Question about Ovens
Setting Clock on a wall double oven
I have a Neef double wall oven. Model unknown. No documentation. During my absence the 2 oven control displays started to blink with time set at 0.00. Also, microwave oven cannot operate. How do I reset the control diplays (set time, etc). There are no buttons on the control panel showing any sort of clock setting icon. My oven is a built in Cooker (brand name), FE661BEX and there is no instruction manual.
I haven't figured out how to set the clock and without this there is nothing going - it's on the blink and shows 'automatic'.
Does anyone know how to set it or can tell me where I get a manual?
Thanks
  • kauliki Nov 03, 2008
    Something went wrong with my post. Here's what it is about:
    Thanks
  • 213 Answers
SOURCE: thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Posted on Nov 19, 2007
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
dutchman05
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
tborn6
  • 700 Answers
SOURCE: temp/clock display faided
its the display theat is fading away. I've haad meter's do the same thing after awhile and there's nothing you or I can do. Thanks for using Fixya
Posted on Dec 23, 2008
SOURCE: Fisher and Paykel electric cooker (Pepper)
No, it's the first 2 buttons on the left pushed together as well as the + or - to set the right time
Posted on Jul 16, 2009
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
30 " Convection wall oven
F2 During BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2 During CLEAN C ontrol senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Nov 26, 2010 | GE 27" Built-In Double Electric Convection...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
GE Wall Oven JKP13GOTBB Touchpad is "too sensitive"??
I don't see that exact model number listed. Check the model / serial number again. If the unit is not too old, you can probably get a replacement key panel which should solve your problem.
Aug 12, 2009 | GE JTP45 Electric Double Oven
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
How to set time with new control board?
You may set the clock on your Microwave per page 6 of the User Guide by following the steps below. We've included the link for the User Guide below.https://www.whirlpool.com/content/dam/global/documents/200105/owners-manual-8300610.pdf
This is a 12 hour clock and does not show a.m. or p.m. To Set: Before setting, make sure the oven, Timer and Timed Cooking are off. 1. Press CLOCK. 2. Press the HR or MIN "up" or "down" arrow pads to set the time of day. 3. Press CLOCK or START/ENTER. To Disable: The clock time can be disabled so that it does not show on the display. To disable, press and hold CLOCK for 5 seconds. To display the clock time again, press and hold CLOCK for 5 seconds and the time of day will show on the display. The clock time should not have to be reset.
Nov 03, 2017 | Whirlpool GMC305PD Electric Single Oven
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Ovens Logo
71 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
