Vizio E421VA and I am contemplating take it back. The volume levels are horribly inconsistent. On some channels I can have the volume level at 2 and its loud, on others you put it to 20...
we have had the same problem and I suggested to Hubby that we had better return it soon. He did some research and we are trying this: use the TV remote and press the center button "Select", Choose Audio, Make sure True Volume is set to On. I've only been watching for an hour but it very well may have solved the problem. Hope it works.
Feb 07, 2011 | Vizio E421VA 42 in. LCD TV
I got sound system problem in chatting
go to control panel and click on sound icon. there you will see speaker and microphone properties check on microphone voice level. if it is very low or mute other party cant listen to ur voice so increase it a bit little. this can solve ur problem
Apr 13, 2010 | Sony VAIO VGN-CR220E/P Notebook
I am getting the voice from other end & my voice is not going
Mic issues can be tricky. Knowing what operating system you are using would help diagnose the issue.
First the simple things. Make sure your mic is plugged into the correct jack. It should be red. Second, you need to open your sound mixer and make sure your mic is not muted or the volume turned all the way down. Either of these will cause you not to be heard.
You can also open the sound settings in your control panel, it is the icon that looks like a speaker if you are using Vista/7. Under the recording tab, make sure you see your mic/headphones/etc (what ever you are using as a mic) in the list. Make sure it has a green check mark on it indicating it is the default device. You can then double click it and select the levels tab to ensure your volume is not all the way down on the mic. You can also click on the listen tab. Place a check in the listen to this device box and click apply. You should now be able to hear your own voice as you speak into the mic over your speakers. It gives you a way to troubleshoot the mic functions. Once you can hear your voice, remove the check and click apply again to return to normal.
Make sure you can hear your voice without Google Talk. It most likely is not the application causing your problem. If, however, your mic works on everything but Google Talk, then we need to do more troubleshooting. Let me know if this resolves your issue.
Mar 06, 2010 | Google Talk
Echo occurs on voice chat
just down the mic volume and see als run the sound diagone test.
Sep 08, 2009 | Logitech QuickCam Communicate STX Personal...
The background music is louder than the voices
in the menu there should be some type of set up for this, it will most times show you on your screen a room with all the speakers in it and ask you to hit test then it will shoot a white noise type of sound around to each speaker and ask if you heard it, there are then adjustments you can make for the front, rear, and side sperkers independent of one another.
Mar 23, 2009 | LG LHT854 Theater System
Voices cannot be heard clearly when playing dvd
erm,, when you say you cant hear voices clearly. do you mean that they seem to be a little lower in "obviousness" than they should be or are they way down ther as the background level is so much higher.
1. a little lower means you need to bring the trebble up and the bass down and bring up the centre and reduce the surround , this is basically tuning the sytem to your room.
you also need to check the dvd setting for audio out to ensure that the settings for the audio on the dvd are set to 5.1 ( if the little black spare connector is connected to your dvd player) or else set to stereo for "normal " palyback.
2. if the voice is way down compared to background sound track.
are you using an amp for the bass channel, this may need to be turned down. or the thing that looks like a spare connector on the end of the cable going to your cd5 unit is not correctly installed. can you tell me what the set up is.
Jan 19, 2008 | Bose Lifestyle 8 series II System
I can't hear voice
chek sound settings and sound level. thts very common. no problm with phn
Jan 13, 2008 | Motorola Mobility E680 Handheld
Sound card driver problem
If you are using xp
Go to control panel
Click on sounds and audio devices
click on voice
See voice playback?
click on volume make sure there is not a check mark in mute under microphone
Do the same for voice recording
and check the volume levels on both
Hope this helps
Oct 20, 2007 | Computers & Internet
JVC TH-M606 System Logo
103 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
